15th Dec 2019, 2:08 pm | #1 |
Where does this spring go?
I have been dealing with a Philips EL3534A/OOA stereo four track, four speed, transistorised (and very heavy!) tape recorder. It is very complicated mechanically, and built like the proverbial brick outhouse. Well, it IS a Philips! I have been dismantling it to clean and re-grease the myriad levers, etc. and, couple of days ago, I worked on the speed change mechanism which has a spring to pull the jockey wheel assembly upwards. Whilst taking it to bits, said spring fell out without me noticing. I can see where the bottom end goes, but I'm blowed if I can see the top anchorage. I THINK it fastens to a mall hole in the lever which holds the detent roller, and it works, but it slightly fouls the cam when turned to the faster speed. I hope the photos help. Thanks in advance' Cheers, Pete.
