Old 20th Nov 2017, 6:46 pm   #1
G6Tanuki
G6Tanuki's Avatar
Default Chimney antenna-mount: twist or clamp?
I've got the roofers/chimney-stack-rebuilders in at the moment, and intend to use the access their scaffolding provides to put up a Hy-Gain 12AVQ HF antenna.
A couple of 18-inch galvanised 'Mitre brackets' will be used on the chimney itself. The 'traditional' way to attach these is with a galvanised wire round the chimney - and usually the ends of the wire are simply twisted back on themselves to provide a 'loop' for the J-bolts that are then tightened.
I don't like this twisted approach: my idea is to use stainless-steel yacht-rigging wire and similarly-sourced "U-bolt clamps":
https://www.s3i.co.uk/stainless-steel-rope-grip.php
which should last well enough to see me into the time when HF DXCC is really not the sort of thing I'm interested in.
Ideas? Suggestions? Should I use 'thimbles' where the wire is attached to the J-bolts?
G6Tanuki is offline
Old 20th Nov 2017, 7:02 pm   #2
Tractorfan
Tractorfan's Avatar
Smile Re: Chimney antenna-mount: twist or clamp?
When I was a lad we used to fold the lashing cable round the thimble. Then we would untwist about a foot of said cable and wrap each strand in turn around the two 'passes' of lashing cable. When that strand ended, we'd wrap the second strand until that also ended, then the third, and so on. If you get my drift.
Hope this helps.
Cheers, Pete.
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 20th Nov 2017, 7:10 pm   #3
G6Tanuki
G6Tanuki's Avatar
Default Re: Chimney antenna-mount: twist or clamp?
Yes that wrapping-style is what I'm familiar with - it's the same as used in the classic double-ended "Western Union" splice on overhead telegraph lines.
Problem is, stainless-steel strainer wire is really a lot more-springy than the galvanised-iron lashing-wire of old. Getting the individual strands of stainless to play nicely and not spring undone when I wind the J-bolts up to a decent torque could be a problem; hence my interest in using U-bolt clamps.
G6Tanuki is offline
Old 20th Nov 2017, 8:04 pm   #4
emeritus
No personal experience, but the accompanying extract from a text book on ropework for yachts (Modern Rope Seamanship, Colin Jarman and Bill Beavis, 2nd Edn, 1983) explains how to make reliable splices in wire ropes. It confirms the need for thimbles (as large as possible) and that the clamps (bulldogs) need to be correctly oriented to avoid damaging the wire. The alternative would be to use a swageless terminal.
emeritus is online now
Old 20th Nov 2017, 8:07 pm   #5
mole42uk
mole42uk's Avatar
Note that some u bolt clamps have undersized threads and won’t reliably clamp the wire.
Richard
Index:
mole42uk is offline
Old 20th Nov 2017, 8:33 pm   #6
G6Tanuki
G6Tanuki's Avatar
Ooh thanks for that! I clearly have quite a bit to learn about this. Alas my uncle Jim [the only real seafarer in the family] is no longer around to give me guidance.
G6Tanuki is offline
Old 20th Nov 2017, 8:35 pm   #7
G6Tanuki
G6Tanuki's Avatar
Good advice again: I'd kinda hope that if I'm buying stuff from the people who equip round-the-eorld yacht-racers they'll know their stuff.
"Cheap" is OK, but not when it involves paying to get scaffolders out to let me reach the failed parts.
G6Tanuki is offline
Old 20th Nov 2017, 8:41 pm   #8
ms660
ms660's Avatar
Stainless steel duplex grips for a loop.
Lawrence.
ms660 is offline
Old 20th Nov 2017, 9:28 pm   #9
Bazz4CQJ
Bazz4CQJ's Avatar
When using stainless steel marine fittings, how do people avoid the pick-up or galling problem on tightened threads; application of some type of a preferred grease, or PTFE tape... ? I've seen some expensive bits of kit completely blethered when people were mean with the tape on stainless pipe fittings!
B
We know there are known unknowns. But there are unknown unknowns – ones we don't know we don't know.
Bazz4CQJ is online now
Old 21st Nov 2017, 5:03 pm   #10
Biggles
Good choice to use stainless if you burn solid fuel. Our Rayburn range burns coke and anything mounted on the chimney is eventually compromised due to the mildly corrosive fumes coming from the stack. A lot of standard rigging items seem to be made from fairly soft iron too with a rather thin galvanised coating so they don't last very long when exposed to smoke. I just tend to coat mine with black underseal clag and inspect them fairly often. I'm a bit of a monkey for trying out new antennas so that isn't a problem, and it keeps the neighbours entertained when I'm clambering about on the roof. I find that a bit of plastic tubing pushed over exposed threads on bolts helps a lot when you need to remove the nuts later on.
Alan.
Biggles is offline
Old 21st Nov 2017, 6:36 pm   #11
AC/HL
AC/HL's Avatar
That sounds like the usual declining standards to meet expectations of ever lower prices. Admittedly it's quite a few years since my duties as a general workshop engineer included aerial rigging, but the steelwork was always heavy duty and well galvanised. I used the same method as Pete in post 2.
Bill, BVWS member
AC/HL is offline
