Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
27th Nov 2003, 11:35 pm | #1 |
cheap standards converters
I used an old sony cammera which used transistors and not ics as transistor types are more easily tweaked about!.
the cammera used A conventonal line oscilator curcuit. That turned down to 405 whith the aid of A screwdriver. I had to adjust the line shift to get the image right. The cammera isnt locked to A sync generator so seems quite happy. I also built A video amp stage to change the video negative !. Im using A normal portable tv as the source monitor. The setup isnt ideal but was all that was available at the time . I believe the pye linx cammeras are easily converted. If not already 405 . Does anyone know of any other cammeras suitable for conversion to 405 ? thay would have to be discrete construction ( no ics in the timebase ). |
6th Dec 2003, 3:56 pm | #2 |
Re: Cheap standards converters
The Pye Lynx is a good bet, a lot of then are dual standard, but check before you buy! They used to be very common at UK radio rallies, so you may want to try an advert in the amateur radio press.
Jim. |
6th Dec 2003, 7:58 pm | #3 |
Hallo Danny, I modified my Sony AVC-3250CE for
DUAL STANDARD, also the viewfinder. I also builded a scan converter with delay lines used in drop out compensators of vcr's. This analog method is much easyer than digital converters and the IC's are avalibel. Greetings from Germany, Darius |
8th Dec 2003, 9:09 am | #4 |
I would like to congratulate Darius on building an analogue standards converter. In my article in BVWS Bulletin 27/3 I dismissed analogue standards conversion in a few words as an impractical option. I know it's technically feasible using the original BBC switched capacitor method but that is massively complex. CCD delay lines, as used a few timebase correctors many years ago would also do the job. I had not thought of using VCR DOC bits.
