5th May 2009, 4:04 pm | #41 | |
Re: Help a newbie put a GECOPHONE 1000 into service
5th May 2009, 4:06 pm | #42 | |
8th May 2009, 1:31 pm | #43 |
... guess what the nice postman just delivered
8th May 2009, 1:52 pm | #44 |
So, take the blue wire and connect it to the new transmitter?
8th May 2009, 2:52 pm | #45 |
8th May 2009, 2:54 pm | #46 |
8th May 2009, 2:56 pm | #47 | |
Also, GEC would have used their own labels for non-GPO models. Frankly, I'd use whichever you like the look of. It's not like it's a permanent modification anyway. Nick. |
8th May 2009, 3:06 pm | #48 |
8th May 2009, 3:15 pm | #49 | ||
8th May 2009, 6:13 pm | #50 | |
Via PM:
It's not just a drop-in replacement though. You need to do some minor modifications. I'll post some pics after the weekend, if that's OK. Nick. |
8th May 2009, 6:20 pm | #51 |
8th May 2009, 6:21 pm | #52 |
Looks like if I shave the notches off round the edge it`ll fit.
8th May 2009, 6:38 pm | #53 |
Ah, Just realised your handset isn't a "normal" GPO Bakelite one, but a more modern looking one.
So you might well be right. The guts of the transmitter (black box with two screw terminals) can be removed in seconds by flicking off the front face of the red case with your fingers. This makes it smaller, or at the very least, allows you to modify the red case without risk of damage to the works. Then, connect it up; you may need to make up a short insulated wire to connect it to the terminals in the handset (where the original had a prong going into the central terminal). N. |
8th May 2009, 7:31 pm | #54 |
oki doki ,I`ll get cracking then. Have a good weekend Nick.
8th May 2009, 9:41 pm | #55 |
Right wasn`t enough to just shave the notches but managed to get it to fit.
Does this look OK? Tried it wired both ways round and it doesn`t seem to matter either way. You can hear your own voice through the receiver though, I guess that`s what the green things for? |
13th May 2009, 10:22 pm | #56 |
Can I get some help with this please...
13th May 2009, 10:26 pm | #57 |
Help in what sense? I'm not really sure what's wrong.
Cheers, Nick. |
13th May 2009, 10:29 pm | #58 |
An answer to my question above would be good Nick.
13th May 2009, 10:33 pm | #59 |
13th May 2009, 10:50 pm | #60 |
You mentioned those two things in the picture earlyer and said we`de get to them later..
When talking on the phone you can hear your voice in the receiver, the speaker bit. I guess that`s not normal and adding one of those two bits in the picture will help. Is this correct and how do I add them? Thanks for your help. |
