Old 21st Aug 2019, 5:32 pm   #1
Elaine Williams
Default Grundig TK 14 restoration
Hello, I have just joined this group and hope someone can help me. I have been gifted a Grundig TK 14 by the widow of an old colleague of mine. We worked together in local radio back in the 1970s and early 80s. It is in excellent condition and the fast wind and rewind work perfectly. However, although the Play button depresses it does not allow the tape I have on the machine to play. Any ideas as to how I might be able to correct this? Thanks for anyhelp you can offer.
Elaine Williams is offline
Old 21st Aug 2019, 5:46 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Grundig TK 14 restoration
It's highly likely that it needs new belts if they've not been done already.
paulsherwin is offline
Old 5th Dec 2019, 11:15 pm   #3
DMcMahon
DMcMahon's Avatar
Depends upon what you mean by Play. If the tape is not moving then make sure that the pinch roller is correctly positioned so that the tape is in firm contact with the capstan motor shaft.
If you mean no sound then could be lots of things, first make sure the playback head is clean.
DavidM
DMcMahon is offline
