8th Oct 2018, 2:32 pm | #1 |
How does a constant voltage transformer work?
As a matter of curiosity, how does a Constant Voltage Transformer work, such that even the heater outputs are stabilised?
Andy |
8th Oct 2018, 2:37 pm | #2 |
Re: How does a constant voltage transformer work?
They use a saturating core with a tuned winding. They can be had up to several kW capacity. Although very good at stabilising voltage, they are very susceptible to frequency changes so caution is needed. I used to buy from Advance.
Ken |
8th Oct 2018, 3:43 pm | #3 |
The one I encountered had a bathtub capacitor in series with the primary.
It saturated and then relied on the capacitor working as a dropper. |
8th Oct 2018, 4:47 pm | #4 |
Many thanks.
8th Oct 2018, 6:07 pm | #5 |
The Advance ones are resonated and are very picky about mains frequency. Never run them from a generator.
8th Oct 2018, 7:25 pm | #6 |
I think that the ones I used had three windings - primary, secondary and a parallel tuned one. They were used on a generator supply but a very smart system with standbys and extensive monitoring. The main problem with the generators was the number of seagulls gathering nearby for the warmth. This was in very remote part of the uk but we were constantly surprised by people "passing by" and cadging cups of tea !
Ken |
8th Oct 2018, 10:30 pm | #7 |
There's a bit of a technical description on the Claude Lyons website, one of those old companies who have and still are making this sort of thing. It mentions the resonating capacitors and the i/o specs they will acheive.
PS just reading an article about the closure of Claude Lyons in 2016!!!
Kevin Last edited by McMurdo; 8th Oct 2018 at 10:36 pm. |
9th Oct 2018, 4:02 pm | #8 |
Many moons ago... early 80's..we were tasked with finding a replacement for the "constant voltage transformers" used in the "back woods" in Turkey, as they were vastly in efficient........ well the Turkish ones were....these transformers were used to stabilize the mains voltage for the TV's in use at that time, as the mains voltage varied widely.
My colleague did the maths...... and we had a chip made by Ferranti, which was basically a number of voltage comparators and logic, which switched transformer taps with thyristors. This was hugely successful and the Turkish government were well pleased. I have no idea how many were made and sold in Turkey. We also designed and made higher power transformers for fridges and other domestic items. That was basically how NEI.. Network Electronic Industries came into being,
Should get out more. Regards Wendy G8BZY |
11th Oct 2018, 11:20 am | #9 |
I'm just starting to power up test a 1966'ish British Physical Laboratories RM175 LZ II Megohmeter that I'm restoring. It uses a two transformer scheme to generate a psuedo constant 240VAC to then supply two transformers (for instrumentation and HV supply).
It looks like a step-up auto-transformer is used to reduce the size of the resonant capacitor, and the sum of the saturating voltage across T1 terminal 3, plus the secondary of T2, is the regulated voltage passed to T3 and T4. T2 has a 4.66:1 turns ratio. T1 has terminal 2 tap at 45%, and terminal 3 at 67%. I haven't checked the inductance levels. The resonant cap C1 had been removed at some stage - and I'm presently substituting a 4.4uF, so it will be interesting to see what the regulation is like over mains voltage and load variations. I'll see if I can find a nice reference that describes the operation, and take some operating measurements soon. Last edited by trobbins; 11th Oct 2018 at 11:26 am. |
11th Oct 2018, 12:13 pm | #10 |
A description from Lee, 1955 (Electronic Transformers and Circuits) attached.
11th Oct 2018, 4:01 pm | #11 |
The ones I remember were fitted to some 1970s ICL computer gear: they used a 'third winding' on the transformer, resonated by a big non-polarised capacitor in a can. These ones had a tapped third-winding to allow 50 or 60Hz operation; output was 12 to 14V at about 30A.
They made one hell of a thump when switched-on! |
