Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
18th Jan 2016, 3:25 pm | #21 |
Re: Vintage TV Help!!! 1958 Bang & Olufsen
Question! My RF modulator is for PAL tv system, wouldn´t that make it incorrect for a 1958 danish tv?
18th Jan 2016, 4:02 pm | #22 |
that is a very nice television receiver you have. From looking at the instructions that come with the modulator... it is possible to change the output spacing of the sound and vision signals . This is so the modulator is compatible with different countries. It would be worth checking which output spacing has been selected. 4.5 mhz is used in mostly the Usa the uk uses 6.0 mhz I don't actually know what standard would be required for a Danish Tv, but I would try the 5.5 mhz sound vision spacing. Another point which I don't yet know the answer to, if you change the sound vision spacing, has the modulator been made so that it also changes the channel allocation ? As I think different countries use different channel frequencies. I do have a dragonsat modulator here that does cover VHF as well as UHF, and also does the different sound vision spacings . regards Peter B |
18th Jan 2016, 4:08 pm | #23 | |
What we need to know is what TV broadcasting frequencies were used in Denmark in 1958 and the number of lines the picture had.
18th Jan 2016, 4:52 pm | #24 |
My understanding is that Denmark used the System B TV standard from the outset, so the sound vision spacing should be 5.5 MHz. I reckon that a set from that era would only cover the VHF TV bands.
18th Jan 2016, 6:43 pm | #25 |
Yes that i also belive to be true. system B
18th Jan 2016, 6:48 pm | #26 | |
Channel allocation? sound vision spacing? I do not know! he he. But I do recall having read that system B uses 5.5 MHz |
18th Jan 2016, 6:54 pm | #27 |
I can confirm that Denmark used system 'B' - 7MHz channel spacing with sound carrier at 5.5MHz - VHF channels 2 - 4 in band 1 and channels 5 - 12 in band 3 (later when additional spectrum was required UHF channels 21 - 68 were employed using system 'G' (a variant of 'B') when colour arrived it was indeed PAL and used the existing channels
18th Jan 2016, 7:07 pm | #28 |
So was does this mean? i need a modulator where I can set the channel spacing and also the sound carrier? is the channel spacing perhaps the same now as back then?
Questions from an ignorent! sorry |
18th Jan 2016, 7:37 pm | #29 |
sorry for not making my post clearer. according to the yellow page you have shown, the modulator you can be switched for several different Tv systems, and 5.5 mhz is one of the options. you would need to hold down the channel up and channel down buttons for three seconds, then the display changes from the channel number to show the sound vision spacing. then you could check it is set to 5.5 . then power the modulator off and then back on again. if it were me I would try setting the television to one of the channels where you get snow, and then changing the lower channel selected on the modulator and see if you get a picture and sound. I mean the channels 13 or below. does the television work on fm radio ? regards Peter B |
19th Jan 2016, 1:40 am | #30 |
Hi - I would disregard the sound spacing for the present - it has no relevance until you get a picture - set channel to '2' by pressing button on modulator until '02' appears on readout and set TV channel selector to '2' only valid channels are 2 - 12 (there is no ch 1 or 13) use fine tuning knob (concentric with channel selector) to peak signal
19th Jan 2016, 4:16 pm | #31 |
Sound spacing is for FM sound surely this set will be AM for the TV sound.
19th Jan 2016, 5:30 pm | #32 |
System B, which we think this set is would be FM at 5.5Mhz offset from the vision carrier.
https://en.m.wikipedia.org/wiki/Broa...vision_systems Frank |
19th Jan 2016, 8:04 pm | #33 |
I think considerable confusion has been introduced to this thread by a misunderstanding of western European TV standards and an attempt, however well meaning, to superimpose British 405 line parameters on the current issue - system 'B' used in most of western Europe including Denmark (7MHz channel spacing, neg vis modulation, FM sound spaced 5.5MHz from vision carrier - ch No.s 2 t- 4. 5 - 12) - the modulator described in post #1 is compatible with system 'B' - sorry to be so blunt but I feel that misinformation is impairing assistance to the OP - kindest regards to all, John
19th Jan 2016, 11:39 pm | #34 |
I am just entering the discussion a little late, I own the same set. Please contact a very good friend of mine from the Radiomuseum Ringsted (Bjarne). You can get there all kind of help. http://www.radiomuseum.dk/ Good luck, German Dalek
And now something completly different: MARC BOLAN, he was/is the real king of Pop Music! |
21st Jan 2016, 10:22 am | #35 |
A very interesting receiver. It has a look similar to our PYE V2 12" model from 1952/3. John.
24th Jan 2016, 9:31 pm | #36 | |
25th Jan 2016, 2:30 am | #37 |
Hi - I had bowed out of the discussion as I thought you had got assistance nearer to home but yes it should work - I would set the modulator and TV both to the same channel (I suggest only try ch 2 - 4 for a start as these are in the same band) a close-up pic of the channel selector on the TV would be useful - best of luck
25th Jan 2016, 2:26 pm | #38 |
Re post 11, Have you tried Julie's suggestion of feeding the modulator to a more modern known working analogue TV.
Once you get the modulator etc proved good you can then try it on the vintage TV. Frank |
25th Jan 2016, 11:08 pm | #39 |
Yes i did that and it works fine.
I tried the fm radio in the set and it doesn´t work, so for now I thank you all for your help. The Bang and Olufsen is going to the mechanic Hopefully it returns in good working order I will post it as soon as there is any news. Thank you all!! Ole Skov, Denmark |
25th Jan 2016, 11:15 pm | #40 |
Look forward to the news it is all working and some photos.
Frank |
