11th Jun 2015, 6:32 pm | #1 |
Fitting a BT Plug
Hi all. I have a seventies Ericofon with a Danish three prong plug. I want to fit a standard BT Plug to the original cord. I know how it should be wired up, but the wires inside the original Ericofon cord are too floppy & slightly too fat to slide into the grooves on the BT plug. I've been trying to fit it for days, reaming out the slots inside the plug, stiffening the two Ericofon wires with superglue, but to no effect. The only way I have got a signal to and from the Ericofon was to twist the wires together with the wires emerging from a BT plug flat cable. It worked, but even soldered was very weak (the Ericofon wires have just a few strands of copper wire inside) and, of course, ugly as hell.
I don't want to replace the original cord - it's a perfectly matched mint green to the phone - but I'm despairing of fitting a BT plug. Does anybody make a two part BT plug that could be fitted around the wires? Or has anyone on this forum had a similar issue and solved it? I'm despairing of ever sorting it out. Help! |
11th Jun 2015, 6:47 pm | #2 |
Re: Fitting a BT Plug
I'll tell you my way but I'll probably get lynched.
Firstly get hold of a 6-way BT plug. Cut the old line cord straight at the end then get some thin single-core wire. Cut this into bits about 5/8" long. Strip 1/4" off and push this inside one of the cores of the line cord. Do this for all three. Now lay the remaining 3/8" bits in order and work them into the plug, it makes things easier to push down the outer two contacts before hand to stop the wires getting into those slots. A 6-way plug will odds-on be big enough for you to get the round outer sheath in and under the cord clamp. After that push the remaining contacts and clamp down as normal. It works for me. - Joe Last edited by ThePillenwerfer; 11th Jun 2015 at 6:57 pm. Reason: Added Diagram. |
11th Jun 2015, 6:58 pm | #3 |
You can get rewireable BT cord plugs. They look like those double adapters but with a grommet at the bottom for the cable entry.
I can't for the life of me think where mine came from, maybe Maplin or it might even have been Exchange & Mart.
Kevin |
11th Jun 2015, 7:23 pm | #5 |
They look like handy things, Dave.
The only snag is that I've found IDC connectors and tinsel wire do not make a happy marriage. - Joe |
11th Jun 2015, 11:00 pm | #6 |
Thanks all for practical avenues to explore, but just as much for helping me feel I'm among friends. I'd reached a level of frustration that was silly and an overreaction to the actual importance of the issue (of course!), but it's great to be able to talk it through & receive some potential ways forward.
I will pursue them - but probably won't get back to you for a week as I'm heading off for a five days' camping in Wales on Saturday. Filthy weather almost a cert according to the weather forecast. Thanks again, and any other suggestions also welcome. |
12th Jun 2015, 1:04 am | #7 |
I've got a simple way of rewiring 3/5/6 way plugs. Cut the cable a good distance ( 4-6" ) from the plug. For most purposes, you only need pins 2/3/5. That's Green/ Red and white on a standard cable. Strip back the outer . Then strip back a length of the colours, but leave a bit of sheath on the wires. Twist the outer and apply flux to the wire/nylon mix, then tin. The nylon will melt leaving a tinned copper mass, to which solid/ other wires can be soldered/ and insulated and make a cable as needed.
12th Jun 2015, 7:14 am | #8 |
It can be done!
See post 6 (and the follow-ups to it, 11 & 12) here: https://www.vintage-radio.net/forum/...ad.php?t=34066 |
12th Jun 2015, 1:05 pm | #9 |
The advantage of using a 6-way plug is that the old, fat line-cords will go into them.
- Joe |
12th Jun 2015, 1:32 pm | #10 |
Never knew that, Joe. Good tip.
12th Jun 2015, 4:52 pm | #11 |
It's a pity you've already cut the Danish plug off, as adapter leads are available which would have kept the phone original.
As things are, you could use a redundant microfilter as the basis of an adapter - remove the internal components and solder the cable to the appropriate points. |
