26th Sep 2010, 2:56 pm | #21 |
Re: Obsolete fluorescent light fittings
There was one of those with single arm & long resistance (that used to get hot) fitted above the sink in the kitchen of my previous house. It was very wastefull of power & packed up in the end & got replaced by another "old" fitting with a "proper" choke
26th Sep 2010, 3:10 pm | #22 |
I've just been up in the loft to check my old tube stock & found that I only have one original bayonet cap tube left & it's the one that got broken the other week......
Not to worry though, as I've got a box of end cap adaptors. That fit on like this. So the old fittings look like living on for a long time to come |
26th Sep 2010, 3:32 pm | #23 |
Here's one of the bayonet end cap fittings that I mentioned in an earlier post.
Still working & hanging by its chains in the garage.....early 1950's or even 40's I've got several of these. This one is over the bench in my outside workshop. It normally runs with just the bare tube & hasn't had a cover fitted in ten years (the tube is pitted with hot metal thrown up from the bench grinder), hence the reason to not spoil the cover. I've just re-fitted the cover specially for these pictures. I can date this fitting exactly to 1959/60. This one has standard tube pin end cap fittings & has an internal 1 amp fuse fitted in a nice little socket & adjustable choke tappings, IIRC......... |
26th Sep 2010, 4:42 pm | #24 | |
Thinking about this, it probably was resistance wire. The fitting in question did (eventually) come in to my possession and was used as the main lighting in my shed/workshop at my parents house some years ago. Regards Andrew |
26th Sep 2010, 6:33 pm | #25 | |
Below is a picture of the Atlas Starterlamp, which has a standard 4-pin starter base with the lamp across the plain pins and the starter across the flanged pins. It is designed for a 40W 4' tube. In a fitting with resistance ballast such as the Philips one being discussed, where, what provides the starting impulse? Surely something inductive is needed and if one is going to go to the cost of installing a choke or transformer for that then why not do as normal and use the choke as the ballast too? On the subject of odd starting methods I invented an unusual instant starter that worked well and served in my workshop for a while, as a result of frustration with dead glow-starters. It consisted of two AC solenoids (gear-change and drain valve solenoids from a long since deceased Bendix LT washing machine) with their armatures mechanically connected in a 'tug-of-war' arrangement. The upper one was connected to the lamp supply, the other across the starter terminals of an ordinary choke-ballasted fitting. The armatures would be at rest with the lower one 'in' and the upper one 'out'. Switching the lamp on caused the upper solenoid to pull the armature suddenly out of the lower, changing its reluctance and generating the ignition impulse, then hitting a microswitch to insert an economy resistance and cut the starter out of circuit. I do like a bit of Heath Robinson every now and then! This sort of thing confirms that there is at least a modest amount of 'play value' in fluorescents! Lucien |
26th Sep 2010, 7:24 pm | #26 |
Couple of things which have been mentioned through this thread.
The use of incandescent filaments, while no longer commonplace as far as linear fluorescent lamps, does still see service in blended mercury vapour lamps. While these offer little better efficacy than incandescent lamps - they do have very long service lives, as such while essentially obsolete technologically, are still in production. I have some further information on these on my website on this page. Lamptech has some further information on the metal-stripe equipped tubes here as I see these have been mentioned quite a bit. Nice couple of units there, Techman. The covers on the one over the workbench definitely have the look of technology from that period don't they! In astonishingly good condition too - large diffusers like that are always very vulnerable to getting cracked I've found - especially once the plastic's aged by a few decades. |
26th Sep 2010, 7:45 pm | #27 |
My parents had a shop in the 70s /early80s and there were a number of the bayonet fluorescent fittings there .I remember the adapters too .I also wouldn't be surprised if there were some in Mums garage now !
I remember being annoyed about 10 years ago when a friends parents suddenly removed and dumped their 50s kitchen fitting that I had been admiring every visit.Very attractive reflectors with fins and ogee shaped ends I think .Green? The replacement is now in a skip too as it fell apart .There was nothing wrong with the original! When I moved here 20 years ago I removed two units in the kitchen which were from about 1960 .They were mounted ,stand away from the ceiling on a central fitting , but as we have low ceilings were not the best thing .Im not sure what the fixing type was . |
26th Sep 2010, 8:17 pm | #28 | |
I recently threw out an early 70's Crompton instant 'Snapstart' geared fitting because it was just taking up too much room in the garage. There is a similar one in my parents kitchen and its very instant, installed in 1972 or so, they have individual switches on the 'ballast' to make it safer to relamp in multiple commercial situations.
Kevin |
26th Sep 2010, 9:25 pm | #29 |
26th Sep 2010, 9:42 pm | #30 |
I can't see that somehow - fluorescent lamps need AC to work. If you use on DC, then the tube would probably be unevenly illuminated; also, the cathode would need to be permanently fed with some sort of heating supply (while the anode electrode would be hot due to electron bombardment with no gain). On AC the heat generated in an end electrode in 'anode' mode is made use of during the next half cycle when it's in 'cathode' mode.
