Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
#1 |
As Analogue outputs start to disappear from domestic HD TV equipment in time it's going to become difficult to feed an Aurora (and therefore a vintage TV) from any modern sources having only HDMI outputs. Therefore I recently purchased the eSynic 1080P HDMI Digital Signal to AV Composite converter.
http://www.amazon.co.uk/eSynic-Digit...pr_product_top Which takes in HDMI, downscales it as necessary and outputs 576i (625 line PAL) Analogue. As a side function it also seems to convert 60Hz frame rates to 50Hz allowing playback of US DVDs on the basic Aurora. However the motion is a little jerky when doing this. Source may still need a 4:3 setting in its menu to avoid wrong aspect ratio. One of my devices needed this set, another gave the correct result even when set to 16:9! I guess it also won't be long before the 4:3 display setting disappears from menus as well. Audio is quieter than with a standard source and the Aurora audio gain pot may need to be increased. I don't know if it will ever be possible to build a proper HDMI in, 405 out Aurora as HDMI is a bit of an exclusive club with high entry costs. But this is a useful halfway house, it also allows 'vintage' 625 set to be driven from HDMI sources. Regards, Paul |
#2 |
That looks quite a handy device, I wonder what my TV22 will make of a Sony PS3?!
Regards, Lloyd. |
#3 |
That would certainly be a handy device to have around the workshop. Thanks for the tip.
Thanks, Peter |
#4 |
#5 |
Thanks for that link. Given that my separate digibox has recently died, that would be very useful if it allows me to use the HDMI output of my digital television to feed into my (analogue) DVD recorder and to rebroadcast a digitally received broadcast to the analogue "slave" TVs around my house. Worth investing £20 in, anyway.
#6 | |
![]() Quote:
I have recently upgraded my PVR to an HD Youview box, luckily it still has a Scart socket for analogue output. I have a couple of PVR's dedicated to my vintage TV collection, these have many classic programmes and films on them, and of course will give live freeview output. I wonder how long it will be until standard definition freeview is phased out? ![]() Mark |
#7 |
Slightly O/T. I have a situation where the video signal goes through an Aurora, but the sound is direct. Naturally, the sound arrives early. Is there a (reasonably priced) in-line device to delay the sound?
I suppose I could make something from a discarded cassette recorder. |
#9 |
A quick Google of "lip sync corrector" came up with various offerings in the UK priced between about £52 and £70.
#10 |
Thanks, that looks like the answer. I knew I should've kept my Copycat.
#11 | |
![]() Quote:
Also even if people buy a HD capable receiver for their main living area they are still likely to have SD receivers in other rooms.
Classic TV Show Theme Tunes |
#12 |
Lip-Sync corrector arrived today. Instant cure for all ills; thanks again.
#13 | |
![]() Quote:
#14 |
#15 |
I noticed that Film 4+1 on Freeview has a message saying it wont be available after the end of this month on SD boxes but will still be available on HD boxes ( in standard definition!) so possibly we may need a converter device such as this not too far in the future if other channels do the same? |
#16 |
I have an HDMI to scart box (ViewHD branded). It outputs composite 576i 50hz, as well as left and right audio. Unfortunately no RGB however, and I haven't found any which do that yet. Until RGB ones are available, the highest quality picture won't be available - and it's difficult to say how much of the loss of definition is down to the HDMI to analogue conversion, or just from the composite signal itself. Still, it's a functional device that does a lot and mostly does it well. The picture and sound are in sync, colours are good, and generally the picture is ok. Text and fine lines suffer a bit however.
You can supply it with various resolutions from devices, but where possible, 720p is better than 1080p I think. Thin horizontal lines can flicker on the higher resolution. I'm pleased enough with it for the price, but I do know HD to analogue can be done with excellent results. My Humax YouView box downscales all the HD freeview channels and on demand content to PAL, RGB scart output, and it looks great on my set. Based on this, I expect the next generation of HDMI to analogue converters may be better. Last edited by Okto1984; 26th Dec 2014 at 4:16 pm. |
