6th Nov 2015, 2:06 pm | #1 |
"Wide Band" ultrasonic transducers.
Does anyone know of a source of 'wide band' ultrasonic transducers (like the TV remote-control types).
I'm resurrecting a bat-detector whose transducer failed some years back after being left out in the rain and ending up full of water: fitting a traditional 40KHz type salvaged from a dead 1980s TV chassis has a rather narrow bandwidth compared with the original (which has now been lost). [The bat-detector is remarkably simple - ultrasonic transducer, a single common-emitter amplifier and a balanced modulator fed with a variable-frequency square-wave from a 555. Result goes to a LM386. Essentially it's a 20-80KHz direct-conversion receiver!]. |
6th Nov 2015, 2:51 pm | #2 |
Re: "Wide Band" ultrasonic transducers.
There used to be some about 1 inch dia that were used in alarm systems. Don't know how wideband they were.
6th Nov 2015, 3:00 pm | #3 |
I use a 40 KHz piezo transducer on my bat-detector and it is indeed rather narrow. I did experiment with electret mic inserts but found they all rolled off below about 20 KHz.
My detector is similar to yours but uses an NE602 balanced mixer driven by a cmos oscillator.
Andy G1HBE. |
6th Nov 2015, 6:05 pm | #4 |
Nowadays a lot of cars have reversing sensors, they look a lot like the old transducers. Maybe a visit to the local car breakers may be an idea?
6th Nov 2015, 6:24 pm | #5 |
Certainly worth a try, but the electronics usually seem to have a tuning arrangement, so I suspect that they are resonant at a nominal frequency.
Would a piezo sounder, stripped of its casing, work perhaps? |
6th Nov 2015, 6:36 pm | #6 |
Hadn't thought of reversing sensors - I'm not sure if these combine both a transmitter and receiver in the same unit, or if there are a pair of transmitters and a separate pair of receivers per vehicle.
In another place someone's also suggested the "volumetric sensors" used in car-alarms to protect the insides of the vehicle against people breaking windows, slashing hoods on convertibles etc. The other thing I was wondering about are the flat circular piezoelectric transducers used as bleepers and pingers in things like digital clocks/watches/microwave-ovens. Definitely this is giving me things to think about - I'm now wondering about modifying the Bat-detector and using several switchable ultrasonic transducers [sort-of frequency-diversity?] to cover different Bat-channels? For example, the common Pipistrelle bat uses a call centred on 45 kHz, while the Soprano Pipistrelle echolocates at 55 kHz. The two species are sometimes called the 45 kHz Pipistrelle and the 55 kHz Pipistrelle. |
6th Nov 2015, 7:09 pm | #7 |
The reversing sensors I've seen are all single dynamic devices, but some have built-in electronics (pre-amp?).
6th Nov 2015, 7:42 pm | #8 |
Oops my post above (#3) was badly edited and gave the impression that electrets roll off *below* 20 KHz. I meant above. Ahem.
Andy G1HBE. |
6th Nov 2015, 8:29 pm | #9 | |
Don't forget the Horseshoe (if they are around at your location) they are around 100khz. Lawrence. |
6th Nov 2015, 8:35 pm | #10 |
Yes there's a Greater Horseshoe roost about 1/4 mile from my house. Getting them is one of the reasons I want a wideband transducer!
[Hmmmm... in the style of the 1950s "HAC" - Heard All Continents - single-valve shortwave radios I propose a HAB - "Heard All Bats" - receiver] |
6th Nov 2015, 9:55 pm | #11 |
The piezo sounders we used in some fire alarm sounders were normally resonant at around 2kHz so may not be suitable.
What frequency do the reversing sensors work at? Keith |
6th Nov 2015, 10:01 pm | #12 | |
Good luck with the detector and enjoy your bat detecting. Lawrence. |
6th Nov 2015, 10:16 pm | #13 |
There was a discussion on bat detectors microphones a while back. Some electrets give an extended response and it is posible to make capacitance types by streatching capacitor film over a pitted surface like sintered filter material. https://www.vintage-radio.net/forum/...d.php?t=102454 Pete |
6th Nov 2015, 11:34 pm | #14 |
I am fairly certain I have a load of unused CTV rem con receiver units. GEC type, maybe some Grundig. PM me if you want some.
Les. |
10th Nov 2015, 8:03 pm | #15 |
I woud guess that very few ultrasound sensors are "wide band", as the majority would be designed for a specific purpose, and use a frequency optimum for that purpose.
The sensitivity probably falls away quite dramatically when they are used off resonance. Tony. |
