Old 15th Apr 2016, 8:29 am   #1
newlite4
newlite4's Avatar
Default Modern radios - rubber finish
Having problems recently with better quality radios that have a silky rubber layer on top of plastic. When new, the finish offers good grip and looks attractive, but after only a few years the rubber develops a stickyness that attracts dust and dirt and is impossible to clean.. I have tried most cleaners to no avail, eventually the rubber comes off along with the legends leaving the plastic beneath, ultimately the radio becomes a scrapper.
Many sets use this "temporary" finish, Tivoli PAL, Pure Classic, as well as a host of hand helds. I wish makers would stop doing this, it is worse than the Philips "suedette" finish on their early eighties test equipment that over the years turned into a sticky fluffy mess.
Neil
preserving the recent past, for the distant future.
newlite4 is online now
Old 15th Apr 2016, 9:12 am   #2
mark pirate
mark pirate's Avatar
Default Re: Modern radios - rubber finish
The same thing happens to the back of Sky remotes, it certainly was not a good choice of finish.
Mark
mark pirate is offline
Old 15th Apr 2016, 9:18 am   #3
Goldieoldie
1980s Sony radios have this problem.IPA will get it off.If you are very careful you might be able to remove it over legends as long as you do not rub hard .Let the IPA do the work
Cheers Pete
Goldieoldie is offline
Old 15th Apr 2016, 9:33 am   #4
Nickthedentist
Nickthedentist's Avatar
My brother has a cheapish telescope, about 15 years old, which is the same. It's virtually unusable now without donning disposable gloves first. Sadly, I couldn't shift the stuff with IPA.
Nickthedentist is online now
Old 15th Apr 2016, 9:34 am   #5
paulsherwin
paulsherwin's Avatar
I'm not sure it is repairable in most cases. The plastic itself seems to break down. I suppose manufacturers don't much care what happens to remote controls when they're 10 years old.
paulsherwin is online now
Old 15th Apr 2016, 9:37 am   #6
G6Tanuki
G6Tanuki's Avatar
This problem also affects the rubbery buttons of remote-controls: I have yet to find a good way to clean the buttons to remove the stickiness. Thank $Deity for 'universal' programmable remotes.
Sidenote: I have a few turn-of-the-millennium IBM/Lenovo "thinkpad" laptops that use what's colloquially known as a "nipple-mouse" - a small pink rubberised joystick protruding between some of the keys.
These use rubber covers that go soft with age: I''ve got a supply of new-old-stock covers, but how is it best to store these so they don't degrade to uselessness before I come to use them?
G6Tanuki is offline
Old 15th Apr 2016, 9:38 am   #7
mark pirate
I have managed to remove the rubber goo, luckily it is on the removable battery cover. To be honest, I never liked the 'feel' of the remote with the rubber in place.
Mark
Old 15th Apr 2016, 9:42 am   #8
Nickthedentist
Yes, but just removing the gungey rubbery covering (and leaving whatever hard plastic or metal is underneath) would be a huge bonus in terms of usability. If anyone has any other ideas about how to shift the stuff, please post.
Old 15th Apr 2016, 9:52 am   #9
SeanStevens
SeanStevens's Avatar
I used a small amount of 'imitation' WD40 on a torch that had a similar coating. It cleaned up fine.
SEAN
There are only 10 types of people, those who understand the binary system, and those who don't.
SeanStevens is offline
Old 15th Apr 2016, 10:07 am   #10
Goldieoldie
Another solvent you could try is the stuff for removing sticky labels
Check first it does not attack the plastic !
Pete
Old 15th Apr 2016, 1:16 pm   #11
newlite4
newlite4's Avatar
Thanks for all your replies. This sticky stuff is very difficult to clean off once it starts to appear, it just moves about. Once you think you have a clean surface you are forever wiping off permanent fingerprints. I initially used label remover but without success. I may have a go with IPA or lighter fluid , anything to break down this horrid compound.
Neil
Old 15th Apr 2016, 5:06 pm   #12
SiriusHardware
Quite some time ago I spent a long time getting to the bottom of a problem on a Kenwood UD70 'integrated separates' audio system - I sorted it in the end but the one thing which was beyond me was doing something about the overall (undoubtedly rather nice originally) 'warm rubber' coating which was starting to turn into sticky gunge.
Sonically, the unit was lovely and punched well above its weight, but cosmetically, it was just a year or three from its final journey to the breaker's yard.
SiriusHardware is offline
Old 15th Apr 2016, 6:09 pm   #13
Andrewausfa
Andrewausfa's Avatar
I was reading this thread earlier at work as I've got a pair of, also about 15 year old, quality binoculars that suffer the same. I thought it was sun lotion affecting the covering from when I took them on holiday. The stuff has dissolved down to a fibre mesh underneath. I've tried lighter fluid but no luck.
Andrew
Invisible airwaves crackle with life. Or they should do.
BVWS Member
Andrewausfa is offline
Old 16th Apr 2016, 7:33 am   #14
Jon_G4MDC
Jon_G4MDC's Avatar
Awful stuff. In my experience Ethanol shifts it. The stuff sold for use in indoor heaters.
Usual warnings about check what else it attacks first apply of course.
Jon_G4MDC is offline
Old 16th Apr 2016, 8:47 am   #15
Herald1360
Herald1360's Avatar
Ethanol for indoor heaters? Do you mean methylated spirits?
Small spirit lamps for fondue sets and the like, perhaps. Otherwise paraffin, surely?
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is online now
Old 16th Apr 2016, 12:17 pm   #16
Geoff 555
Geoff 555's Avatar
Hi this is a shot in the dark to say the least, but there is a stripper called Homestrip that removes paint, varnish etc. but does not burn and is safe, will not burn cloths, skin .
I have a laptop that has a rubber finish and I have tried cleaning it without success.
If I can find a small quantity I will have a go.
Cheers.
Geoff.
Geoff 555 is offline
Old 16th Apr 2016, 12:48 pm   #17
emeritus
I haven't had this problem with electronic equipment, but have addressed the sticky rubber problem with tool handles by applying talcum powder. The goo and powder can be worked into a stiff paste that can be more easily removed by rubbing or wiping. Probably not a practical solution where cosmetic appearance is important.
emeritus is offline
Old 16th Apr 2016, 8:31 pm   #18
camtechman
camtechman's Avatar
The same problem soon became apparent with 1980's and onwards Canon SLR cameras. The rubber coating also turned white-ish and later, it was discovered that this was more of a problem with owners who suffered from diabetes. The only remedy, although temporary, was to replace the rubber grips.
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it!
camtechman is offline
Old 17th Apr 2016, 12:42 pm   #19
dseymo1
My now rather ancient Olympus has this problem too.
Oddly, the same sort of finish on my 12 year old car interior hasn't suffered except from wear.
dseymo1 is offline
Old 17th Apr 2016, 9:46 pm   #20
McMurdo
McMurdo's Avatar
I hate the stuff, it seem to be a design fad at the moment. My old VW golf had it all around the interior door pulls and window switches and of course it soon got very tatty. It's used on certain sorts of pot knobs on mixing desks. The rubber coating seems to react with the grease on fingers and it rubs off, sometimes leaving a different coloured plastic under the coating. Nasty!
Kevin
McMurdo is offline
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
