Old 8th Mar 2019, 5:16 pm   #21
AC/HL
AC/HL's Avatar
Default Re: External telephone line junction box.
It would seem to depend on the difference between a fault and damage once the line enters your property, not necessarily at the master socket. Post 1 would have been chargeable: http://bt.custhelp.com/app/answers/d...ervice-charges
AC/HL is offline
Old 8th Mar 2019, 8:38 pm   #22
qazxsw123
I remember going on the 10ft poles to do the open wire tensioning training freezing day in December with white frost on the poles and wires, also the aerial joint to drop wire on full hight poles in a large metal building. I think it was the apprentice A course.
qazxsw123 is offline
Old 8th Mar 2019, 11:54 pm   #23
Oldcodger
Graham, you conjure up visions of open wire to house ( AKA Subs premises) , with insulators 16 ( from memory ) fitted on the house, to allow for the open wire to be joined to a flat copper wire leader to the "protector" ( with line fuses & carbon protectors, fitted with a protective earth) . Most dropwire in this era were copper coated cadmium or steel. But for those thinking of using what is known as "jelly crimps", I know from experience and old anecdotal evidence from old maintenance contacts that what happens with these is that the connection remains protected, but corrosion forms on the outer of the crimp and HR occur. Saying that I've come across many a Krone strip hidden in /under lead cladding where there's been no problems with damp.
Oldcodger is offline
Old 9th Mar 2019, 10:13 pm   #24
Graham G3ZVT
Graham G3ZVT's Avatar
I didn't know that open-wire pairs were made of cadmium.
I do occasionally see bits of it in rural areas, and it's not inconceivable that some may still be in use on private land.
How much of a danger did it pose to those who worked with it?
Graham.
G3ZVT
Graham G3ZVT is offline
Old 9th Mar 2019, 10:24 pm   #25
Station X
Station X's Avatar
"Copper" as used for catenary wire etc. is actually an alloy of copper and cadmium. Pure cadmium is not used.
Graham. Forum Moderator
Station X is online now
Old 10th Mar 2019, 12:18 am   #26
Oldcodger
in my day- open wire was copper, but dropwire could be either copper coated steel or cadmium. Coper to give the transmission qualities, and a steel/cadmium inner to give strength. It's almost like the transmission properties of a co ax cable. Modern day drop wire has a two pair copper system, with steel cateniary supporting the drop wire.
Old 10th Mar 2019, 12:36 am   #27
Station X
Station X's Avatar
Open wire was always a cadmium copper (cc) alloy rather than pure copper. It's much springier than pure copper and doesn't work harden and break so easily.
The use of copper coated cadmium for drop wire would have been prohititedly expensive as well as unnecessary.
The comparison with a coaxial cable is invalid. A coaxial cable has two conductors, not one. I think you're referring to skin effect.
Old 10th Mar 2019, 12:53 am   #28
julie_m
When BT had to replace my old drop wire, the new stuff they used had four copper cores (white, orange, green and black) and three steel cores (all yellow). It was vandalised one night (together with everyone else's phone and TV cables; some must have gone along the whole street with a sharp knife) and subsequently repaired with gel-filled crimps inside a clip-together housing.
julie_m is offline
Old 10th Mar 2019, 3:26 pm   #29
JulietMike
JulietMike's Avatar
Graham,
What type of cable was used to connect from the drop wire to the terminal block in the premises ? I seem to remember twin core copper, rubber sheathed and cotton covered.
John
JulietMike is offline
Old 10th Mar 2019, 4:01 pm   #30
Station X
Station X's Avatar
The grey drop wire I remember was generally taken right into the premises and terminated directly on the terminal block just inside the door or window frame. Often the telephone line cord was terminated on the same terminal block.
Old 10th Mar 2019, 4:39 pm   #31
JulietMike
JulietMike's Avatar
Possibly I'm thinking of an earlier time - around the 1950's.
John
Old 10th Mar 2019, 5:35 pm   #32
Station X
Station X's Avatar
ISTR there was an earlier drop wire coloured black. Possibly it was terminated on an old style protector. Or may be 2 core flat cable was run from the drop wire to the protector. If so I don't know how the connection was made, perhaps inside an old style insulator? The whole idea of drop wire was to get rid of insulators etc. The drop wire was mechanically terminated at the pole and premises using clamps. The later ones were coarse helixes of insulated steel wire which the drop wire was wound around. The earlier versions had some kind of sliding clamp.
Old 13th Mar 2019, 11:09 pm   #33
Pellseinydd
Dropwire was introduced in early 1930's and used a small eccentric wheel known in the 'Vocabulary of Engineering Stores' as 'Clamps, Eccentric' for some reason They can still be seen around if you look ! This is a twin wheel version
but most were a single wheel. See Herbert & Proctors 'Telephony' Volume 1 pages 1159/60
The cable was one pair with cadmium copper conductors known as 'Cable, I.R.V., Braided and Compounded' - (IRV = India Rubber Vulcanised)
Three types - Black, Grey or 'PBJ'.
Only the PBJ was still in use with a sliding copper clamp with a loop around an inch across which was dropped over a spindle when I started with the GPO as a YIT in the 1950's.
Pellseinydd is offline
Old 13th Mar 2019, 11:16 pm   #34
Station X
Station X's Avatar
Thanks for that Pellseinydd.
Old 13th Mar 2019, 11:27 pm   #35
Pellseinydd
One of the junction boxes used for dropwire to internal cable is the 'Block Terminal No 16A' in grey or black, about 5cm square with no terminals - just room to house the crimped joints of the conductors. No terminals inside.
Old 19th Mar 2019, 4:15 pm   #36
JohnBG8JMB
Originally Posted by nutteronthebus View Post
I have found the gel seal in my box of bits you will need the crimps but the seal if yours for postage
Dave
Thank you
I replied to the email address in your pm but it bounced...Don't know how to do the paypal bit - can you let me know, please
JohnBG8JMB
JohnBG8JMB is offline
Old 23rd Mar 2019, 9:48 am   #37
nutteronthebus
nutteronthebus's Avatar
Hi John glad the gel box con arrived the is the roundtoit you need as well
Dave
Any tool can be used as a hammer but a screwdriver makes the best chisel
nutteronthebus is offline
Old 23rd Mar 2019, 10:04 pm   #38
qazxsw123
The standard grey drop wire was called drop wire 3, the thicker black was drop wire 4 same conductors but thicker insulation , used when the run ran through trees to give better protection from the branches rubbing against it.
Old 24th Mar 2019, 1:37 am   #39
Oldcodger
There were a few types of dropwire. One was a smaller grey type ( No 3,if memory serves), which was used with its own style clamp (colloquial term in engineer speak was "curliwurlie"). In our area, this one was removed as not suitable for the climate/locale, and DW4 used instead. Clamps were phased out somewhere in the late 60's, being replaced by spiral clamps( colloquial term in engineer speak was "curliwurlie"). I've also seen dropwire to a house, with insulators 16 at the house end used to connect a DW4 to a leader ( soft copper pair) to the protector or phone block trminal.
Old 27th Mar 2019, 7:28 pm   #40
pip5678
pip5678's Avatar
I remember the steel cored dropwire being substantial stuff when I was an apprentice on overhead maintenance, I was barely strong enough to cut it with the cutters I had, and as 'the youth' I was left to tidy up any recovered wire, this was no mean task as it had a mind of its own and did not want to be coiled up.
pip5678 is offline
