Old 7th Dec 2006, 6:40 am   #1
LanceM
Default Can 405 line videotape be played back on other media?
Hello,
I was wondering if 405 line videotape can be played back on other mediums. For example what machine might a play a recording from a peto scott model, or Phillips EL series ? I am doing some school related research and could use some input.
Thanks, Lance.
LanceM is offline
Old 7th Dec 2006, 9:27 am   #2
ppppenguin
ppppenguin's Avatar
Default Re: 405 line videotape question
AFAIK, this physical tape format was unique to these machines. Other 1" machines (such as Ampex 5xxx/7xxx and IVC) will not play these tapes.
The line standard is less important - these machines lock to the field pulses and merely replay any line pulses as they were recorded.
ppppenguin is offline
Old 12th Dec 2006, 7:50 pm   #3
Mikey405
Mikey405's Avatar
Hi Lance.
Just to add to what PPPPenguin has already said: I think the Philips EL3400 will happily play back the 1" tapes recorded on the Peto Scott E2770, and I believe (although I have never tried it) that the Philips LDL1200 will also play back tapes from the Peto Scott. The Philips EL3402 won't play back EL3400 or Peto Scott tapes however.
Hope this helps Lance.
From Mike.
Mikey405 is offline
Old 14th Dec 2006, 4:39 am   #4
LanceM
Smile Re: 405 line videotape question
Thank you mikey,
I have sent you a message regarding the question you just answered. So please accept my apology on this. I appreciate all the info, it helps quite a bit.
Thanks, Lance.
LanceM is offline
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
