Old 9th Sep 2017, 3:53 pm   #1
GW4FRX
GW4FRX's Avatar
Default Re-anodising heatsinks?
I found out the hard way today that putting anodised aluminium heatsinks in the dishwasher to clean them is a very bad idea. They're now a sort of streaky grey with black areas where the devices were mounted. "Mortified" is the word.
Is it possible to get heatsinks re-anodised?
GW4FRX is offline
Old 9th Sep 2017, 4:33 pm   #2
kalee20
Default Re: Re-anodising heatsinks?
The alkaline solution of dishwasher tablets attacks aluminium, as you've found out!
Depending on how bad the surface is, you may be lucky.
Take a few photos and email South West Metal Finishers. No connection apart from a satisfied customer in the day job!
kalee20 is offline
Old 9th Sep 2017, 5:05 pm   #3
GW4FRX
GW4FRX's Avatar
Originally Posted by kalee20 View Post
The alkaline solution of dishwasher tablets attacks aluminium, as you've found out! Depending on how bad the surface is, you may be lucky.
Oh well. I learned a lesson from that mistake. The surface feels very smooth so hopefully something can be done; I've e-mailed as you suggest and will see what transpires. Fingers crossed...
GW4FRX is offline
Old 9th Sep 2017, 7:11 pm   #4
Craig Sawyers
Craig Sawyers's Avatar
Black anodising is essentially cosmetic for a heatsink that is not running stinking hot.
The majority of heat transport from a heatsink is via convection, not radiation, for typical heat rise of say 40C. In that case the difference between a black anodised heatsink and a shiny aluminium one is negligible that for typical heat rise.
Rather than pay for a small quantity to be stripped to bare metal and re-anodised, I'd be tempted to spray paint them black.
Craig Sawyers is offline
Old 9th Sep 2017, 7:19 pm   #5
Tractionist
Per Craig: If you use VHT [AKA Very High Temperature] spray paint there is no chance that this will lift or bubble .... this stuff is used by car restorers etc. on exhaust manifolds. (It goes under then name of VHT / 'Firecote' etc. Retailed by CarPlan - made by Tetrosyl Ltd. Bury, Lancs. BL9 6RE. Tel. 0161 764 5981.)
They'll be fine ..............
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 9th Sep 2017, 7:54 pm   #6
GW4FRX
GW4FRX's Avatar
That's interesting -- thank you. Does this type of paint work well on aluminium? I seem to recall reading horror stories about needing etch primer or exotic surface preparation to make paint adhere properly.
GW4FRX is offline
Old 9th Sep 2017, 8:33 pm   #7
Bazz4CQJ
Bazz4CQJ's Avatar
For an outlay of 15 shillings, anodising can be done in the average home...according to PW in 1962 (see attached)!
I wonder how big your heatsink(s) are? PM me if you consider any "homebrew" option.
As for dish washers, I have put the odd item of agricultural engineering in them, but never any item of radio/electronics.
B
Data beats opinions most times... that's my opinion, though I have no data on that.
Bazz4CQJ is offline
Old 9th Sep 2017, 9:24 pm   #8
kalee20
Worth trying for some fun!
I believe after dyeing, commercial anodising features a further electrolytic operation which hardens the oxide coating and makes it more dense. This is missing from the PW article. But I may be wrong on this. Hopefully someone will correct me!
Look forward to what South West Meatl Finishers come up with. If time is not of the essence, they may offer to wait till a big batch of something arises, and put it in at the same time for a nominal sum.
kalee20 is offline
Old 9th Sep 2017, 10:32 pm   #9
GW4FRX
GW4FRX's Avatar
Originally Posted by Bazz4CQJ View Post
For an outlay of 15 shillings, anodising can be done in the average home...according to PW in 1962 (see attached)! I wonder how big your heatsink(s) are? PM me if you consider any "homebrew" option. As for dish washers, I have put the odd item of agricultural engineering in them, but never any item of radio/electronics.B
I quite often put passivated steel chassis items for restoration (such as Racal receiver side panels or bottom chassis members) in the dishwasher. They come out looking like brand-new. But aluminium heatsinks evidently don't, alas.
