11th Apr 2010, 4:47 pm | #321 |
Re: Tv62
Looking back on some of the photos, I am worried about the location of C16?
Should it go from the Red asterisk to the Green one? Les
11th Apr 2010, 4:53 pm | #322 |
Re: Tv62
already corrected that yesterday, thought nobody had spotted
But it's good that you did the reason I keep posting pics is to provide other eyes with evidence other than my own to verify, so at least it proves it works. |
11th Apr 2010, 5:00 pm | #323 |
Re: Tv62
Disconnect C13 and measure the resistance again.
If it measures around 1M then switch on and measure pin 1 volts with C13 disconnected. |
11th Apr 2010, 5:14 pm | #324 |
Re: Tv62
PJL. Won't the resistance reading on PCL83 (V3A) pin 2 to chassis depend on the setting of VR2 the Frame Speed control? It could be anything between 680K and 1.68M depending on where the control is set.
My understanding is that C13 has been changed, but it's obviously worth a check.
11th Apr 2010, 5:15 pm | #325 |
Re: Tv62
742k...
11th Apr 2010, 5:19 pm | #326 |
Re: Tv62
In that case R20 or VR2 is faulty. Try measuring each on its own. No need to snip anything. Even if the wiper of VR2 isn't touching the track it should still measure 2M.
11th Apr 2010, 5:19 pm | #327 |
Re: Tv62
Fix it...must be the pot as I think you already changed R20. If you haven't got a 2M pot then put a 1M resistor in it's place for the time being.
11th Apr 2010, 5:21 pm | #328 |
Re: Tv62
just to be clear 742K on pin 2
R20 is fine at 682K |
11th Apr 2010, 5:24 pm | #329 |
Re: Tv62
Check the reading from pin 2 with VR2 at both extremes of travel.
11th Apr 2010, 5:28 pm | #330 |
Re: Tv62
You cheated and edited your post! In which case power it up with C13 disconnected and measure PCL83 pin 1, pin 2 and pin 3 voltages.
11th Apr 2010, 5:30 pm | #331 |
Re: Tv62
probe to clipped to chassis, probe clipped to pin2 (v3 half frame osc) VR2 rotated reads 749K whatever
11th Apr 2010, 5:38 pm | #332 |
Re: Tv62
In that case VR2 is short circuit or possibly the knob isn't actually moving the wiper. If you can't fix it replace with a fixed 1M resistor for the moment.
11th Apr 2010, 5:38 pm | #333 |
Re: Tv62
Check your wiring...R20 is wired to the wrong place.
11th Apr 2010, 5:41 pm | #334 |
Re: Tv62
Chris said he can measure 768k from pin 2 to deck so it wouldn't stop the oscillator working though even if the pot was shorting. It would just result in the frame speed being wrong.
11th Apr 2010, 5:46 pm | #335 |
Re: Tv62
11th Apr 2010, 5:46 pm | #336 |
Re: Tv62
If you look at the picture, R20 is wired in parallel with C13 which would explain everything.
Edit: I can't really tell from the picture but I think this goes to pin 6 of the ECC8*. It is supposed to go to the frame speed control VR2. |
11th Apr 2010, 5:48 pm | #337 |
Re: Tv62
please please tell me where it should go
it should hit a rail going to VR2 but i cannot workout from the schematic where that pickup point is in the real |
11th Apr 2010, 5:50 pm | #338 |
Re: Tv62
Did you take any pictures before you started? I exoect it is tag 3 but you will need to follow the wire back to check it goes to VR2. Nearly fixed that fault...then on to the next
11th Apr 2010, 5:52 pm | #339 |
Re: Tv62
Maybe the tag to the right?
LOL! All you fella's spotted it while I was doing the picture Haa Haa Good Fun.
11th Apr 2010, 5:53 pm | #340 |
Re: Tv62
OK flipped back through my photo records ( thank god i take them ) tag 3 is the point
Phew. PJL Thank you, thank you, that was yesterday brain melt. TopCap as usual you are right rectifiying faults as we speak |
