25th Aug 2014, 12:15 pm | #1 |
How to type Symbols (eg ohms)
Split from this thread: https://www.vintage-radio.net/forum/...d.php?t=108783
(Incidentally, how do I type the omega symbol on the forum? [alt 234] doesn't work.) Last edited by AC/HL; 26th Aug 2014 at 10:42 pm. Reason: Thread split |
25th Aug 2014, 3:21 pm | #2 |
Re: Unusual resistors?
I wouldn't bother, ohm spelt out always works, some fonts have something different, and ohm is one less key press than alt 234 !
25th Aug 2014, 9:18 pm | #3 |
According to my ancient MS-DOS manual, to use the <ALT> 234 method of typing Ω, the numbers must be entered using the numeric keypad. You will need to press the <NUM LOCK> key if the numeric keypad is not active. This holds true on my XP Laptop, where the numeric keypad lies within the QWERTY keys, but I usually use it with a seperate keyboard when at home. The code for µ is <ALT> 230.
26th Aug 2014, 12:54 pm | #4 |
Ω µ
Thanks for that! Much quicker than copy/paste from a WP. Or you can just use R as in 100R, 4R7 etc.
26th Aug 2014, 1:08 pm | #5 |
Tried that already. Caps lock using numerical keypad:
[alt 234] = Û ( U with ^ above it on my screen) [alt 230] µ (yes!) Ian |
26th Aug 2014, 1:32 pm | #6 |
[Alt 234] = Û corrresponds with the "Multilingual (Latin 1)" character set (code page 850). You need to change to the "United States" character set (437). Not sure how to do this under Windows. Under MS-DOS it involves using the "chcp" command.
26th Aug 2014, 1:42 pm | #7 | |
26th Aug 2014, 6:06 pm | #8 |
This alternate character set problem tripped me up a few years back. I was then using Windows 2000 - and still am! I recall that a tweak of the registry was required. On this PC, Alt-234 gives Ω; Alt-251 gives √; Alt 171 gives ½. There are other differences too. If I recall correctly, these symbols are not displayed using the Num. Lock - Alt. sequence with the standard installation of Windows 2000 and Windows XP. (Can't vouch for later Windows systems).
Al. |
26th Aug 2014, 7:44 pm | #9 | |
Not everyone's using Microsoft. Not everyone's using a UK/US-English native codepage or preferred local display rendition. If you do want to use inline non-standard symbols it's far better that you should use two-byte Unicode: most browsers [and associated text-to-speech programs used by those with visual impairments] make a decent attempt at rendering these. |
26th Aug 2014, 11:15 pm | #10 |
Re: How to type Symbols (eg ohms)
I just go to RUN and enter charmap. Lots of other interesting things there too like:-
∑ √ ⅞ ۞ ♫ ☺ Just SELECT and COPY
26th Aug 2014, 11:35 pm | #11 |
I think I may have an answer to the [Alt] 234 = Û question.
Firstly, my OS is Windows XP, and my browser is Chrome. I had thought I had reset all the language options to "English (United Kingdom)" when I first got my laptop, but delving around in the "Regional and Language Settings" tab in the Control Panel, I found that, under the "Advanced" tab, the language was still "English (United States)". I changed this to "English (United Kingdom)" and restarted as instructed. I then found that, on entering the forum, I now got [Alt] 234 = Û ! I went back to the Control Panel, selected the "Regional and Language Settings", reset the language under the Advanced" tab to "English (United States)", restarted as instructed, and on re-entering the forum, found that [ALT] 234 = Ω was restored. I have attached a screen shot of the control panel menu, and two pages from the 1994 MS-DOS manual showing the characters that can be generated by the [ALT] XXX method with the United States [437] and Multilingual (Latin 1) [850] character sets. According to the options in the "Advanced" menu, the 8 character sets of 1994 have been greatly expanded, but the original sets have retained their original numbering. Last edited by emeritus; 26th Aug 2014 at 11:50 pm. |
27th Aug 2014, 10:44 am | #12 | ||
Moreover, this site is a web-based forum and I have just displayed some of those Alt chars., produced by the method I have explained. So, did you receive, read and understand them? Anyone else have a problem with them? Al. |
27th Aug 2014, 3:56 pm | #13 |
alt-z types Ω on a Mac
alt-m types µ
28th Aug 2014, 3:13 pm | #14 |
In Linux, use the "Alt Gr" key to get various symbols: altgr+Q gives you Ω, altgr + m gives you µ, altgr + ( gives you ±. There are others, of course .....
28th Aug 2014, 3:29 pm | #15 |
They only give a code for a symbol, what that is rather depends on what is decoding it. Unicode is consistent, the rest are not. I will stick to ohms (or R) etc..
24th Sep 2014, 6:38 pm | #16 |
To get a consistent encoding on websites, it is also possible to get these characters by using the HTML special character code. For example, Ω for omega or µ/μ for micro. The code needs to be followed by a semicolon ';'. The text editor here and on other forums converts them automatically to the correct character.
Ω: Ω µ: µ μ: μ A browser search for 'html character codes' will find you more codes. The 'R' notation seems the simplest though! Last edited by WaveyDipole; 24th Sep 2014 at 7:05 pm. |
24th Sep 2014, 8:14 pm | #17 | |
Someone whose browser-locale-defined character-set is, say, Hebrew, is likely to see a rendition entirely different to what you may think you have typed. [I speak from a decade or so's exchanging documents with techies from one of the world's largest firewall/network-security-providers who are based in Tel Aviv]. |
