Old 5th Dec 2014, 3:29 pm   #1
samoca58
Default Impex Transistors
I have just obtained a Perdio Spinney that is a rebadged PR36 Fanfare (also available in Westminster , Challenge and EAR clones).
My question is: this Spinney has Impex transistors fitted in the first 3 mixer/osc IF positions. A label in the back advises that this model can have either Impex or Mullard (OC44/5) types fitted. If you do a google search for Impex transistors there is practically nothing.
How can a manufacturer of transistors from fifty years ago just vanish from history?
Can anybody point me in the direction of data sheets?
samoca58 is offline
Old 5th Dec 2014, 4:41 pm   #2
Herald1360
Herald1360's Avatar
Default Re: Impex Transistors
Impex sounds suspiciously like a "brand" rather than a make.
Whatever they are, the characteristics for OC44/45 will be close enough.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 5th Dec 2014, 5:18 pm   #3
vidjoman
I remember Impex Transistors - Can't remember what they were labled. We were given a quantity by an equipment manufacturer to build PCB's for them. Not sure where they came from but were metal cased and we had previously used Mullard OC44's on those boards.
vidjoman is offline
Old 5th Dec 2014, 5:39 pm   #4
Cobaltblue
Cobaltblue's Avatar
A quick search and I found this at Pig Dog
Never seen this brand in the flesh as far as I remmember.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 5th Dec 2014, 5:40 pm   #5
samoca58
For the OC44 position the Impex is marked "Impex S44T" on the metal can and the OC45 positions are marked "Impex S45T" (one with orange spot the other a blue spot)
samoca58 is offline
Old 5th Dec 2014, 5:58 pm   #6
paulsherwin
paulsherwin's Avatar
'Impex' sounds suspiciously like an abbreviation of import-export so maybe they were sourced from Japan and remarked in the UK.
paulsherwin is offline
Old 5th Dec 2014, 5:59 pm   #7
G6Tanuki
G6Tanuki's Avatar
There exists a trail for a company "Philips Impex Limited" with a history going back to 1939.
Given the historical incestuous bond between Philips and Mullard, it doesn't take much to hypothesize that "IMPEX" was an IMPort-EXport division of the company?
[exit left thinking of James Bond and http://jamesbond.wikia.com/wiki/Universal_Exports ]
G6Tanuki is offline
Old 5th Dec 2014, 6:02 pm   #8
samoca58
Import export - Interesting idea .
Name:	IMG_0978 (800x536).jpg
ID:	101153   Click image for larger version
Name:	IMG_0976 (800x600).jpg
samoca58 is offline
Old 5th Dec 2014, 6:09 pm   #9
m0cemdave
I have an S31T and an S30T here, unused. They are in metal OC72 type cans. Interestingly, careful inspection reveals Mullard markings that have been mostly rubbed off, although I can't make out the original type numbers.
m0cemdave is offline
Old 5th Dec 2014, 11:41 pm   #10
AC/HL
AC/HL's Avatar
I've always understood Impex to be a Mullard/Philips brand, although why they needed another I don't know.
AC/HL is offline
Copyright ©2000 - 2026, vBulletin Solutions, Inc.
Copyright ©2002 - 2026, Paul Stenning.
