Old 12th Jun 2017, 7:01 am   #1
FIXITNOW
FIXITNOW's Avatar
Default BTH C2 horn speaker
This is a carry on from this wanted thread
http://www.vintage-radio.net/forum/s...d.php?t=136791
Thanks to John for this damaged Horn base
I had to fill a chip in the lip on the good side then I cast a mould using some Silcoset 101 that I had it was outof date but set ok
I had two good internal ridges but only wanted 1 on thereplacement side so I cast one of these first moved this to the middle andrecast the whole piece this gave me 3 ridges so had to back fill the 2 I didnot need
Than I laid a layer of glass fibre resin and a piece of matand left it to set
Then using some ISOPON bumper filler to bring it up level
I put more glass fibre across the joints on the back forextra support
A good sanding some primer and Ford rio brown to finish
I still need to fit a new logo to the horn but need to ordersome transparent paper
First to print it
And I will need to rewind one side of the coil ,but for thatI will need to make up a rewinding machine
For now its on display with my Cossor Melody maker
Vince
ID:	144340   Click image for larger version
ID:	144341   Click image for larger version
ID:	144342   Click image for larger version
ID:	144343   Click image for larger version
FIXITNOW is offline
Old 12th Jun 2017, 7:01 am   #2
FIXITNOW
FIXITNOW's Avatar
Default Re: BTH C2 horn speaker
and 2 final pictures
ID:	144345   Click image for larger version
FIXITNOW is offline
Old 12th Jun 2017, 8:44 am   #3
60 oldjohn
That is brilliant, and it has not taken you very long either! well done. Pm sent.
John.
60 oldjohn is offline
Old 12th Jun 2017, 11:00 am   #4
David G4EBT
David G4EBT's Avatar
Excellent job Vince!
Depending on the logo design, you may find that you need white rather than clear water-slide ('decal') paper. I recently printed some 'top labels' for the Wartime Civilain Receiver cabinet on clear paper. They looked fine when on the backing paper, but very poor when slid from the backing paper and applied to the top of the radio. I reprinted them on white water-slide paper, and they turned out fine. Can't attach a pic as I'm away from home till tomorrow.
Every success.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 12th Jun 2017, 12:00 pm   #5
Hartley118
Hartley118's Avatar
Brilliant job Vince!
The (rather battered) BTH logo on my example is in black and gold on the horn inner, 17mm dia and on my example its centre is 80mm from the lower rim of the horn.
I attach a photo.
Martin
Name:	P1000131 (Large).jpg
BVWS Member
Hartley118 is offline
Old 12th Jun 2017, 12:08 pm   #6
FIXITNOW
FIXITNOW's Avatar
Where it goes !! cheers
that helps I do have a scan of the logo from another forum member
so will print it out, and now I now where to stick it
FIXITNOW is offline
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
