Old 15th Jan 2018, 11:55 pm   #1
JHGibson
Default Cutting Aluminium Sheet.
I sometimes need to cut small pieces, sometimes with a straight edge, sometimes curved, from a large sheet of one sixteenth thick aluminium.Not having a guillotine I must use what the average home workshop has.
My main cutting tool is a jig saw with a fine tooth blade, but making a cut with half the sheet hanging over the work bench edge does not do a good job.
I found that if I place a piece of 2 inch thick rigid styrofoam on the floor and place my work piece on it then I obtain very good control of the jig saw and can cut a good edge with practice. The cut edge can be smoothed with a file.
John.
JHGibson is offline
Old 16th Jan 2018, 12:34 am   #2
Bazz4CQJ
Bazz4CQJ's Avatar
Default Re: Cutting Aluminium Sheet.
I just wanted to double check; styrofoam is 'expanded polystyrene' . Now, do all Canadians talk about aluminium, or are you a Brit who has escaped John?
Guess this would work on other sheet material. I recently had to take a few mm off the edge of a large, thin plastic panel and I used a mini-drill with a burr. Did a fair job but took very long time.
B
Bazz4CQJ is offline
Old 16th Jan 2018, 12:55 am   #3
JHGibson
Hi Bazz, Yes I escaped! Expanded polystyrene is called styrofoam in this neck of the woods.
John.
JHGibson is offline
Old 16th Jan 2018, 1:46 am   #4
MrBungle
MrBungle's Avatar
Interesting method. I’m using a set of left right and straight cut aviation shears. Clean cut every time. Only big problem is that you end up with blisters very quickly. Suggest wrapping the handles in insulation tape several times. Seems to keep the skin on!
Now folding it without a brake is where I come unstuck.
MrBungle is offline
Old 16th Jan 2018, 8:57 am   #5
Bobdger
Hi Bazz
Styrofoam is an extruded polystyrene and is uniquely identified by its blue colour. It was first developed and produced in the 1940's by Dow Chemical in the USA. Rapid Electronics list it.
Bob
Bob, BVWS member
Bobdger is offline
Old 16th Jan 2018, 9:43 am   #6
kellys_eye
I still use the sharp blade, scoring and bending method to cut sheet aluminium.
kellys_eye is offline
Old 16th Jan 2018, 9:58 am   #7
M0FYA Andy
A relevant topic, I'm currently thinking of buying an electric 'nibbling' cutter - does anyone have experience of these tools?
Andy
M0FYA Andy is offline
Old 16th Jan 2018, 10:25 am   #8
barrymagrec
I had an attachment type some years ago - it was O.K. for a while but soon started to create large burrs and jam up. - I suspect some are much better than others.
barrymagrec is offline
Old 16th Jan 2018, 10:53 am   #9
MrBungle
MrBungle's Avatar
Same experience. Mine was from Machine Mart. I'm using a hand nibbler now and keeping things for very small apertures in enclosures, mainly because it's hard work and I'm lazy
MrBungle is offline
Old 16th Jan 2018, 10:59 am   #10
M0FYA Andy
I not thinking of an attachment type, I've always found attachments to be rather unbalanced and clumsy.
I'm thinking of a tool which will cope with up to 1.5mm mild steel. The trouble is there are so many, at all sorts of prices, and I guess you get what you pay for, as always.
Old 16th Jan 2018, 11:06 am   #11
Craig Sawyers
Craig Sawyers's Avatar
I'm lucky in the I own a bandsaw with an accurately set adjustable fence; with the right blade it makes short work of cutting aluminium sheet. If I need a curved piece, I cut a rectangular piece first, then mark the curved line and cut freehand.
I realise that this is luxury, but my main hobby is amateur cabinet making and a good bandsaw is an essential piece of kit.
Craig Sawyers is offline
Old 16th Jan 2018, 11:09 am   #12
Rod H
I still use a simple and very effective little tool callled a Goscut Eclipse 2000, purchased around 1972 and so named after its inventor Tony Goss. It works a bit like a hand-gripped guillotine Unfortunately they're no longer available, but used ones seem to be available on eBay.
Rod H is offline
Old 16th Jan 2018, 11:51 am   #13
John M0GLN
John M0GLN's Avatar
For deburring a straight cut in aluminium a woodworkers plane with a cast iron sole will give a perfect edge.
John
John M0GLN is online now
Old 16th Jan 2018, 12:00 pm   #14
Craig Sawyers
Just don't expect it to be much use for wood afterwards
Old 16th Jan 2018, 12:30 pm   #15
John M0GLN
John M0GLN's Avatar
If there is any dulling of the blade it takes just a few seconds to touch it up, I've never really noticed it and I use mine mainly for hard woods.
John
Old 16th Jan 2018, 1:26 pm   #16
TrevorG3VLF
TrevorG3VLF's Avatar
I bought a nibbler attachment at a car boot sale and was told that it needed a powerful dril to operate. I dimantled it with difficulty and found a bearing slightly over half inch. I contacted the makers to find the correct size and was told the firm has moved to Australia. After pictures were exchanged, I was sent new parts free of charge from Australia so I now have a spare cutter and anvil. I find it difficult to accurately follow a line but it works well on aluminium.
I have also got a hand driven double shear which cuts out a narrow strip which curls up. The pieces left are not distorted as with shears.
My work for REMAP has now stopped so have not used either tool recently.
TrevorG3VLF is offline
Old 16th Jan 2018, 2:50 pm   #17
Nickthedentist
Nickthedentist's Avatar
https://vads.ac.uk/diad/bres/pub/COID/241/62.jpg
Nickthedentist is offline
Old 16th Jan 2018, 5:27 pm   #18
Herald1360
Herald1360's Avatar
Canada uses aluminium anyway.
(And has "limited" companies not "incorporated" ones, too.)
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 19th Jan 2018, 4:09 pm   #19
BigClick
BigClick's Avatar
This video shows how determination can get the job done without a brake press
https://www.youtube.com/watch?v=7p--jwtsT-M
watch from 5.30 for the bendy metal bit
BigClick is offline
Old 20th Jan 2018, 1:23 am   #20
Oliver35
Oliver35's Avatar
I once formed a couple of aluminium chassis for a project by bending them up in a Workmate, with two lengths of steel angle lining the clamping edges. Pushing over the tail of the sheet with a sizeable block of wood to avoid distortion resulted in a pretty reasonable fold. Wouldn't care to do it with anything stiffer, though.
Regards,
Oliver
Oliver35 is offline
