| Vintage Test Gear and Workshop Equipment For discussions about vintage test gear and workshop equipment such as coil winders. |
#1 |
Looking for service info please. Control PCB marked KHD 125-SS issue 1 7/84
Have no output, not too complicated, but circuit would make life easier 0 to 150 volt 0 to 300mA |
#2 |
Pictures if they help.
#3 |
No idea if this will be any help, but the unit looks similar to yours.
#4 |
Yes, somewhat the same. May help. Pity there is no parts list, but certainly a help.
Cheers. |
#5 |
Also found early version of V series without op amp but includes parts list. Between the two should help me more.
#6 |
Mine is now fixed using the circuit uploaded by Herald1360
As there was no parts list I have made a part one from my unit Version 15A03 With PCB marked KHD 125-SS issue 1 7/84 VT3/4/5 BC108 VT8 BCY70 I USED 2N2907A VT9 BFY51 MR1 1N4005 MR2 BRIDGE OF 4 1N4005 MR3 9V1 MR4 1N823 (6.2V) MR5 9V1 MR6 3V3 MR7 1N4003 MR10 1N4003 MR9 5V1 MR11 1N4003 MR12 IS MADE OF 3 ZENERS IN SERIES 1 X 43V 1N5367 AND 2 X56V 1N5370 ALL 5W 0A1 OP AMP 741 RV2 50K POT VOLTAGE O/P COURSE RV3 1K POT VOLTAGE O/P FINE C4/8/9 10n 250V DC C11 100n 250V DC C7 100p 630V DC C3 4u7 160V C1 150u 63V I USED 220u C6 100u 10V In mine the zeners MR12 had scorched the PCB but measured ok I replaced all 3 also MR4 /R12 47 ohms /RV3 /VT8 and the 3 electrolytics C1/3/6 |
