Reply
Old 28th Jan 2018, 10:20 pm   #1481
Station X
Station X's Avatar
Default Re: The "Sussex" Homebrew Valve Tester.
Would one of the forum's Sussex experts mind taking a look at post #1 in this thread to see if any changes are needed.
Thanks.
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 29th Jan 2018, 12:41 am   #1482
KeithsTV
KeithsTV's Avatar
It had been my intention to update the manual last year but various domestic matters intervened meaning various projects have been delayed. When I get the opportunity I'll take a look at the latest updates and produce an addendum to the manual.
Keith
KeithsTV is online now   Reply With Quote
Old 5th Feb 2018, 8:40 am   #1483
ricothebrol
Hi folks !
My tube tester is finally up and running. For reminder it's a modded version, which is able to test power tubes as well. I also had to design an "AC to DC" circuit because I couldn't find the right panel meter for gm reading. This was maybe the toughest part as I wasn't too familiar with floating circuits but now it's working great with great precision (I checked the measurements with a scope across the 10R anode resistor to make sure I calibrated my circuit correctly)
That being said, I ran a lot of different tubes in the tester at "typical characteristic" from their datasheet, and I noticed that I keep having low results for the anode current at the specified bias, and also for gm (I generally increase the bias to reach the specified Ia).
As the tester is still in "test" I double check the voltages with my multimeter and they are correct.
So my question is : do tube makers have a tendancy to be over-optimistic about their tube specs ?
Thanx in advance for sharing your experience.
Best regards.
Eric
ricothebrol is offline   Reply With Quote
Old 29th Mar 2018, 3:58 pm   #1484
G4WYZ MikeyP
G4WYZ MikeyP's Avatar
The excellent info David G4EBT on meter suppliers.
Unfortunately Asia Engineer does not supply to the UK anymore.
There is another supplier on EBay called 365-Bestseller http://stores.ebay.co.uk/365-bestsel...p2047675.l2563
The supply all three meters.
ie
https://www.ebay.co.uk/itm/3-1-2-Blu...wAAOxy7rdRERLb
73's Mike g4wyz
G4WYZ MikeyP is offline   Reply With Quote
Old 29th Mar 2018, 8:15 pm   #1485
Wallenda
Hi Mike,
I ordered from this seller a couple of weeks back - they were very helpful in making sure I had the right parts (low supply voltage)
Lou
Wallenda is offline   Reply With Quote
Old 1st Apr 2018, 6:25 pm   #1486
Alf Fisher
Thumbs up Re: The "Sussex" Homebrew Valve Tester.
Hi folks,
To those who have built themselves a Sussex VT1 using the new boards, I have a question that relates to the Voltage Selector switches and the way they are shown in post #1282 on page 65.
The resistors are shown mounted on the opposite side of the little board to the switch and seem a bit vulnerable to being bent over creating faults and shorts. I was thinking if the resistors were mounted on the same side of the board as the switch they would be better protected.
Any thoughts?
Incidentally, I bought my meters from 365-bestseller and had no difficulty. I contacted them to confirm the connections and they replied very quickly with the required information.
Cheers, Alf
Alf Fisher is offline   Reply With Quote
Old 1st Apr 2018, 8:02 pm   #1487
G8UWM-MildMartin
Hi Alf,
As long as your resistors are small enough to avoid shorting against the front panel, it is your choice.
G8UWM-MildMartin is offline   Reply With Quote
Old 4th Apr 2018, 12:27 pm   #1488
Dekatron's Avatar
The most important aspect to follow when mounting the switches has already been mentioned by G8UWM-MildMartin in his previous post, enough distance to the front panel - you could also put a plastic sheet behind the front panel if you wish to mount the resistors on the switch side to increase the isolation to the front panel.
If you are afraid that the resistors should become shorted in any way you can always put a piece of heat shrink tubing around each resistor or put a dab of silicone glue "binding" them together so they can't move.
I tried to place the resistors so that they shouldn't be able to move around if they are soldered tight to the circuit board, you might turn some resistors 180 degrees around so that any pins that could short be moved as far from each other and so that pins that don't matter if they short moves closer (pins already connected on the PCB).
I never did build a Sussex myself but tested the PCBs by placing components on them to make sure that they would work and would be possible to solder and use properly.
/Martin
Martin, Sweden
Dekatron is offline   Reply With Quote
Old 6th Apr 2018, 5:08 pm   #1489
Alf Fisher
Hi folks,
Has anyone created a running-out list to show where the connections from the on-board terminal blocks to the transformer and components on the front panel and everything else that isn't on the board.
It would be useful information to include in the construction manual when its updated.
Cheers, Alf
Old 7th Apr 2018, 11:54 pm   #1490
Sinewave
Sinewave's Avatar
I've just ordered a set of the PCBs, I'm looking forward to an involving project. I can hide in the garage for a while with this one.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW.
