Old 22nd Nov 2017, 4:27 pm   #1
mole42uk
mole42uk's Avatar
Default Ferrograph 6 pinch roller adjustment?
I've a problem I've not had to deal with before - the pinch roller on a Ferrograph 6 series isn't touching the capstan and I can't work out how to adjust it. Of course, the manual doesn't help much.
Can anyone point me to the correct procedure?
Thanks,
Richard
Index:
mole42uk is offline
Old 22nd Nov 2017, 11:23 pm   #2
BillDWVA
Default Re: Ferrograph 6 pinch roller adjustment?
I have had a quick look at the underside of a series 5 deck (not sure how much difference there is between 5 and 6 as the operating mechanism appears the same) and cannot find any obvious method of adjusting anything. When the 'Run' lever is pulled and holds to the solenoid it just lets the pinch roller mech fall back against the capstan under spring pressure. It only does this when the deck is energised?
BillDWVA is online now
Old 23rd Nov 2017, 8:26 am   #3
mole42uk
mole42uk's Avatar
ISTR there are more similarities between the 5 and the 6 than differences.
The pinch roller does move correctly in ‘Play’ but is held just slightly away from the capstan, about the thickness of a tape. There must be a way to adjust the stop, I’ll have another look today.
Richard
Index:
mole42uk is offline
Old 23rd Nov 2017, 11:36 am   #4
BillDWVA
Another thought: Is it possible to move the capstan bearing carrier position in relation to the pinch roller, as a way of closing the gap? I.e. The whole capstan assembly.
Old 23rd Nov 2017, 3:18 pm   #5
mole42uk
mole42uk's Avatar
Unfortunately not, the three screws that hold it to the plate are well fitted into the top plate. I also suspect that moving the flywheel / capstan assembly may make for troubles between the motor and the flywheel.
Richard
Index:
mole42uk is offline
Old 23rd Nov 2017, 7:51 pm   #6
vidjoman
Could it just be a case of rubber shrinkage due to age.
vidjoman is offline
