Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > General Vintage Technology > Where To Get Sets and Parts
Where To Get Sets and Parts For discussions about swapmeets, rallies, NVCF and BVWS, car boot sales, antique and charity shops, dealers, newspaper adverts, the local tip and just about any other source of equipment (other than eBay).
Old 26th Nov 2018, 6:13 pm   #1
brunel
brunel's Avatar
Default Cheap hard drives
https://cpc.farnell.com/wd/wd3200avv...3gb/dp/CS31967
The full list: https://cpc.farnell.com/search?st=re...e&utm_campaign
brunel is offline
Old 26th Nov 2018, 6:29 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Cheap hard drives
They are certainly cheap enough, but you should note that they are 'recertified' so have an uncertain history. They are likely to be fine, but you may not want to use them for anything really critical.
paulsherwin is offline
Old 26th Nov 2018, 6:45 pm   #3
MrBungle
MrBungle's Avatar
I wouldn't touch them myself. You'll find WD drives usually have a 2 or 5 year warranty depending on grade. These have 1 year. Plus they are mechanical.
A 250Gb Samsung SSD costs £55. A crucial 240Gb one costs £37. Both on Amazon. This tech is dead other than for archival and you want new, reliable drives for that!
MrBungle is offline
Old 26th Nov 2018, 6:56 pm   #4
Paul Stenning
Administrator
Paul Stenning's Avatar
I won't touch recertified drives either. In my experience the likelihood of a further failure is much higher, around 50% of the ones I have encountered in the past had failed or were showing SMART warnings.
Basically they are faulty disks that have been fixed by hiding the bad sectors or even disabling a head/platter (with the capacity reduced and model number changed if necessary), and SMART data reset to hide the history.
They are often sent out by drive manufacturers as warranty exchanges. If I ever get one it goes straight onto eBay or to CeX.
If you want mechanical drives buy them new. They aren't expensive and are much less of a gamble then these recertified ones.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is offline
Old 26th Nov 2018, 7:08 pm   #5
Yes, SSDs are getting ridiculously cheap these days.
Old 26th Nov 2018, 7:29 pm   #6
Nuvistor
Nuvistor's Avatar
I have just bought a Crucial 500GB drive for around £65 to replace the two and a half year old 250GB SSD. The new larger drive was cheaper than the old one.
The old SSD will be installed in a portable caddy for data backup..
Frank
Nuvistor is offline
Old 26th Nov 2018, 8:02 pm   #7
woodchips
Ah yes, but the SSD drives aren't actually guaranteed to last, from what I have read. Unless you use them they will slowly, years, fade and die.
A mechanical drive doesn't suffer from this, if you put it in a RAID then the whole point of that is to provide restoration if one drive fails.
My experience of mechanical drives is that they are very reliable. And the data doesn't fade with the passage of time.
woodchips is offline
Old 26th Nov 2018, 8:23 pm   #8
Nuvistor
Nuvistor's Avatar
Both types have their problems, choose the type that suits your usage. SSD’s tend to be faster than standard PC HDD’s, that may not be the same for the 10,000 and 15,000rpm server drives. HDD’s are usually less expensive for very large capacities.
If the data is important I would not want to leave either a SDD or HDD on the shelf for years and be certain of it working.
Frank
Nuvistor is offline
Old 26th Nov 2018, 9:21 pm   #9
MrBungle
MrBungle's Avatar
Decent SSDs are way more reliable. Orders of magnitude. And when they do fail they fail slowly and predictably with reallocations and lifespan metrics falling rather than “clunk and the data is gone”.
Genuine desktop usage write lifespan is around 300 years. Retention is 10 years+. And that’s just the crap drives.
I say this from experience as we replaced all of our spinning rust with SSDs over the last two years across servers and desktops totalling 500 odd drives. I haven’t heard of a single failure yet.
Really the only reason they sell mechanical disks now is price/Gb is still better. That’s the only metric and that’s rapidly disappearing.
MrBungle is offline
Old 26th Nov 2018, 9:34 pm   #10
I opened my latest 500Gb SSD*, a pcb about 2x1 inches, four large memory chips and a smaller one, I guess 4Tb would fit easily. The rest was air!
*It's what one does with a new bit of kit, buy, take apart, reassemble, turn on, use and then read the manual.
Old 26th Nov 2018, 9:59 pm   #11
MrBungle
MrBungle's Avatar
First thing I did when I got mine as well, although I never read the manual
MrBungle is offline
Old 26th Nov 2018, 10:35 pm   #12
Reading the manual post operation is a handy parity check.
Old 26th Nov 2018, 10:47 pm   #13
wave solder
wave solder's Avatar
I bought a few 2Tb SAS drives for what they cost for my RAID array, will see what happens with them...
wave solder is offline
Old 26th Nov 2018, 11:42 pm   #14
McMurdo
McMurdo's Avatar
can you get PATA solid state drives?
Kevin
McMurdo is offline
Old 27th Nov 2018, 12:26 am   #15
Paul JD
https://www.google.co.uk/search?source=hp&ei=dID8W8ynEozpsAe0vbqoDQ&q=pata+ ssd&btnK=Google+Search&oq=pata+ssd&gs_l=psy-ab.3..0l8j0i22i30l2.2846.13934..15826...0.0..0.88. 558.8......0....1..gws-wiz.....0..0i131j0i10.JAVYGV8PrcM
Looks like the answer is yes
Paul JD is offline
Old 27th Nov 2018, 12:31 am   #16
paulsherwin
As far as I'm aware, PATA SSDs are all NOS.
Old 27th Nov 2018, 4:21 am   #17
arjoll
arjoll's Avatar
I'd never sell either hard drive or SSD as being 100% reliable. They all fail - but I'd pick SSD over HDD. If you want reliability, then redundancy and backup are where you should be heading.
In terms of performance, I had a client with write performance issues on a RAID10 15k SAS HDD array. After lots of to-ing and fro-ing, I added a couple of mixed use HPE SATA enterprise SSDs in RAID1 into the mix, and moved the VM over to that. Instant improvement, even though I'd normally have never considered SATA for server use, being SSD masked the issues with things like queue depth. Server was HPE ProLiant DL360 Gen 9 with SmartArray P440ar, 2 GB FBWC - just standard stuff.
arjoll is offline
Old 27th Nov 2018, 10:10 am   #18
radioman
radioman's Avatar
Well, I was just about to order the 40Gb one of those : https://cpc.farnell.com/samsung/mp04...20hard%20drive
to fix an old laptop I've got, but now I'm not so sure..
It needs to be 2.5" and have an EIDE interface.
I've never used SSD's but they seem much more expensive and have a lower capacity.
If these CPC ones aren't a good idea, what would you suggest I do ?
Andy
radioman is offline
Old 27th Nov 2018, 10:37 am   #19
Paul Stenning
Administrator
For EIDE there isn't a lot of choice, either second hand or refurbished, and both are a gamble. Not much point in buying an SSD for such an elderly laptop, as it won't be able to run an operating system modern enough to properly support SSDs.
At least the CPC ones have a warranty (although that doesn't cover any data on the disk) and are cheap enough.
Make sure you have backups of anything important. Never rely on a single drive as the only place data is stored, regardless of type or age etc.
Paul Stenning
Old 27th Nov 2018, 10:37 am   #20
Nuvistor
Nuvistor's Avatar
For that price in an old laptop I would give it a try, how old is the laptop, the drive may out last other items in the computer.
Just have good backups.
Crossed post with Paul but the same advice.
Frank
Nuvistor is offline
