18th Nov 2017, 10:17 am | #21 | |
Re: Unknown 160m Transmission
Regds, Russell W. B. G4YLI. |
18th Nov 2017, 11:51 am | #22 | |
Someone came to the farm in the early 90s and asked about putting a mast up for a navigation system for the Forth. They'd picked the spot because of the adjacent trig point. I asked "What frequency?" He demurred and said below the TV band. I said I used radio gear quite a lot and needed the exact frequency and specification of the signals. He'd thought he was dealing with someone non-technical. He named the frequency, right in 70cms "Oh, I'm licensed for 400W in that range, and high gain or omni antennae... are you sure this is going to work?" He went away. Result! David
19th Nov 2017, 8:42 am | #23 |
Hi David,
I was NOT that man! Yes, trig pillars were popular sites, as were lighthouses and coastguard lookouts. I ran a chain covering the Dover Strait. We took power from the CG station at Langdon Battery and used an old gun mount for the Texas Tower mast. Anyway, this is getting away from the topic, Top Band activity! I listen occasionally, using the G4FPH SDR, and hear quite a bit of AM activity on 1977kHz. I have a KW-160 and a Codar AT5 here so once I finish putting down a few more radials I will give the band a try. Oh, and if anyone comes across any HIFIX gear, I'd love to get hold of a Low-Power Transmitter! 73 Roger/G3VKM |
19th Nov 2017, 8:48 am | #24 | |
There's some interesting photos on that link, must have a closer look. Cheers Roger |
19th Nov 2017, 1:28 pm | #25 |
Great pictures.Seems I have started something mentioning by saying I did not recognise that 1925khz transmission.
Very enjoyable posts though i add.
19th Nov 2017, 3:35 pm | #26 |
https://youtu.be/WBeymCP_-xA?list=UU...ZJ2fL8iv3Phamg
I recorded this clip a few years ago. ..... (The trusty old B28 is still giving yeomen service) SORRY! wrong clip appeared. https://www.youtube.com/watch?v=Q0MU...ZJ2fL8iv3Phamg Last edited by gm0ekm cecil; 19th Nov 2017 at 3:46 pm. Reason: Finger trouble. |
20th Nov 2017, 8:37 am | #27 |
Hi Cecil,
I think that the second clip is LF Loran? Or, depending when you made it, it could be Pulse/8 another Decca/Racal system that I last saw used in the 90s. 73 Roger/G3VKM |
20th Nov 2017, 6:11 pm | #28 |
Hi Roger, yes the video clip on 100KHz. was I suspect was the Norwegian Loran C. The recording was made in 2013 after the US system was closed down, of course all gone now as the system in Europe has also been closed down. Ironically there is talk of a back up hyperbolic system for the current GPS . The first video clip (VMARS AM net) was posted in error ........... finger trouble!!
