Old 1st Nov 2017, 6:16 pm   #1
Linnovice
Default B77 case clean
Hi all, Iím in the process of refurbing a Revox B77 which has spent a good number of years stored in a loft. Itís extremely dusty/dirty. Iíve managed to clean all the mechanism and boards, mainly with IPA. Iím now left with the case. Itís the standard grey box which I think is coated with Nextel? Does anyone have any pet ideas on how to clean it. Itís very slightly sticky so the dust sticks to it making for a very unsightly finish. Would it be possible to put it in the dishwasher or would that be too extreme? I donít fancy the toothbrush and detergent route much. Mike
Small Scotch, New Aids and Happy Ears
Linnovice is offline
Old 2nd Nov 2017, 6:52 am   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: B77 case clean
No idea re dishwasher as never had or used one, thing is you can't do a small area to test. Just use a bigger brush Mike like a nail/scrubbing brush.
Andy.
Old 2nd Nov 2017, 11:16 am   #3
brenellic2000
Nextel was used in outer space so should be durable!
The best bet for a first attack is always household soap and water on a damp rag, or methylated spirits, but don't use meths near transfers. Stubborn stickyness usually succumbs to lighter fuel.
Barry
brenellic2000 is offline
Old 2nd Nov 2017, 11:42 am   #4
paulsherwin
paulsherwin's Avatar
Foaming bathroom cleaner works surprisingly well on grubby surfaces. It even removes old fag smoke deposits. You just spray on a layer of foam, leave it 5 minutes to break down, then wipe it off with a rag. I buy mine from Poundland.
paulsherwin is offline
Old 2nd Nov 2017, 1:45 pm   #5
Vintage Engr
Have had this problem a few times. Apparently this coating does degrade. I understand that there is a company in Germany that can re-coat the B77 cases.
Not tried it for reason of cost implications!
Mine is still sticky, despite all known cleaning methods.
David.
Vintage Engr is offline
Old 2nd Nov 2017, 2:36 pm   #6
Ted Kendall
There's not a lot of moisture in outer space, and damp degrades this stuff. Shame, because the feel is positively luxurious until it breaks down.
Ted Kendall is offline
Old 13th Nov 2017, 6:10 pm   #7
revoxhut36
I have a B77 which I have had from new. Case is also sticky. Not sure how to clean it.
revoxhut36 is offline
Old 13th Nov 2017, 9:24 pm   #8
AC/HL
AC/HL's Avatar
Some information in a vinylengine thread: https://www.vinylengine.com/turntabl...p?f=57&t=48545
Bill, BVWS member
AC/HL is offline
Old 17th Nov 2017, 11:14 pm   #9
soundfactory
Dishwasher would do it, I wouldn't put it on the hottest setting though.
If you want to remove the Nextel coating completely (sometimes the best option if its really bad) get some meths on it, it comes off with ease.
soundfactory is offline
