Old 12th Dec 2019, 12:00 am   #1
19Seventy7
19Seventy7's Avatar
Default Dynatron HFC51 volume change
I have a Dynatron HFC 51, which I've had for a couple of years now, but recently I've started having issues with audio.
The audio level can suddenly change, it usually gets louder, then stay at it's louder level for a few minutes, then drop again, to a quiet level.
The left channel is also unusable as it gives a very loud distorted noise, this happens through both headphones, and the loud speakers.
I have had the distortion issue for a while now, but it was very quiet, and only noticeable with no music, but it now overpowers the music.
I did search for a diagram and found one online, but it's too much for what I can afford.
The player uses a Dynatron SA29 "chassis" (I don't know if that's the term for record players)
I guess it's something in the amplifier section?
Thanks
19Seventy7 is offline
Old 12th Dec 2019, 8:17 am   #2
qualityten
Default Re: Dynatron HFC51 volume change
Hi, this thread may help you somewhat https://www.vintage-radio.net/forum/...d.php?p=485094
qualityten is offline
Old 12th Dec 2019, 11:38 pm   #3
19Seventy7
19Seventy7's Avatar
Thank you, for linking that, i'll get to reading it now
Thanks
Old 13th Dec 2019, 12:52 pm   #4
Edward Huggins
Failure of one Channel in these is a very common problem. What is your skill level in fault finding/voltage measuring on old equipment such as this?
Edward.
Edward Huggins is online now
Old 14th Dec 2019, 12:48 am   #5
19Seventy7
19Seventy7's Avatar
I'm so-so with fault finding, I have some limited experience and know-how, with some guidance I can do it
I'm not too great at following schematics and diagrams, although.
Thanks
Old 14th Dec 2019, 2:26 pm   #6
Dodgy Geezer
I'm going to go right out on a limb here, since I am unskilled and incompetent at electronics - but I have a Sony HMK-80B which has a similar problem, and I believe it to be caused by a failing volume pot together with poor contacts at the headphone socket...
Dodgy Geezer is offline
Old 14th Dec 2019, 4:34 pm   #7
Edward Huggins
A Volume Pot does not actually "fail" enough to impair volume - but the track does get worn so that over time, the volume may become intermittent, but not necessarily reduced in amplitude.
Edward.
Old 15th Dec 2019, 5:50 pm   #8
19Seventy7
19Seventy7's Avatar
the volume changes on both channels, but the heavy distortion is from the left channel only, so it could possibly be the volume control, it's a slider and I think these had their problems, but I think the volume drops, and then raises to its normal level, so i'm not sure
Thanks
