Reply
Old 29th Oct 2017, 2:29 pm   #1
Pieter H
Default Philips-Mullard TV tuners 1955-1960
impossible to find any circuit diagrams of the Philips/Mullard TV's for the 1955-60 periode. I'm looking for the codes of the tuners used in these sets, both the product code (usually in the AT75xx or AT76xx range) and the factory code (A3 xxx yy if made in Eindhoven, probably MW xxx yy if produced in Micham).
As far as I know it concerns the following TV families:
  • 1955/56: 1756/1757/2157U
  • 1955/56: 1458/1758U
  • 1956/57: 1468/1768/2168U
  • 1956/57: 1772/1778U
  • 1958/59: 1796/2196U
  • 1959/60: 17TG100/17TG200/17TG300
Any help much appreciated!
Cheers, Pieter
Pieter H is offline   Reply With Quote
Old 29th Oct 2017, 3:04 pm   #2
FERNSEH
FERNSEH's Avatar
Default Re: Philips-Mullard TV tuners 1955-1960
From the components list in the service manual for the Philips 2155U. Related models are: 1458U, 1468U and 1772U.
The tuner unit employed in these receivers is given as: complete tuner MK.892.82. Tuner unit less valves HY.142.26.
Spare parts for the tuner have MK prefixes. E.G. the tuning spindle assembly is MK.958.26. Only a few parts in these receivers have A3 prefixes.
Service manual is dated February 1957.
DFWB.
FERNSEH is offline   Reply With Quote
Old 29th Oct 2017, 3:28 pm   #3
Jac
Jac's Avatar
Pieter,
I should have the service manual for probably all the above types.
As well as for the AT7520 & A3.791.64 tuner modules.
Jac
Jac is offline   Reply With Quote
Old 30th Oct 2017, 8:18 am   #4
Heatercathodeshort
Heatercathodeshort's Avatar
Just a few from manuals that are at hand. The rest are at the back of the garage..
1792/2192U Feb 1959 Including FM radio Less valves. HY.142.38
1756U August 1955. MK.892.71
1768/2168 October 1967. HY.142.30
Note. Later 1768U models were fitted with a tuner that employed printed circuit clip in coils similar to the tuner fitted in the 17TG100U series. John.
Heatercathodeshort is offline   Reply With Quote
Old 30th Oct 2017, 10:47 am   #5
Pieter H
That's a good start, thanks to all!
I assume all mentioned tuners are based on the PCC88-PCF80 valve set.
Interesting to see that Philips/Mullard used a two-step approach for the tuner manufacturing. Apparently the mechanical and electrical assembly was done in a first factory, coded HY, while valve insertion and subsequent tuner alignment were done in the Mitcham factory, coded MK. Does anybody have an idea about which factory this "HY" might be? Alternatively, but less likely, this was also Mitcham, with HY the factory code for unfinished sub-assemblies and MK for complete modules.
Jac, I'll contact you off-line.
Old 30th Oct 2017, 4:07 pm   #6
FERNSEH
FERNSEH's Avatar
Doesn't help much, but here's a picture of the miniature tuner fitted in the Philips 19TG108U. Valves are PCC89 and PCF80. Made in 1961 the 19TG108U was a development of the 1959/60 model 17TG100U.
DFWB.
Old 31st Oct 2017, 8:56 am   #7
Heatercathodeshort
The standard valve line up in the UK from 1954-59 was PCC84 and PCF80.
The frame grid PCC89 did not appear until 1959 but strangely the earlier PCC88 was overlooked by all manufacturers other than in a range of very high gain Pye models introduced in 1958. John.
Old 31st Oct 2017, 10:15 am   #8
Pieter H
Hi John,
something interesting happened here.
Contrary to your statement, the "continental" Philips tuners changed to the frame grid PCC88 (in combination with the PCF80) in 1956 and it was used massively in two generations of tuners until 1963. Apparently Mullard stuck to the PCC84, for reasons not clear to me.
In contrast, Mullard was the first to switch to the PCC89 in 1959 (still in combination with the PCF80), whereas the "continentals" waited for the PCC189. This one was introduced in 1960 in the French tuners from the Dreux factory, again still in combination with the ubiquitous PCF80.
In 1961 the Dutch and German factories then finally changed over to the new combination PCC189-PCF86, both frame grid valves. I still have to find out where the PCC89 and PCC189 differ, but it is clear that the latter quickly replaced the 89.
To be continued!
Cheers, Pieter
Old 31st Oct 2017, 6:05 pm   #9
Heatercathodeshort
Sorry Pieter, I should have said the PCC88 was overlooked by British manufacturers. I can't understand why due to the much superior gain of the PCC88 over the PCC84.
Philips manufactured truly excellent tuners. John.
Old 31st Oct 2017, 8:24 pm   #10
AC/HL
AC/HL's Avatar
Could it have been that our service areas were smaller, or perhaps the smaller bandwidth requirements of the 405 system?
They would have been forced to change when the PCC84 inevitably went from current to maintenance status, possibly the 88 wasn't far behind it?
Bill, BVWS member
AC/HL is offline   Reply With Quote
Old 31st Oct 2017, 8:32 pm   #11
FERNSEH
FERNSEH's Avatar
I believe the only difference between the PCC89 and PCC189 is the pin connections to the electrodes.
