15th Dec 2019, 8:47 pm | #1 |
Garrard 401 transport advice
Hi, I have just bought a Garrard 401, which I will collect by car. Does anyone have any advice regarding transport? Removing platter? Does this model have immobilizer screws? Anything else I need to consider?
Many thanks from Bill. |
15th Dec 2019, 8:59 pm | #2 |
Re: Garrard 401 transport advice
There are two red screws which lock the motor suspension. You need to take the platter off to do this - hold it up and tap the spindle with a block of wood to break the taper. Having done this, you might just as well transport the two halves separately, suitably wrapped.
15th Dec 2019, 9:07 pm | #3 |
Absolutely agree. Transport with the platter off and the motor suspension screwed down. Now mine was bought from the original owner, and for some reason was missing the motor clamp. But careful driving got it home safely.
A superb deck. Mine is now mounted in a Peak HiFi plinth with an SMEIV arm and is a source of joy. They had a reputation for rumble, but that is just because they were mounted in flimsy chipboard plinths. Given a high mass plinth they are absolutely silent with no discernible rumble at all. |
15th Dec 2019, 9:29 pm | #4 |
Thanks guys, I appreciate your help.
Bill. |
15th Dec 2019, 9:54 pm | #5 |
When you say " high mass plinth" are we talking hardwood or one of these marble or concrete creations you see?
Cheers from Bill. |
15th Dec 2019, 10:40 pm | #6 |
Hardwood works but barely!!! I made my own slate plinth it weighs in at around 30 kilos,
that's WITH the cutout for the deck and the SME3009 arm. I made mine 500 mm square just to add some weight. BUT as stated, its silent. Rumble can also be caused by a worn idler wheel bearing, which fetch stupid prices unfortunately. Joe |
16th Dec 2019, 12:13 am | #7 |
Not marble - too high Q. Slate is good. As are composites like Corian, or super-dense plywoods like Panzerholz. Anything that is high density, heavy and dead.
The Peak hifi ones use a Quartz conglomerate https://www.peakhifi.co.uk/cgi-bin/e...uct&db_pid=774 |
16th Dec 2019, 6:49 am | #8 |
I have a spare if you want it. FREE, but freight is your responsibility!
This one is much lighter as the slate is only 37.5 mm ( 1 1/2" ) thick. Surrounding timber is New Guinea Rosewood, fairly rare even here in Australia. Weighs 18.5 kilograms. This is similar to my first effort, and works the same as my double thickness version. Corner joints are not so flash mitred mortice and tenon pins. It WON'T break easily. It needs finishing, T- nuts, spikes, a base if required, (I dont use a base, as it keeps the motor cool, BUT I live in 35 degree plus temperatures) plus it needs the arm/base cutout. It's Christmas!! (bah humbug) Enjoy Joe |
16th Dec 2019, 8:39 am | #9 |
I cast a concrete plinth for my 301, I understand that concrete is rather higher in Q but I was very happy with the results.
Peter |
16th Dec 2019, 1:38 pm | #10 |
Thanks for the replies. Joe, that is an amazingly kind offer, but I don't think I have the skills to complete the plinth. Thank you so much for the offer though, I really appreciate it.
Regards from Bill. |
16th Dec 2019, 5:56 pm | #11 | |
I think if I was starting from scratch rather than the Peak hifi one I have already, I think I would seriously consider Panzerholz. But I have woodworking skills so that is not as mad as it at first seems. Craig |
16th Dec 2019, 6:45 pm | #12 |
Craig, those Peak Hifi plinths are nice! I worry about hanging over 38 kg of slate off my red brick walls. The wood ones look nice, but they are only birch ply.
What do you guys think? Cheers from Bill. |
16th Dec 2019, 7:16 pm | #13 |
this guy from facebook makes a good looking one https://www.facebook.com/search/top/...epa=SEARCH_BOX
Any tool can be used as a hammer but a screwdriver makes the best chisel |
16th Dec 2019, 8:08 pm | #14 |
Thanks, they look cool. I like the gloss.
Bill. |
16th Dec 2019, 8:56 pm | #15 |
Oh,smeg it that quartz model from Peak Hifi is gorgeous, and it's nearly Christmas. Let the Poverty begin!
Bill |
16th Dec 2019, 9:48 pm | #16 |
My 301 had been slung in a cardboard box some time in the 1970s, before i got my hands on it 30 to 40 years later. It cleaned up a treat and after fettling works beautifully. It was missing its transport screws so I replaced the springs the motor hangs off just in case. Luckily these are well built and made to be repaired.
I put mine in a plywood plinth and then a slate one, a bit of an old snooker table I think. Hope you enjoy your 401 just as much. Glyn |
16th Dec 2019, 9:58 pm | #17 |
Thanks Glyn, I fetch it home on Sunday. It has an sme 3009 S2 (with removable head -shell). Quite a combo, I hope you'll agree! I am ridiculously excited it has to be said.
Bill. |
16th Dec 2019, 10:40 pm | #18 |
I did (try and ) post pics, but apparently they didnt upload.
By finish, Bufo Bill, all it needs is the timber needs a sand and a rub with some beeswax furniture polish. ( or similar ) Three holes need be drilled for spikes to be fitted ( for accurate levelling ) These would normally be fitted into T nuts ( otherwise known as threaded inserts ) and a hole or holes need be drilled for your tone arm. Although its quite hard, slate is fairly easy to drill using tungsten tipped drills and a holesaw for the arm. It can be cut and filed with ordinary steel hacksaw blades and files. The files seem to last but the hacksaw blade will probably be dead afterwards, but they are cheap. Now!!! try pics again. If Bufo Bill doesnt want it, and somebody else does, its yours free but you pay freight. Im guessing, but after sending 20 kilos of transformers to Andy I know it will cost around 100 quid. Joe |
17th Dec 2019, 9:30 pm | #19 |
Sorry Joe, I pushed the button on one from Peak Hifi last night. Someone will step in now I am sure though, it's a real beauty and a real bargain.
Thanks again from Bill. |
17th Dec 2019, 11:27 pm | #20 |
Since you're clearly investing quite heavily in the 401 Bill, I'm just wondering whether or not you have a cartridge in mind for use in the SME?
Alan |
