Old 9th Dec 2017, 5:47 pm   #1
buggies
buggies's Avatar
Default Small (8" * 6.5") panel with dial etc
Trying to thin-out some junk and a couple of items seem telephone-related but I have no idea if they are of interest. Might just turn out to be a source of BA screws...
The panel has a red, green and white light (6v wedge lamps) two push buttons and three key switches - one "lockable".
Some labels refer to "tape"?
ID:	153662   Click image for larger version
ID:	153663   Click image for larger version
George
buggies is offline
Old 9th Dec 2017, 6:13 pm   #2
ThePillenwerfer
ThePillenwerfer's Avatar
Default Re: Small (8" * 6.5") panel with dial etc
Certainly some handy parts on it if nothing else.
Maybe it was from a location where telephone calls were recorded.
ThePillenwerfer is offline
Old 9th Dec 2017, 6:36 pm   #3
AC/HL
AC/HL's Avatar
Telex?
AC/HL is offline
Old 9th Dec 2017, 8:12 pm   #4
buggies
buggies's Avatar
Ah - that would make sense, and probably explains the other hunk of junk which contains a number of relays plus a Carpenter high speed type. Will post pictures of it tomorrow.
George
buggies is offline
Old 9th Dec 2017, 9:06 pm   #5
Originally Posted by AC/HL View Post
Telex?
Indeed. It's the "J BELL" which gives it away. Sending this character caused a bell to ring at the distant teleprinter to attract the operator's attention.
The tape would have been a punched paper tape.
Station X is offline
Old 10th Dec 2017, 5:31 pm   #6
buggies
buggies's Avatar
Duh! Now I remember - it came from an old ICI explosives factory where I occupied a building in the 70s-80s. I also acquired the associated Creed 7B and used it for several years for RTTY.
The relay unit I mentioned was in the large grey box under the desk shown halfway down this page:-
http://www.ringbell.co.uk/ukwmo/Page233.htm
ID:	153744   Click image for larger version
George
buggies is offline
Old 10th Dec 2017, 7:33 pm   #7
I remember going on a day's course on how to set up those Carpenter bipolar relays [and coming away with the relevant set of feeler- and tension-gauges].
Thankfully in the early-1980s they were replaced with sealed relays and/or solid-state flipflops [using CV7004 and CV7007 transistors].
Old 11th Dec 2017, 7:30 am   #8
russell_w_b
russell_w_b's Avatar
That relay rack is the same (but with different functionality) as those in the control section of a Marconi B6122 / BD272 HF transmitter. There were three mounted side-by-side.
And they used Carpenter relays! In the valve and HT overload circuitry. Still got some tension gauges kicking around somewhere.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline
