Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
25th Jun 2010, 10:55 am | #1 |
Aurora and Amp Distribution
Hi after reading the "Aerial isolater safety" thread it re-kindled a question I had been mulling over. Rather than taking that thread OT, I will raise it here.
I currently supply a signal from my Aurora to 4 sets via a 4-way splitter, this does not have any earthing protection for the Aurora. The signal is very strong but the sets cope. I would like to gear up the Aurora to supply 7+ simultaneously as the collection grows. I would like like solve the two issues with one solution and a dist amp would seem to do this (multi sets and earth protection for Aurora). Q1 I thought fitting a dist amp will over load the signal especially if I just swap out the 4way splitter for an amp with my current setup. Q2 would there be a benefit from getting a dist a with variable gain control to back off the signal strength when only a few sets are connected. Any advice or amp recommendation would be most welcome. Chris |
25th Jun 2010, 11:16 am | #2 | |
Re: Aurora and Amp Distribution
The main problem with a distribution amp is finding one that goes all the way down to channel B1. Most don't. You really don't want an amp rolling off over the channel. I leave it to others to make recommendations here.
Signal strength isn't usually a problem. Most sets are pretty tolerant. You can use the ordinary 6dB and 12dB attenuators (I hope these are still available) as required. If you still have plenty of signal after a 4 way passive split then just do further passive splitting. Multiple output distribution amps don't usually give much net gain - they do what it says on the box - distribution. Internally they have enough gain to overcome the splitter losses plus a bit for presumed cable losses. Quote:
25th Jun 2010, 11:37 am | #3 |
Hi Chris,
I use an SLX 8 way dist amp, it has a UHF input and also a VHF input that is designed for FM presumably, You have to be careful though as there are two types, one has a blue power LED and the other, a red one. I don't know what the internal differences are but I know that only the type with the red power LED works on VHF TV signals. I use one of these because I have a collection of working 625 colour, 405/625 colour dual standard 405/625 B&W and 405 only sets. I simultaneously feed UHF and VHF (straight from the Aurora) into the amps inputs and it works very well at both standards simultaneously with no cross interference. I don't have signal overloading problems either. Hope this helps. Cheers
Lee |
25th Jun 2010, 2:59 pm | #4 |
Hi Guys
I have got two of these http://www.tlc-direct.co.uk/Products/MXSLX8G.html I find that in spite of what they say they work very well on channel 1 . I go from two auroras via a diplexer into a passive splitter which feeds my monitor ( sony 9 90ub) and 2 dist amps and all works perfectly , if anybody ever in the area , more than welcome to have a look cheers Peter |
25th Jun 2010, 5:58 pm | #5 |
If anyone is up my way and wants to check their aerial distribution amp I can whack it on my network analyser and measure the frequency response from as low as you like up to 500MHz.
25th Jun 2010, 6:28 pm | #6 |
Hi.
I use two dist amps here with 4 actve channels. One is an old antiference Xtra Set6/32 with 6 normal outs and one high o/p, One of the norma o/p's feed into a modern Wolsey with seperate UHF & VHF inputs, I have no problems with the four channels I use (1,2,9,& 13) no cross mod etc and I believe that the spec on the wolsey is minimum of 56mhz I also split the high o/p from the antiference 4 ways so I have a total of 14 outs!
