Old 5th Apr 2015, 7:27 pm   #1
HuMpH57
HuMpH57's Avatar
Default Spinney SRP115 with BSR C109
New on here and have been trying to find out how to diagnose a problem with my new toy.
I found this (I think) lovely little unit in a charity shop and it was listed as fully tested/working.
Once home it was obvious that it had not been tested at all, upon powering the unit all seemed ok until I tried a record on it.I can hear the tunes fine if the lid is up but there is no sound going out to amp or speakers.
Now before i'm shouted at..I have read a few stickies and I tried the test with touching the wires at the bottom of the cartridge to see if there was any noise/buzzing ect but I don't get anything at all.
Before I buy a new cartridge I wanted to ask if you thought it definitely that at fault or would it be amplifier as I don't get any buzzing when touching any of the 4 wires.
Is there anything I can do to test amp ?
I am not clued up with electronics but I have tested 2 fuses (both ok) and cleaned up any contacts I can get to.
Any pointers would be greatly appreciated so I can fix this little beauty. Pics here
Thanks Ian
HuMpH57 is offline
Old 5th Apr 2015, 8:30 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Spinney srp 115 with BSR C109
If nothing happens when you touch the cartridge wires then there is probably an amplifier fault. It's not really possible to give advice on repairs given your admitted limited expertise. It's very unlikely that the cause will be something very simple like a blown fuse.
There is no point in buying a new cartridge unless you can eliminate or fix the amp fault.
paulsherwin is offline
Old 5th Apr 2015, 8:55 pm   #3
Nickthedentist
Nickthedentist's Avatar
What an odd thing - basically a radiogram with the radio omitted to save money! But it looks pretty well made for what it is, and has Elac speakers.
...but it's not impossible that a fuse that's failed of old age and vibration could cause this. Those 1.25" ones seem particularly prone to going O/C at the drop of a hat. And their end-caps look very green and corroded. Do check them (with a meter) first, or at least clean their caps with fine emery paper, before getting more involved.
It is plausible that the unit DID work OK in the shop when they tested it, and a loose connection has shown up by the time you got the unit home, although anything's possible with charity shop purchases.
As Paul says, a new cart. is NOT what you need at this stage. The current one is probably a BSR SX-something or other, which are actually reasonably reliable, as crystal cartridges go.
Nick.
Nickthedentist is offline
Old 5th Apr 2015, 9:59 pm   #4
ben
ben's Avatar
Blimey, the ends of those fuses are filthy/oxidised. Wouldn't be surprised if that were the cause of the trouble. Do as Nick says - remove and shine them up a bit.
The amp module uses germanium transistors, which are prone to failure and are getting hard to find now, but let's not jump the gun until we've eliminated the other points made so far.
Regards,
Ben.
ben is offline
Old 5th Apr 2015, 11:59 pm   #5
AC/HL
AC/HL's Avatar
Default Re: Spinney SRP115 with BSR C109
It also uses lots of Callins capacitors, always suspect.
Bill, BVWS member
AC/HL is offline
Old 6th Apr 2015, 7:23 am   #6
Nuvistor
Nuvistor's Avatar
I could not decide if they were Callins or Sprague.
Nuvistor is offline
Old 6th Apr 2015, 11:06 am   #7
paulsherwin
As Ben says, it's certainly worth cleaning and reseating those fuses. It will only take a couple of minutes and you may be lucky.
The fact that both channels are dead suggests a power supply problem, and the fuses are part of that.
Old 6th Apr 2015, 11:53 am   #8
HuMpH57
HuMpH57's Avatar
Thanks for all your replies, I really appreciate your help.
I will clean up those fuses today and update thread.
HuMpH57 is offline
Old 6th Apr 2015, 2:12 pm   #9
AC/HL
AC/HL's Avatar
I was going by the package, so could well be wrong (I often am according to SWMBO)
Bill, BVWS member
AC/HL is offline
Old 6th Apr 2015, 3:41 pm   #10
HuMpH57
HuMpH57's Avatar
Well, I cleaned up the fuses and contacts but still no luck, tested continuity on fuses and they work ok.
Is there anything else I can check or do I need to find a local repair shop ?
HuMpH57 is offline
Old 6th Apr 2015, 4:12 pm   #11
AC/HL
AC/HL's Avatar
Apologies for stating the obvious, but you did touch the metal part of the cartridge tag?
Bill, BVWS member
AC/HL is offline
Old 6th Apr 2015, 5:02 pm   #12
HuMpH57
HuMpH57's Avatar
Yes the 4 pins that the wires clip onto. I noticed there is a very small screw on the cartridge with + and - marks as if it can be adjusted, are these factory set and don't touch
I took a pic of the underside of deck where the 4 wires from the cartridge solder onto a small board
HuMpH57 is offline
Old 6th Apr 2015, 5:45 pm   #13
Nickthedentist
And have you checked that the mains plug is properly fitted?
Old 6th Apr 2015, 6:10 pm   #14
paulsherwin
Nick, the record deck is working after a fashion, so power must be getting as far as the cabinet. I agree it's important not to overlook the obvious though.
Humph, your pic shows a completely standard arrangement with no obvious faults.
Old 6th Apr 2015, 6:21 pm   #15
HuMpH57
HuMpH57's Avatar
Yea plug is fine, little video if I am allowed to attach one just to show what's happening.
HuMpH57 is offline
Old 6th Apr 2015, 6:49 pm   #16
Nuvistor
Nuvistor's Avatar
Not sure which screw you mean but there are no user adjustments on the cartridge.
Nuvistor is offline
Old 6th Apr 2015, 7:00 pm   #17
Nickthedentist
Sorry, it's been a long day
Old 6th Apr 2015, 8:16 pm   #18
HuMpH57
HuMpH57's Avatar
On top of the cartridge not the stylus side.
As I can't add video in post here is link to it, just shows what happens soundwise when playing vinyl. Here
Sorry I could not edit last post as I am still new so option does not show.
HuMpH57 is offline
Old 6th Apr 2015, 8:49 pm   #19
ben
ben's Avatar
On top of the cartridge there is a rivet, you will destroy it if you try to remove it.
The video shows that the deck's motor works as do the auto functions.
If it is not the fuses at fault , then you are unlikely to get any further with this as the amp will need looking at by someone in the know.
Regards,
Ben.
ben is offline
Old 6th Apr 2015, 9:29 pm   #20
Radio_Dave
Radio_Dave's Avatar
Where do the twisted red and white wires go?
Radio_Dave is offline
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
