8th Jun 2017, 3:16 pm | #1 |
HMV 1134 Radio Restoration
Bit the bullet ...just had to buy this radio just up the road from me, and paid £15.00.. think it's a lovely design and reminds me of the one I had in my bedroom as a kid when I was about 8 in the mid 1960's.
Never had a go at anything like this and could be quite a project to undertake, not even going to plug it in, just look at the last image...looks like something has blown!!....when I took the back off this is how it was..... so will be looking for a lot of advice on testing and items to replace thanks in advance |
8th Jun 2017, 4:23 pm | #2 |
Re: HMV 1134 Radio Restoration
The blown part looks like the mains filter cap. Remove it. Wont affect sets performance.
Malc Scott |
8th Jun 2017, 4:56 pm | #3 |
It's actually quite a good choice for a first VHF restoration. I would advise getting the AM side of things working before looking at the FM aspects. If you're lucky it will just need a good clean and some new caps.
Attractive set. |
8th Jun 2017, 5:02 pm | #4 |
Change the audio coupling capacitor C52 0.001uF (Trader) then connect to lamp limiter (40 watt lamp if not using a variac) and check the HT voltage as it rises.
Connect an aerial, switch to MW, check smoothing caps are not getting warm and mains transformer is cool. With the volume up full you should start to hear some hiss or hum in the speaker, and maybe a station or two. HT voltage should be about 100 volts or more. If all OK, change to a 60 watt lamp, now you should be getting some stations and HT should be up to maybe 160 volts. The 60 watt lamp should be fairly dim. Try switching out the lamp limiter after a few hours of soaking on reduced voltage and go round checking all the voltages on the valves. Personally I always reform the main electrolytics using a home made reformer. Mike |
17th Jun 2017, 10:15 pm | #5 |
Thanks for the replies. Where is the best place to buy this capacitor? I hope to have a closer look this coming week and proceed with caution.
