Old 19th May 2011, 7:57 pm   #1
dustymott
Default French Socotel S63 PTT
Can anyone help me convert my French phone. I've been on British Telephones but there no photo's or diagrams to help a complete novice like me.
Regards Dustymott
dustymott is offline
Old 19th May 2011, 8:00 pm   #2
Station X
Station X's Avatar
Default Re: French Socotel S63 PTT
Is there a diagram somewhere inside? If so please post it here.
Graham. Forum Moderator
Station X is offline
Old 20th May 2011, 8:38 am   #3
Jim_746
Jim_746's Avatar
From http://www.britishtelephones.com/pstconv1.htm
Socotel S63 (French PTT)
The terminal strips number from right to left. The top terminals are even numbers and the terminals nearest the edge of the circuit board are odd numbers.
1. Remove the metal link T11 / T17
2. Connect a 3.3k resistor to T11 and T17.
3. Red of line cord to T11.
4. White of line cord to T13.
5. Blue of line cord to T15.
6. Insulate the green wire of the line cord.
7. Try the configuration above and if the bells do not work correctly then cut one of the leads of the 760 ohm resistor. As the resistor forms part of the anti spark quench circuit then it should really be left in situ.
"And what on earth are you going to do with that?"
Jim_746 is offline
Old 20th May 2011, 3:00 pm   #4
dustymott
Hi there, thanks for your reply. I've taken the cover off and have numbers 1-8 and 10. The hand set is connected to 1-4.
Regards Dustymott
Old 20th May 2011, 3:12 pm   #5
dustymott
Hi again, markings inside the case PTT 76 and not S63, 76 also on the base.
Regards Dustymott
