Old 7th Nov 2017, 11:28 am   #1
yesnaby
yesnaby's Avatar
Default Mains synchronous clock movement
Hello,
My mains synchronous clock (made in woodwork class half a century ago) has stopped working. I think the motor coil has gone open circuit.
There is only one place that sells the motor, but unfortunately they are trade only!
See
https://www.cousinsuk.com/product/ma...ous?code=M7814
Note: this has to fit a panel 11 mm thick, there are other ones I can get for a 5 mm panel: however, the construction of the clock makes these unusable.
Perhaps I could have the coil rewound? But there may be other problems with the motor, is it worth the risk?
Or could I find a friendly clock repairer who could order for me?
Michael
yesnaby is offline
Old 7th Nov 2017, 11:43 am   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Mains synchronous clock movement
I'm sure Ed Dinning could re-wind it for you.
Or you could re-wind yourself using thicker wire and power it from a small step-down transformer: http://sound.whsites.net/clocks/ocm.html
I order from Cousins from time to time, though I tend to wait for the shopping list to get quite long to make the postage charges worthwhile. AFAIK, the most relevant part of their "trade only" policy is that you can't return goods ordered in error like you can usually with mail ordering.
Could you post a pic of the motor you currently have, please?
Nick.
Nickthedentist is offline
Old 7th Nov 2017, 11:47 am   #3
yesnaby
yesnaby's Avatar
Hello Nick,
For Cousins, when you register with them don't you have to confirm that you are in the trade?
Michael
PS Sorry Nick, photo coming asap.
yesnaby is offline
Old 7th Nov 2017, 11:57 am   #4
yesnaby
yesnaby's Avatar
Photos as promised
ID:	151916   Click image for larger version
ID:	151917   Click image for larger version
yesnaby is offline
Old 7th Nov 2017, 12:07 pm   #5
M0FYA Andy
Did CE marking exist half a century ago?
Andy
M0FYA Andy is offline
Old 7th Nov 2017, 12:11 pm   #6
yesnaby
yesnaby's Avatar
You are right, this is a replacement movement! Must be 20 years old though I can't remember exactly.
yesnaby is offline
Old 7th Nov 2017, 12:29 pm   #7
mole42uk
mole42uk's Avatar
We have a Cousins account, we have to place an order most weeks.
Richard
Index:
mole42uk is offline
Old 7th Nov 2017, 1:55 pm   #8
Boater Sam
Boater Sam's Avatar
CE marking started in 1993 replacing the EU mark.
Boater Sam.
BVWS Member
Boater Sam is online now
Old 7th Nov 2017, 2:44 pm   #9
Hampus
Hampus's Avatar
Yes you have to, but that is just a checkbox you have to tick... No proof is requested. It is only a matter of honesty I have bought stuff from them several times and I am not in the trade.
Hampus is offline
Old 8th Nov 2017, 1:03 am   #10
Herald1360
Herald1360's Avatar
And presumably you don't have to say exactly what trade you're a member of....... you're a "restorer"- a perfectly good trade!
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 8th Nov 2017, 9:42 am   #11
Phil G4SPZ
Phil G4SPZ's Avatar
H S Walsh are another supplier who come recommended:
https://www.hswalsh.com/categories/mains-synchronous
Phil (BVWS / BVTVWM / NVM / GQRPC 2101)
Optimist [n]: Someone who is not aware of the full facts
Phil G4SPZ is offline
Old 8th Nov 2017, 9:50 am   #12
Brigham
Can we have a pic. of the clock?
Brigham is offline
Old 8th Nov 2017, 9:53 am   #13
yesnaby
yesnaby's Avatar
Herald1360: Good point!
Phil: Unfortunately neither the CM310 nor the CM311 is suitable.
The CM310 has a maximum panel thickness of 5 mm whereas mine is 11 mm; the CM311 is too big and also has no seconds hand.
Thanks anyway!
The Cousins one (M7814) is now in stock again so I'll try to order from them.
Brigham: Yes, indeed, photo coming this morning.
yesnaby is offline
Old 8th Nov 2017, 10:03 am   #14
M0FYA Andy
Another approach is to rewind the motor to operate on a low voltage and add a transformer. I've previously linked here to a website which gives details, but I can't spot my posting at the moment. It makes sense because the typical coil for operation at 240v is wound with thousands of turns of fine wire, whereas rewinding for, say, 6 volts means fewer turns of thicker wire, much more manageable.
Andy
Old 8th Nov 2017, 10:37 am   #15
Nickthedentist
See my link in post 2, Andy
Old 8th Nov 2017, 12:06 pm   #16
yesnaby
yesnaby's Avatar
Photos
ID:	151968   Click image for larger version
yesnaby is offline
Old 8th Nov 2017, 12:11 pm   #17
Boater Sam
Boater Sam's Avatar
Now that is pretty, and you made this when you were in your crib?
Boater Sam.
BVWS Member
Old 8th Nov 2017, 12:26 pm   #18
yesnaby
yesnaby's Avatar
Age 14 I think!
Perhaps it could also do with a set of new hands ....
yesnaby is offline
Old 8th Nov 2017, 12:28 pm   #19
Nickthedentist
That's a lovely piece indeed, with a classic 1930s look to it.
Old 8th Nov 2017, 3:25 pm   #20
M0FYA Andy
Oops, I hadn't spotted that you'd already mentioned the idea.
Andy
