Reply
Old 5th Dec 2015, 8:47 am   #21
Phil G4SPZ
Phil G4SPZ's Avatar
Default Re: Battery case links and scans.
It's a bit expensive though, Sam, at 14 per 200 grams:
http://dentala2z.co.uk/PRE10043
(Other brands and suppliers are available)
Phil (BVWS / BVTVWM / NVM / GQRPC 2101)
Optimist [n]: Someone who is not aware of the full facts
Phil G4SPZ is offline   Reply With Quote
Old 5th Dec 2015, 8:50 am   #22
Boater Sam
Boater Sam's Avatar
Wow! so dear? Time to befriend a dental techy.
I used it many years ago but wasn't paying for it. There is the advantage that it can be removed easily.
Boater Sam.
BVWS Member
Boater Sam is online now   Reply With Quote
Old 8th Feb 2016, 12:44 pm   #23
Phil G4SPZ
Phil G4SPZ's Avatar
Mallory TR-115R 6.75 volt mercury battery case scan attached.
This is a small cylindrical battery used in some 1960s test equipment, and I'm trying to replicate it using modern available button cells. As the filename states, to print this image reduce the size to 20%. The overall size of the finished battery should be 16.7mm diameter by 35.5mm long, including the domed cap at the negative end.
Phil
Name:	Mallory TR-115R print at 20%.jpg
Old 14th Jan 2018, 9:09 pm   #24
David G4EBT
David G4EBT's Avatar
Hope these for the PP8 6V battery are OK.
(If the thumbnail is opened, and the opened picture is copied and saved, it should come out the correct size, as stated on the side tabs of each picture - 257 mm full length).
ID:	155489   Click image for larger version
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline   Reply With Quote
Old 14th Jan 2018, 11:51 pm   #25
ThePillenwerfer
ThePillenwerfer's Avatar
Newer style PP8.
"Experts are only good at one thing: explaining why something will not work!"
ThePillenwerfer is offline   Reply With Quote
Old 15th Jan 2018, 12:43 am   #26
ThePillenwerfer
U2, aka SP2, HP2, D.
Reply
