Reply
Old 14th Oct 2018, 5:51 am   #1
suebutcher
suebutcher's Avatar
Default Mystery PA with Sanken transistors
Which manufacturers tended to use Sanken transistors? I'm checking over a Japanese PA amp with Sanken 2SD257 output transistors, but it has no brand name. The model number is LBH-1021/01, it's 15 watt, and the front panel is black with a sort of Sansui/Realistic/Kenwood look to it.
The Waves That Rule Britannia
suebutcher is offline   Reply With Quote
Old 14th Oct 2018, 7:11 am   #2
Diabolical Artificer
Diabolical Artificer's Avatar
Default Re: Mystery PA with Sanken transistors
I've had Pioneer and Marantz amps with Sanken Q's in, but that doesn't sound like yours. How about a pic?
Andy.
Diabolical Artificer is offline   Reply With Quote
Old 14th Oct 2018, 10:11 am   #3
suebutcher
suebutcher's Avatar
Here it is. Only the knob on the right is original, and a DIN mike socket has been added to the back. "LBH" makes me think of Leader, which had model numbers with similar prefixes, but I've only ever seen test gear from them.
ID:	170872   Click image for larger version
Old 14th Oct 2018, 12:22 pm   #4
Terry_VK5TM
That looks similar to an old Tandy/Radioshack PA I used to have many moons ago.
So wondering if it may be one of those generic ones that got branded for any of a multitude of companies.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline   Reply With Quote
Old 14th Oct 2018, 1:24 pm   #5
dseymo1
Eagle is another possibility.
dseymo1 is offline   Reply With Quote
Old 14th Oct 2018, 1:40 pm   #6
paulsherwin
paulsherwin's Avatar
It certainly has a 1990 cheap generic look to it. It's only 15W output so is certainly not a professional PA amp. Actually, it's hard to imagine what you would use such a limited amp for.
paulsherwin is online now   Reply With Quote
Old 14th Oct 2018, 2:44 pm   #7
Herald1360
Herald1360's Avatar
15W into 3 or 4 horn loaded PA speakers is plenty for a local show or fete.
It does look to have a 70V line output.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline   Reply With Quote
Old 14th Oct 2018, 3:22 pm   #8
paulsherwin
Ah, missed that. You're right in that case.
Old 14th Oct 2018, 3:53 pm   #9
Maarten
LBH1021/01 (without the -, but that could have slipped in as Japanese manufacturers almost always write model numbers that way) is a valid Philips model number from their Electro Acoustics department. They didn't always make their own amps, especially the cheaper models. It doesn't look like it was ever touched by Philips, no type plate, etc. but I think the model number is too much of a coincidence.
I'd say it's not 1990's but 1970's.
Philips model numbers starting with LB are all professional audio products, the third letter and first number indicate the sub-category. Unfortunately the letters LBH1 didn't exist yet according to the 1967 model number decoding key that I have (it goes up to LBG1), but if I were to take a guess, I'd say the model was commissioned by a local Philips ELA department, for example that of the UK.
Either that, or it was made by a Japanese manufacturer that was great at trolling (I'm not sure whether Philips could claim copyright on the number format Lxxnnnn).
Could you maybe take a picture in which the specs on the back are a bit more zoomed in? I'd like to transcribe them in my Philips numbers database (with a tick in the box "more info wanted" so if anything turns up even a few years from now, I know to go back to this topic). Pictures of the inside, possibly from markings that could help determine the OEM and build date, would be nice as well.
Maarten is online now   Reply With Quote
Old 14th Oct 2018, 4:28 pm   #10
Refugee
Refugee's Avatar
Date codes on components would help a lot.
Refugee is offline   Reply With Quote
Old 14th Oct 2018, 8:50 pm   #11
jamesperrett
It certainly looks like the sort of thing that Eagle would have sold in the 1970's but I don't recognise the model number.
jamesperrett is offline   Reply With Quote
Old 15th Oct 2018, 2:17 am   #12
suebutcher
suebutcher's Avatar
It's from 1979, there's just one date on a cable. Here's the interior, and a close-up of the model ID. The mixer board has printed resistors, and the three-transistor power amp is transformer coupled, the driver transformer being tucked under the board. The original knobs do look a bit Philips-ish, though I haven't been able to match them to anything else pictured on the Internet.
ID:	170962   Click image for larger version
Old 15th Oct 2018, 2:52 am   #13
Maarten
Thank you! For future reference: the amplifier board is marked PK-30A. The mixer board has printed on resistors. I think either JVC, Sharp or Pioneer used that technology but it may have been common for certain Japanese equipment of that era. 1979 seems a bit late but not too far out of range, but to confirm are there any date/batch codes on the Sanken transistors? Normally, semiconductors are a good indicator with a margin of roughly a year.
Also, aren't there any markings on the transformers? I think I see something on the side of one. Such markings might be useful in finding out in which brands they're also used.
Old 15th Oct 2018, 6:28 am   #14
The back panel looks like a TOA amplifier, they use the same blocks and the same anodised metal panel's and case construction. The designator looks TOA like too, but a search of their site reveals nowt, nor does a completed listing ebay search both in the UK and USA. A TOA amp would have "Made in Canada" not Japan.
Whatever it is, it looks well built using quality component's ( Rubycon caps), look at the size of the OPT, I bet it sounds well.
Andy.
Old 15th Oct 2018, 8:17 am   #15
suebutcher
suebutcher's Avatar
The output transistors, Sanken 2SD257, have the code 9 N, the power transformer's marked UP 15H PT OE, the output transformer is marked UP 15 OPT OD with OE stamped on the top, and the mixer board says PRC HDK S6837 (and possibly more, there's components in the way.)
It can do 17 watts at 400Hz and above into 4 ohms before distortion, drops off to about 10 watts before distortion at 100Hz, and isn't usable below 50Hz, but that'd be fine for voice and background music. Apart from the power cord being cut, nothing was wrong with it. For all I know it may have been dumped because a couple of knobs were missing. Now to find someone who actually wants it!
Old 15th Oct 2018, 10:53 am   #16
paulsherwin
The 240V voltage rating is unusual and implies it was made specifically for 240V countries such as the UK (and Australia?).
Old 15th Oct 2018, 11:13 am   #17
Studio263
Studio263's Avatar
Those dates just show at what point the cable type was approved by some certification body or other (is there a BS number nearby?), not the date of make. You could say that the unit can't be any older than this, but it may be considerably newer. It looks early to mid 80s to me.
Studio263 is offline   Reply With Quote
Old 15th Oct 2018, 11:22 am   #18
Herald1360
Herald1360's Avatar
And isn't 12,000 miles away......
....__________
Old 15th Oct 2018, 12:31 pm   #19
suebutcher
suebutcher's Avatar
No BS number, all the components including the wire are Japanese. Sumitomo put the year of manufacture on their cables for TEAC, for example.
Old 15th Oct 2018, 2:31 pm   #20
Refugee
Refugee's Avatar
Andy.
The output transformer looks big because it has two secondary windings to cover 70V and 4 ohms.
Reply