26th Sep 2010, 9:42 pm | #31 |
This discussion has just reminded me of something which I've never actually seen an example of, but I've seen one video advert for (think it's in the videos section on Lamptech) and have one printed advert for buried somewhere.
Effectively the very first predecessor I imagine to CFLs, from the early 60s - made by Mazda, and named the Netaline. This was effectively a complete linear fluorescent fixture which attached to an existing lampholder. Given the weight of such a thing, I imagine they must have attached to the ceiling rose rather than the lampholder itself - and the one decent picture I've seen of one seems to confirm that. Anyone seen one of these?
Zel's Lair - A random bag of vintage tech, lighting information and other assorted geekery Last edited by Brian R Pateman; 27th Sep 2010 at 12:15 pm. Reason: Link fixed. |
26th Sep 2010, 10:24 pm | #32 |
Just in the ads of 'Exchange and Mart' years ago. A three-foot-ish metal arrangement that plugged into a bayonet socket?
Regds, Russell W. B. G4YLI. |
26th Sep 2010, 10:37 pm | #33 |
Why did you bring this up ? I have to replace one in my workshop ( the THIRD one) in about 10 years, the ballast looks like a transistor radio output transformer !!!! and like the last two is open circuit, they run at over 100 degrees C, the old ones ran at a ( hot) 60C were 6 times the size and dont go open circuit
Joe |
26th Sep 2010, 10:38 pm | #34 |
Pretty much - not entirely certain whether they actually fitted straight into the bayonet fitting - at over three pounds in weight you'd hope not! - or if they fastened to the actual ceiling rose. Having never seen one in person, it's hard to say.
The idea does seem to live on though - I spotted a couple of years ago in a DIY store a perfectly normal linear fluorescent fitting (18W one I think) with a B22 cap on the back! Last time I was there though they were no longer there though. In fact, linear fluorescents seemed very poorly catered for compared to previous visits.
Zel's Lair - A random bag of vintage tech, lighting information and other assorted geekery Last edited by Brian R Pateman; 27th Sep 2010 at 12:15 pm. Reason: After fixing link in earlier post. |
26th Sep 2010, 10:49 pm | #35 | |
The choke is there to provide the kick to strike the tube and then the impedance to prevent self destruction. Did they have different tubes, or is the "kick" not necessary? Back then we also had a very space age thing in our house, a circular fluorescent light, remember them? |
26th Sep 2010, 10:49 pm | #36 |
I remember seeing one of these plug-in linear fluorescent fittings - a friend had one in his shed. It was fairly awful. It consisted of a bayonet cap mounted on a plastic tube containing a long resistance wire ballast (no choke) with a couple of (2 foot?) fluorescent tubes attached. I still don't understand how the starting arrangement worked, though tubes as short as that will frequently strike without a starter in my experience.
26th Sep 2010, 11:19 pm | #37 |
Some of mine are working with bayonet converters; but occasionally on a long cool summer evening I would carefully 'de-cap' a new 5' tube, and fit the ends recovered from a used-up bayonet type. You have to extend the leads in order to reach the contacts, and then solder them very quickly with a hot iron, to prevent them coming apart again.
I have only one still running on a bi-metal starter. The filaments are glowing all the time the lamp is lit, so they eventually give up, at which point a glow-tube is fitted. It spoils the action of the lamp, though; the repeated strikes are a clear give-away. Is there an Ebay category 'Obsolete Fluorescents'? I'd certainly be bidding. |
26th Sep 2010, 11:44 pm | #38 |
Cmjones01: Doubt this is the same thing then - the Netaline looks to be rather more substantial bit of kit than that - and as far as I'm aware there weren't any twin tube versions.
This page shows an ad very similar to the one I have tucked away somewhere - I'll scan it if I can find it - and it doesn't look to me like a cheap bit of plastic. Yes - I want one! Brigham - Have you tried using one of the modern "pulse" starters? They tend to light the lamp on the first strike in my experience - not sure if they come in four pin versions though - all of the ones I have are two-pin.
Zel's Lair - A random bag of vintage tech, lighting information and other assorted geekery Last edited by Zelandeth; 26th Sep 2010 at 11:46 pm. Reason: Added info about starters, and corrected a typo |
27th Sep 2010, 8:43 am | #39 |
I did have in the garage of my old shop two huge fittings which I believe came from the late 30's. They were massive, heavy twin tube affairs,thinner than the usual older types but using a 5kv transformer to power them. They were simply fluorescent coated tubes filled with maybe Argon? The high voltage was applied to the ends as in Neon sign practise. They were salvaged from the Venner time switch factory just before demolition in 1978. I think one may still exist as I passed a couple to a mate to use in a store room. The attached pictures show an instant start Ekco fitting with the striped tube. It like the fittings described earlier came from the Venner factory. Regards, John.
27th Sep 2010, 8:49 am | #40 |
I like the look of that in Zels link ! very sixties stylish .Like something out of Madmen.
We had an early form of CFL i think In the 80s in the bathroom at home.Was horrible. Like a milk bottle flickered as it came on and i think I remember took ages to get to brightness .It was quite heavy i think too. |
