Reply
Old 19th Aug 2017, 10:49 am   #301
thejazzageuk
Default Re: Restore a Beau Decca
Thanks Edward Huggins. I'll check if the TC8H is working and let you know. The other cartridge is an X5M, not a X5H unfortunately!
I've fitted it into the longer casing and it is working up to a point. At low volumes the sound is very good, however when you turn the volume up there is a hum that soon becomes equal to the music level. Could this be because the cartridge output is too high, or maybe if I replace the coax between turntable and amp it would help?
thejazzageuk is offline   Reply With Quote
Old 19th Aug 2017, 12:30 pm   #302
Edward Huggins
The BSR X5M will be a good input mV match for the input stage of the Decca although the input impedence is high. These crystal cartridges do not introduce hum, I suspect the screening from the tone arm to the amp's input.
Edward.
Edward Huggins is online now   Reply With Quote
Old 8th Dec 2017, 12:29 pm   #303
Station X
Station X's Avatar
SG posts moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=142037
Graham. Forum Moderator
Keep the soldering iron hot.
Station X is online now   Reply With Quote
Reply
