2nd May 2019, 7:24 am | #1 |
Telephone number circular labels?
Having recently inherited a working 746 telephone I'd like to replace the current hand-made paper disc in the centre of the dial with a "proper" label and was wondering if anyone has, or knows of, a piece of software to print your own? Thanks Roger |
2nd May 2019, 8:09 am | #2 |
Re: Telephone number circular labels?
A bit of Googling and I found this, and it works fine:-
http://going-digital.github.io/telephone-dial/ Thanks, mods please close topic. Roger |
2nd May 2019, 10:29 am | #3 |
I found this.
I did a blue peter job on one, printed it, printed some text, stuck the text on, then scanned the lot in and printed it http://www.telephonesuk.co.uk/dial_labels.htm |
2nd May 2019, 7:51 pm | #4 |
More About Telephone Labels
In belated response to Roger's post, here's a tip which adds authenticity to telephone labelling, and has been well-documented elsewhere.
Instead of printing the label on new A4 paper, use instead a blank sheet cut out of an old paperback (there's usually a blank sheet at the front or back) to give it that 'aged' look. Obviously some paperbacks go yellower than others so you'll need to choose accordingly.
Regds, Russell W. B. G4YLI. |
2nd May 2019, 8:27 pm | #5 |
For a really authentic look you need a GPO number stamp as well. Unfortunately they seem to sell for quite a price these days. I always think it's worth finding out the appropriate historic exchange name for the particular location and using the correct number of digits for the period. Sadly I can become quite fussy about such things!
Alan |
2nd May 2019, 8:41 pm | #6 |
Cold tea (without milk!) is another way of making paper/card look older.
2nd May 2019, 11:13 pm | #7 | |
If anyone wants to know about a particular exchange on a particular date, I have a huge database of details of exchanges back to the year dot - just PM me if you'd like details such as the ranges of numbers in use around a particular date on a particular exchange. I just produce my labels using a DTP program - got lots of blank label templates so just a case of dropping the exchange name in. I print them on an 'off white' 160gsm card - I used to use the weak tea method but the 'off white' looks pretty like the originals compared with ones printed on 'modern' white card. |
2nd May 2019, 11:26 pm | #8 |
The blank labels I use are available here: http://joefreeman.weebly.com/dial-labels.html
11th May 2019, 4:14 pm | #9 |
About 5 years ago I purchased a PDF label generator from eBay. It had templates for 200, 300 and 700 series labels and the results were pretty good - pre-soiled too! The seller is still active, but not selling this item at the moment.
