Old 16th Oct 2018, 7:03 pm   #1
recordplayer
recordplayer's Avatar
Default Ekco RP430
HI , just repairing this player and C7 , C8 and C9 look weary and test out of spec also the Hunts caps I am going to change - I have the circuit and its on the Service data DVD but can anyone let me know if the Metalmite caps C7 , C8 and C9 are polarised - they are coloured red and black at each end but I am pretty sure these are not electrolytics - in fact I have never changed a Metalmite capacitor and have been doing this job for years !! The values of the caps are 0.01uf at 350 volt , Tony .
recordplayer is offline
Old 16th Oct 2018, 9:36 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Ekco RP430
Metalmite capacitors are paper dielectric, I have had them fail.
Frank
Nuvistor is offline
Old 16th Oct 2018, 10:17 pm   #3
recordplayer
Hi , yes I don't want to leave them in or replace with nos caps . What's a good modern replacement for these ?
Old 17th Oct 2018, 8:37 am   #4
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Personally I would use the yellow poly. axial caps made by LCR and others. These are what I normally use in any valved gear.
'LIVEWIRE?' is offline
Old 17th Oct 2018, 9:22 am   #5
dazzlevision
I use the Vishay (Roederstein) MKT1813 series Polyester film capacitors.
https://uk.rs-online.com/mobile/p/po...itors/1854280/
dazzlevision is online now
Old 17th Oct 2018, 11:51 am   #6
'LIVEWIRE?'
Those are the type I meant, DV. I've bought similar caps from, among others, CPC, Cricklewood Electronics, Farnell, & RS, over the years. Not all have been made by Vishay, though.
Old 17th Oct 2018, 2:46 pm   #7
recordplayer
Yes. I usually use the yellow LCR poly caps rated at 600 volts - but was just making sure the metalmites were not polarised - will get parts on order and see how I go - it should sound good 7 watts 2xECL 86 push-pull amp fitted.
Old 25th Oct 2018, 8:58 pm   #8
recordplayer
Hi , sorted the amp on this now - sounds great - just need to do the usual clean , re-grease and re-lubricate the deck , metalmites replaced with LCR poly caps and been on test for a full day so its looking good !
