Old 13th Jul 2016, 4:14 pm   #1
Somerset
Default Maker of zener diode from 1965?
Does anyone know the maker of the type of zener in the link to the pic below?
http://www.voxac100.org.uk/images/front2/thumbs2/zener_15_02.jpg
It's in an amp from 1965 - value is 15v (MV15), around 1/2W rating? It's almost impossible to find info on these things.
Mullard made a "SV" series zener, similarly gold-coloured, but in a different package - but not even that seems to appear in the company's databooks.
Any suggestions, much appreciated.
Somerset is offline
Old 13th Jul 2016, 4:20 pm   #2
camallison
camallison's Avatar
Default Re: Maker of zener diode from 1965?
Does the"IR" above the type number signify International Rectifier?
Colin
camallison is offline
Old 13th Jul 2016, 5:04 pm   #3
ronbryan
Affirmative Captain.
Ron
ronbryan is offline
Old 13th Jul 2016, 5:27 pm   #4
camallison
camallison's Avatar
Colin
Old 13th Jul 2016, 8:22 pm   #5
Marconi_MPT4
Marconi_MPT4's Avatar
Nearest data I have is IR MZ15T10 listed in Iliffe Radio Valve Data published c.1966. Spec appears to match case style in terms of power dissipation.
Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be!
Marconi_MPT4 is offline
Old 13th Jul 2016, 8:26 pm   #6
Aub
Aub's Avatar
Have you got an AC100? They're as rare as hen's teeth. I used to use two of them back in the 70's. If I recall correctly, that zener forms the bias feed, along with 2 others, to give -45 volts.
Aub
Ignorance of The Law is No Excuse - but I didnt know that!
Aub is offline
Old 13th Jul 2016, 9:37 pm   #7
julie_m
Zener diodes are specified by PIV and power dissipation. Any 15 V, 0.75 W (or greater) Zener diode will substitute, although modern ones are more likely to be in a glass or resin package.
Julie {formerly known AJS_Derby}
julie_m is offline
Old 13th Jul 2016, 9:38 pm   #8
Somerset
Thanks! Perfect.
Aub - cheers, yes, it's the zeners in the bias feed - great amp the AC100.
Nick
Somerset is offline