Sinewave is offline   Reply With Quote
Old 8th Apr 2018, 9:59 am   #1491
David G4EBT
David G4EBT's Avatar
ie
73's Mike g4wyz
Just a point worth reiterating, which isn't always made clear in the description of digital panel meters, (whether measuring Voltage or Current), is that the supply which powers the meter must not share a common ground with the circuit being measured. At the link above it does mention that requirement in the description, but not, for example, with the 500V DC one here:
http://vi.vipr.ebaydesc.com/ws/eBayI...1&secureDesc=0
I've no personal experience of the Sussex but discovered this requirement when I built the Capacitor Reformer which initially featured in Radio Bygones, and later in the BVWS Bulletin, the circuit of which had an error showing a common ground. I've mentioned this before but it might be worth reiterating.
Hopefully, when the meters arrive they do have a datasheet, but if anyone is unclear, I've attached a copy of the sheet which came with my meter, and others that I've bought since.
What a wonderful project this has turned out to be, with many stunning examples of completed testers, (many more yet to be finished!), and such commitment by so many forum members in developing the original design.
Name:	Digital Meter Module Info0001.jpg
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline   Reply With Quote
Old 9th Apr 2018, 9:13 pm   #1492
Wallenda
Thanks for the pic David - mine did not come with any information!
Lou
Old 9th Apr 2018, 9:56 pm   #1493
Thatvalveguy
Location: Nijmegen, Netherlands (You know from that bridge)
Could anyone PM me the approximate DC winding resistance and rated current for the 6,3VAC winding. I'm curious as to the feasibility of a low drop out regulator board for the Sussex heater supply.
Thatvalveguy is offline   Reply With Quote
Old 19th May 2018, 11:45 am   #1494
Station X
Station X's Avatar
Some posts moved to a new thread here:-
https://www.vintage-radio.net/forum/...d.php?t=146683
Old 25th Jul 2018, 6:46 am   #1495
G4WYZ MikeyP
The current PCB (c/w daughter board) ie version 9, whats happened to the low voltage function which was available on the original.
Looks like a separate PCB will have to be made, incidentally the Heater select switch quoted in the BOM is wrong it ought to be a 1 Pole 7 Way, not a 2 Pole 6 Way
Old 25th Jul 2018, 8:34 am   #1496
G8UWM-MildMartin
It has been changed from one LM317 switchable between 1.4V and 2V to one for each, sharing a heatsink (so insulating mounting kits are needed).
Old 23rd Aug 2018, 9:12 pm   #1497
G4WYZ MikeyP
In the Commissioning Section of the manual (page 5)
Measure the heater voltages between TB2-2 and TB2-5 and check it is within expected tolerances.
The lowest I can obtain is 7.42volts, using a Rigol DM3058E
Old 10th Oct 2018, 9:29 am   #1498
G4WYZ MikeyP
This is truly excellent valve tester, my observations are the lack of information as the manual in use was written for the original design by Less Carpenter.
The PCB is now on version 9, thanks to the updates by 'Detatron'.
When I started wiring and connecting the PCB all my misgivings evaporated away. The commissioning was excellent as some faults where wring found, unfortunately let down by no mention of setting up the oscillator.
Really impressed, thanks to all who have been involved with this design.
Attached is a 'Bill of Materials for version 9', which includes alternative suppliers and descriptions, if you decide to source from elsewhere.
Photographs will follow.
Mike G4WYZ
File Type: zip SUSSEX_VT1_BillofMaterials_V11 .xlsx.zip (12.9 KB, 274 views)
Old 11th Oct 2018, 5:56 pm   #1499
Top Cap
Top Cap's Avatar
I must confess to not keeping up with the changes since I built an early model and it has given faultless operation. The sine wave generator was either a work or no work circuit which seemed to rely on VR1 (200 Ohms) being set to the right point, I added the value that I found to work on mine which was 85 Ohms. Adjusting the 100mV drive, if I may call it that, required a RMS Voltmeter though I did wonder at the time, if it was possible to use the front panel AC mV Meter. Using a switch, one should be able to set the meter to 100mV by VR2 (4k7) then monitor the sense resistor R12 (10 Ohms) as normal, any metering errors will apply to both switch settings and thus give a reasonably accurate gm reading. You would of course have to set the Bias Volts Pot to 0V when checking 'drive' or the AC mV meter may complain. Maybe the switch could be made to do this in the CAL position?
I kept putting off trying this arrangement until the Sussex required service but that has not happened and maybe someone is in a better position to try it. If it works, the CAL pot and switch could be mounted on the front panel close to the sense resistor?
Name:	Calibration Mod special.jpg
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way!
Top Cap is offline   Reply With Quote
Old 25th Oct 2018, 8:35 pm   #1500
G4WYZ MikeyP
The early construction phase, this version incorporating an IEE mains socket.
ID:	171545   Click image for larger version
ID:	171546   Click image for larger version
ID:	171547   Click image for larger version
ID:	171548   Click image for larger version
Reply
