14th Dec 2019, 12:57 am | #1 | |
Tube brighteners.
Split from this thread:-
https://www.vintage-radio.net/forum/...d.php?t=162082 Quote:
For example watching shango066's channel on Youtube it's surprising how many "brighteners" were deployed. The concept was not unknown here, although we just called them CRT heater (filament) isolation transformers to the best of my recollection, and you could work out your full career without ever encountering one. When they were used, it was more to do with eliminating severe hum due to heater/cathode leakage, than overrunning the heaters. I wonder if others agree with my assessment?
-- Graham. G3ZVT |
14th Dec 2019, 1:07 am | #2 |
Re: Tube brighteners.
Brighteners in Australia were used when the cathode had died sufficiently that the screen was quite dim. When we fitted a brightener ( that's what we called them) we advised the customer to start saving for a new tube, a regunned tube or a new TV. The "real slick" brighteners had taps that could be upped as the emission got lower and lower. We didn't have "heater cathode" shorts!!! We had a piece of figure 8 flex soldered to the heater and cathode pin of a spare tube socket. we started the set and connected one lead to chassis and the other lead was tapped a few times onto the topcap of the 6CM5 or 6DQ6 booster valve. Watching carefully we did this untill the sparkler effect stopped inside the tube. Thereafter there were no shorts. . DONT laugh!!! this was highly effective.
Joe |
14th Dec 2019, 8:04 am | #3 | |
No Longer a Member
It was possible to make a very compact "brightener" transformer for the task aided by: 1) Autotransformer design 2) High permeability core 3) 60 Hz operating frequency. So they could just fit in a small extension base on the CRT that was roughly about the same diameter and not too long. Possibly why these might have been less common in the UK, many of the sets were AC/DC series heater chain types, making it more awkward. |
14th Dec 2019, 2:40 pm | #4 |
Two methods here - one is the transformer to boost the heater voltage, giving a bit more emission from the cathode, the other which Joebog1 lists, is zapping the cathode surface with a high voltage in order to break up the cathode coating and (hopefully) get a bit more emission that way. I've used both methods many years ago with varying degrees of success, but the high voltage zap was of course cheaper and a lot more fun!
14th Dec 2019, 2:40 pm | #5 |
I have never seen one of the brightners, too young at 61, but when colour tubes started to fade we had a device the powered up the heaters +10% and then pulsed G1 and each of the RGB cathodes in turn. I think it applied +120V DC to G1 for a very short time, stripping off tired cathode material, seemed to work for a decent time afterwards.
worried about the electrons entering the circuit and the smoke leaving Andrew |
14th Dec 2019, 2:52 pm | #6 |
There used to be adverts in Television for a device, "Cathodray", or similar from memory. It fitted inline with the tube socket. Presumably just an autotransformer.
14th Dec 2019, 3:17 pm | #7 |
Boosting or blasting the CRT on a full time use telly was a bit like rearranging the deck chairs on the Titanic.
Lawrence. |
14th Dec 2019, 3:31 pm | #8 |
A CRT heater-booster would often be enough to get another year's life out of a weak tube; remember that back in the 50s and 60s a new tube (or a new telly) would have been a significant cash-cost to your average viewer.
Wasn't a tube-booster one of Clive Sinclair's first products? EDIT: Photo attached, from July 1961 Practical Wireless. Is this _the_ Clive Sinclair or someone else called Sinclair? |
14th Dec 2019, 4:17 pm | #9 |
When we were married in 1981 all we could afford was an old Philips B/W TV because it was free. It had a very dim picture so I used my old H&M train transformer to run the tube heaters rather bright for a few seconds and that did the trick, disconnected from the heater chain of course. I successfully repeated the procedure once more before we bought a second hand colour set. When we did I put the old Philips in the loft and to my shame left it there when we moved along with a KB and another. 32 years on I often think about going back to our old house in Coventry and asking if I could reclaim them........
I’ve certainly got one of the RS tube boost transformers with the percentage taps hidden away, it came from my father-in-law’s radio and TV shop. Peter |
14th Dec 2019, 10:42 pm | #10 |
I never used one myself, but I came across more than one on Finlandia colour sets. I forget which make of CRT they had, but it was a common retro fix I believe. It MAY have been because the stock heater supply was low rather than the tube itself. These were simple mains transformers with 6.3V and + 20% as I recall.
Les. Last edited by MotorBikeLes; 14th Dec 2019 at 10:43 pm. Reason: more not morte |
15th Dec 2019, 12:49 pm | #11 |
If memory serves me " R - S" used to do them
15th Dec 2019, 5:30 pm | #12 |
Wasn't it the case that late model tubes were not very successfully boosted due to the limited cathode material?
15th Dec 2019, 5:43 pm | #13 |
Yes, RS used to do the heater transformers with the normal 6.3V and an additional tap that gave 6.3 +20% as a boost. These were surprisingly cheap and I found them ideal for powering small '9V' DC power-supplies, the boosted 6.3V, when bridge-rectified using silicon diodes (OA202 etc) gave about 10V on-load, great for feeding stuff that normally devoured PP9 batteries.
16th Dec 2019, 2:27 pm | #14 |
I have a RS 4 volt CRT booster transformer,I can certainly remember my father getting a bit more life out of a Bush TV tube with one of these boosters,possibly made by Elstone. Les
16th Dec 2019, 4:15 pm | #15 |
A little more information on the Sinclair booster.
Frank |
16th Dec 2019, 4:15 pm | #16 |
That unit (post #8) looks interesting, especially as it doesn't have any power supply! I suspect it's used to lift the heaters from chassis to 'cure' a H/K leak. Can't see how it could increase the heater voltage._Edit: crossed with the above post, which says it boosts the heater voltage. I wonder how?
The Thorn 3000 series TVs had an extra 20% tap on the mains transformer. I don't think this was supposed to be used for increasing the CRT's heater voltage but it did work. Of course the transformer was the proper way to do it. More common was the extra dropper resistor (or worse) hung onto the CRT's heater pin. |
16th Dec 2019, 4:43 pm | #17 |
I suspect that the cylindrical body-part of the Sinclair booster contained an autotransformer.
17th Dec 2019, 1:01 am | #18 |
No Longer a Member
I explained in post #3 that these brightener units contain autotransformers, it is no mystery how they work. You will note though they won't work for sets that are powered from DC, that scenario practically never happened in the USA where the brighteners were super popular and part of every TV serviceman's kit.
17th Dec 2019, 10:13 am | #19 | |
Craig |
17th Dec 2019, 12:43 pm | #20 |
No Longer a Member
Not unlikely at all, the autotransformer booster at this point in history was 10 year old American technology and if he was well traveled "Uncle Clive" would have seen these on trips to America along with many other TV and Audio innovations. In those days it took about 10 years for new tech to get from the USA to the UK and about 15 to 20 years to get to the Antipodes.
