Old 5th May 2023, 7:19 pm   #1
BBCmicro
BBCmicro's Avatar
Default Hacker Mayflower RV20
This was is my first go at a valve set and was a little nervous.
I paid too much for it but, it was local and I couldn't say no.
I don't know what the varnish is on these sets but it was extremely resistant to attempts to remove it (third pic as received, finish was cracked, peeling and missing in places, and someone had had a go at the front panel and torn up the grain in the veneer).
A sand down and stain and a few coats of spray varnish got it looking serviceable, it'll never be perfect but it's not bad.
Suffered from a few resistors that went high when the set heated up and would cause increasing distortion until the thing was unintelligible. Worked out which ones by observing where the wax coating was running off, and by burning my finger (set powered off of course!)
Canned caps restuffed (again a first for me) after one leaked everywhere.
Electrolytics replaced and the selenium rectifier emptied and stuffed with silicon diodes.
I haven't the skill or equipment to do an alignment but it sounds fab as is. I will probably need to check resistors around magic eye as the bars do not meet in the middle.
It's rapidly usurping my Roberts R707 as my favourite radio. Hopefully it'll last, but it's got a new lease of life with me for a bit at least.
ID:	277789   Click image for larger version
ID:	277790   Click image for larger version
BBCmicro is offline
Old 5th May 2023, 8:06 pm   #2
stevehertz
stevehertz's Avatar
Default Re: Hacker Mayflower RV20
Looks nice, great job you've done there. A couple of points from me. You may not get the bars on the signal strength indicator to meet in the middle, it could just be signal level, not necessarily out of tolerance components. On my set I found the sound lacked bass, and I'm not the first person to comment on this. In this thread I describe a non invasive mod that greatly improves the frequency response of the RV20. https://www.vintage-radio.net/forum/...d.php?t=110877
stevehertz is online now
Old 6th May 2023, 1:26 pm   #3
BBCmicro
BBCmicro's Avatar
Thank you for the tip!
I've ordered a long reach phono plug, when it arrives I'll give it a go.
It's a shame there aren't separate treble/bass controls on this but it does keep operation nice and simple!
BBCmicro is offline
Old 6th May 2023, 5:23 pm   #4
stevehertz
stevehertz's Avatar
Well with the mod you only have to adjust for the amount of treble you want. Without it you're wrestling with a sound that lacks bass, so you tend to reduce the treble, but then it becomes muffled. The mod sorts it.
Old 6th May 2023, 7:13 pm   #5
Uncle Bulgaria
Uncle Bulgaria's Avatar
It looks good! Well done.
It may have been on DIY Audio as I can't find a thread on here, but I recall having a lot of help when I was restoring my Mayflower II (also my first restoration) which resulted in the magic eye becoming much more responsive. It is a wonderful sounding radio.
I shall certainly add your mod to my list of things to investigate, stevehertz...
Uncle Bulgaria is offline
Old 6th May 2023, 8:49 pm   #6
60 oldjohn
That sounds OK to me, the Bars should only meet in middle of the viewing window when stood directly in front centre of the set, if not IIRC the tube can be slid a millimetre or so either way. BTW my experience is with the RV14 but I think they are the same in that respect.
John.
My favourite text message "I'll be there in five minutes, if not read again"
60 oldjohn is offline
Old 7th May 2023, 9:32 am   #7
vinrads
First class job well done .Mick.
vinrads is offline
Old 10th May 2023, 12:01 pm   #8
Pilot Mariner
Pilot Mariner's Avatar
Location: Burntwood, Staffordshire, UK or Kabaty in Warsaw Poland.
Steves tone modification made a such a vast improvement to the sound quality that I made it permanent in all my 3 HM2s.
Post 42 of this thread shows how I incorporated the 2 resistor/1 capacitor arrangement.
https://www.vintage-radio.net/forum/...=179104&page=3
Mark
Pilot Mariner is offline
Old 10th May 2023, 12:14 pm   #9
stevehertz
stevehertz's Avatar
John.
I think you're referring to Parallax Error there John? The OP (as I understand it) is talking about the bars (for some reason) not being driven hard enough to meet in the middle. Different thing.
Old 10th May 2023, 1:05 pm   #10
60 oldjohn
John.
My Mistake, In that case I would be checking the high value resistors R19 & R20.
John.
Old 11th May 2023, 7:58 pm   #11
BBCmicro
BBCmicro's Avatar
I've done the wee modification and the difference is very noticeable, a great improvement thanks!
I am out of 2.2M resistors have put in an order. Thanks all!
BBCmicro is offline