PCC89: https://www.radiomuseum.org/tubes/tube_pcc89.html Pin connections same as PCC84.
PCC189: https://www.radiomuseum.org/tubes/tube_pcc189.html Pin connections same as PCC88.
DFWB.
Old 31st Oct 2017, 9:33 pm   #12
Pieter H
Thanks a lot for your inputs, the picture is getting clearer.
So the Philips tuner organization at large made the switch from PCC84 to PCC88 in 1956, which required a re-arrangement of the valve socket connection. However, with the socket rotated 180 degrees the connections were roughly identical, so in that respect the effort was limited. But the benefit was considerable, as John pointed out, due to the almost doubled effective gain of the frame grid construction. When the PCC88 was replaced by the pin-compatible PCC189 that was an almost drop-in replacement. This switch-over was made in 1960.
I agree that it's difficult to judge why the Mitcham tuners stayed with the PCC84 for another 3 years. Every TV standard, irrespective of the channel bandwidth, should have benefited from the improved valve. So the most plausible explanation is an economic one. The UK Philips sets had stayed relatively long, compared to the continent, with single channel non-tunable front ends, the first tuner-equipped family being the 1446/1746/1747 in 1954, three years behind the Netherlands and Germany. Given the modest initial volumes it is not unreasonable to assume that in 1956 the first generation investments were not yet written off and a conversion to the PCC88 not justifiable. A "thin" explanation, I admit, but for lack of a better one.
But even then it is difficult to understand why the Mitcham tuners even stayed with the PCC89, because that valve, like the PCC84, had the screen connected to the second gate. In the PCC88 and PCC189 the screen had a separate pin for direct grounding, which was in principle more effective. So a follow-up question: did the UK tuners stay with the PCC89 or did they also switch over to the PCC189, and if so when?
Cheers, Pieter
Old 1st Nov 2017, 12:24 am   #13
Synchrodyne
From its TV AGC papers of 1957-58, one may infer that for positive/AM TV systems, Mullard preferred to use remote cutoff valves in AGC’d positions, although the sharp cutoff type was seen as being acceptable for negative/FM systems.
The PCC84 comprised a pair of sharp cutoff triodes that when operated in series cascode, had a net remote cutoff characteristic.
The PC88 had sharp cutoff triodes that in combination provided a sharp cutoff result.
The PCC89 had remote cutoff triodes that in combination produced a curve similar to that of the PCC84
So, given its preference, it seems reasonable that for UK domestic production, Mullard would have stayed with the PCC84 until the PCC89 became available, rather than switching to the PCC88.
Mullard described the PCC189 as the PCC89 with a different pinning arrangement that facilitated alternative positioning of components in tuner units.
Cheers,
Synchrodyne is offline   Reply With Quote
Old 1st Nov 2017, 12:44 pm   #14
Pieter H
I've seen this discussion before and initially assumed the statements were correct. However, diving deeper into the matter I think I have to disagree with your statement that the remote vs. sharp cut-off was valve-dependent. What I found in the Philips valve documentation is that it is circuit dependent!
See the first attached picture, illustrating the PCC84 Vg-Ia characteristic for circuit configuration A, where the cascode grid is biased from a series resistor in the cathode chain, vs. configuration B where the grid is independently biased. The curves show a remote AGC cut-off behaviour for A and a sharp AGC cut-off for B.
ALL Philips tuners used configuration B, albeit with over time higher resistor values of 1M. At least the continental (non-UK) tuners. I don't posses circuit diagrams of the Mitcham tuners yet, so can't verify whether they used configuration A to obtain remote cut-off as you state. You might well be right, but then it's not a valve but circuit issue.
This behaviour did not change with the new valves like the PCC88 and PCC189, which had almost identical DC behaviour as the PCC84 and PCC89. The second picture shows the (delayed) AGC curves for a PCC88-equipped tuner in combination with EF80 IF valves, clearly showing the 5V tuner AGC cut-off. When the EF184 was introduced that valve required a much higher (20V) cut-off whereas the equivalent PCC189 AGC control voltages remained identical.
Cheers, Pieter
Name:	Philips 1954 PCC84 characteristic.jpg
ID:	151650   Click image for larger version
Name:	Philips 1959 AT7634 AFC.jpg
Old 6th Nov 2017, 10:17 pm   #15
Synchrodyne
The PCC89 data show a range of grid base numbers according to the exact circuit details, but the range is from 9 to 15 volts for divider bias in the upper triode grid, and around 16 volts for sliding bias. Given that the triodes themselves are of the remote cutoff type, this is not so surprising. The Mullard PCC89 was announced in Wireless World 1957 October, p.474, including the comment that it had a variable-mu frame grid construction to assist in the reduction of cross-modulation effects. Presumably that claim applied for both the divider bias and sliding bias circuit configurations.
In its original work on the series cascode circuit, RCA emphasized the sliding bias option, observing that this resulted in a stretched grid base and what was close to a square-law curve, which minimized cross-modulation. I imagine though that the divider bias option was attractive to some setmakers in that with its short grid base, around 5 volts for the early cascode double triodes, as compared with 10 volts or so for sliding bias, it required less gain from the AGC system.
Cheers,
Reply
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Copyright ©2002 - 2017, Paul Stenning.