Not sure the homebrew option would go down very well with Madam or the elf 'n' safety people nowadays....
GW4FRX is offline
Old 9th Sep 2017, 10:37 pm   #10
GW4FRX
GW4FRX's Avatar
That would be ideal. There's no rush at all -- the PSU for this amplifier needs some re-design and a new PCB and there are still some components to source.
GW4FRX is offline
Old 10th Sep 2017, 11:34 am   #11
dseymo1
Being amphoteric, it's difficult to predict how the aluminium oxide will have reacted, but there's a fair chance that it's just the dye which has been leached out. I'd be inclined to dump the heatsink in a hot dye bath for a few hours before contemplating anything more drastic.
dseymo1 is offline
Old 10th Sep 2017, 12:27 pm   #12
John M0GLN
John M0GLN's Avatar
The DIY process I used about 5 years ago required the freshly anodised article, whether natural colour or dyed, to be immersed in boiling distilled water for 30 minutes to harden it, the piece I anodised has been outside now for that period and looks as good as it did when made.
John
John M0GLN is offline
Old 11th Sep 2017, 5:43 am   #13
Bazz4CQJ
Bazz4CQJ's Avatar
My understanding is that the conditions chosen for anodising intentionally create a porous oxide layer and the dye goes in to the pores. That is then is sealed in by the action of the subsequent immersion in boiling water which "seals" the pores, though I guess the same could be done electrolytically.
B
Bazz4CQJ is offline
Old 11th Sep 2017, 8:52 am   #14
Craig Sawyers
The reason that anodised aluminium cannot be used in ultra high vacuum systems is the pores. These give rise to what is known as a "virtual leak". In other words it has the characteristics of a leak, preventing the vacuum level to be attained, but in fact it is something in the chamber outgassing. And anodised aluminium outgasses pretty much forever.
The aluminium treatment for UHV use is electropolishing.
For decorative use (ie not vacuum use!) electropolishing and then anodising (and dying) gives a superb mirror like finish.
Old 11th Sep 2017, 5:57 pm   #15
GW4FRX
GW4FRX's Avatar
Look forward to what South West Metal Finishers come up with.
Unfortunately they came up with a mildly snotty reply stating that they "...do not undertake this kind of work." Oh well. Back to the Yellow Pages.
GW4FRX is offline
Old 12th Sep 2017, 8:00 am   #16
Craig Sawyers
I've used these guys on a number of occasions, and found them to be pretty good. Perhaps worth a try. Based in Uxbridge.
http://www.metroplating.co.uk/
Old 12th Sep 2017, 8:35 am   #17
Goldie99
That's an excellent link Craig - if you click on the various services they offer, they give some very good concise descriptions of each of the anodising processes.
Goldie99 is online now
Old 12th Sep 2017, 4:34 pm   #18
Telleadict
Hello
This sounds like something that motorbike customizers or restorers would need doing. Perhaps if you could get a read of the adds in a 'bike magazine there might be some firms that would do a small job.
Just a ramdom thought.
Will
Telleadict is online now
Old 12th Sep 2017, 6:11 pm   #19
Craig Sawyers
A guy I know in Sweden has a plater that takes a black anodised heatsink, strips the anodising and then gold plates it. Must ask him who does this, hopefully in a cost effective way.
This is what his gear looks like
Old 12th Sep 2017, 9:03 pm   #20
merlinmaxwell
merlinmaxwell's Avatar
We use metro plating, they are a friendly bunch, worth having a chat at tea time (10 am) outside (fag break) for a "private job". One of the cleanest plating plants I have ever seen.
Cats have staff, it's dogs that have owners.
merlinmaxwell is online now
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
