Old 11th Aug 2007, 5:43 pm   #41
David Goodall
David Goodall's Avatar
Default Re: Rigonda Stereo - Reviving the beast
I've been following this tale with interest, as I was given a Rigonda Symphony a couple of years back. It does indeed look to be, as Steve P describes "Serious kit." I was mightily impressed with the 15 or so valves, and automatic tuning. How for example would the sound compare with my Sansui 500 ?
Name:	Rigonda Symphony.jpg
David Goodall
David Goodall is offline
Old 12th Aug 2007, 1:56 am   #42
Zelandeth
Zelandeth's Avatar
That's another mighty impressive looking bit of kit. Obviously a higher spec unit than the one I have, but certainly from the same family. I have to wonder what those four red indicator lights on the front panel are for.
I don't know your Sansui, but I can state that even in its currently somewhat sick state using somewhat questionable cheap 1980s speakers, sounds really rather nice. Now, if only I could get both channels to work!
You need to get that one put back the right way up, and into service David!
PS: If it's the same cabinet material as mine, with nought other than a good clean and polish you'll find that it can double up in service as a mirror!
Zelandeth is offline
Old 12th Aug 2007, 4:17 pm   #43
David Goodall
Yes, those indicator lights are a mystery. I've only just noticed the "band" control. I hope that adjusts the bandwidth as suggested, as I don't own a set with that feature. It should be fun to play around with.
As you say, It looks as though it will clean up well. Infact the varnish is so thick, I half wonder whether it was sailed here from the USSR !
I shall change the usual two caps, then test Steve's theory. It may be two out of two !
David Goodall
Old 12th Aug 2007, 5:47 pm   #44
Steve_P
Steve_P's Avatar
I've had a look at the circuit, and if the Volume and Balance Controls are on the input of the amps, then do the following:
1: Clean those switches thouroughly.
2: Clean the pots. They appear to be ganged together, but the same applies.
3: There's 2 x 47uf (I think) caps on the 1.0 pots - Change them.
4: There's the resistors and caps on the boards, linked to the pots. Check and Change.
Cheers,
Steve P
Steve_P is offline
Old 14th Aug 2007, 11:34 pm   #45
RoundyMooney
RoundyMooney's Avatar
Quote of the week!
They do resemble earlier German offerings, don't they?
Putting the smoke back into antiquated junk since 1977
RoundyMooney is offline
Old 1st Sep 2007, 6:40 am   #46
Chris55000
Hi!
If the output valves are equivalent to EL84s the official published ratings were:-
Va 250V, Vg2 250V, Ia 48mA, Ig2 5.5mA, Rk 135 ohm, gm 11.3mA/V, Ra (Optimum Anode Load) 5600 ohms, Pout, 5.7W for 10% total Harmonic Distortion.
Heater 6.3V, 760mA, Max Anode Dissipation 12W
Most manufacturers used to under-run this valve a bit to economise on HT current and keep heat down, typically at Ia 34-38mA, Ig2 4-5mA with a bias resistor of 220 ohms. In my experience this still gave very satisfactory results.
Regarding the 0.08V positive grid volts, if you've replaced the grid-couplers from the previous anode(s), you should be fine, but watch out for "hot leak" in the output valves or signs of incipent "Grid-Emission". The set will almost certainly have parallel heaters, *so if you're careful*, you can remove the output valve from its holder and switch on, using your testmeter to see if there's still any positive grid voltage at the G1 socket contact - if it has now gone the capacitor is perfect as regards leakage, and you have one of the valve faults mentioned above.
I'd suggest -3 to -4V GB is much too low for nearly all 6.3V output valves, the EL84 and its equivalents are -7.3 to -8.0V, whilst the EL41 and the pentode section of the ECL86 which have identical characteristics, are -7.0V GB.
Older types, (ECL82 and the octals etc.,) needed -11.5 to -12.5V GB.
Chris Williams
Chris55000 is offline
