Old 21st Nov 2017, 9:54 pm   #1
NickG0HIK
NickG0HIK's Avatar
Default What is this connector?
Has anyone seen this military coaxial connector and know what it is called ?
It's the brass one to the front right side.
It's part number is 10H/7560043.
Or even better anyone got one or two mating plugs that they would part with.
Thanks
Nick
Name:	GEE Ground.jpg
NickG0HIK is offline
Old 22nd Nov 2017, 4:52 pm   #2
G8BBZ
G8BBZ's Avatar
Default Re: What is this connector
It looks similar to the connector in the attached pics. I can't see if your connector is male or female. For reference, the outside diameter of the outer coaxial conductor on the plug is 5/8".
I do not know what this connector is called. I have only ever seen them moulded onto the end of the cable as in the pics. They are used in conjunction with Uniradio1 coax at SHF.
Hope this helps
cheers
Peter G8BBZ
ID:	152722   Click image for larger version
Peter
G8BBZ is offline
Old 25th Nov 2017, 8:56 pm   #3
NickG0HIK
NickG0HIK's Avatar
Hi Peter,
The ones I have are female and the threaded portion is 0.5" with the outer body being 0.75".
The inner on yours would also need to be recessed, so I don't think the one in your picture is the same thing.
Thanks for the input.
Nick
