Old 15th Oct 2018, 11:11 am   #1
Tractorfan
Tractorfan's Avatar
Smile Sanders plug suffering the effects of damp.
I have a box of old UK plugs which have been kept in a plastic storage box in the cellar. Among them is a 'Sanders' 15 amp plug with sleeved pins. Said sleeves have swollen badly due to damp, which makes me wonder what they were made from? Something organic, no doubt, but what?
I also have a Sanders 5 amp plug with red sleeves. These have also swollen, but not as badly as the white ones on the other plug.
All the other plugs are OK, but these have definitely suffered.
Cheers, Pete.
Name:	'Sanders' plugs (1).jpg
ID:	170970   Click image for larger version
ID:	170971   Click image for larger version
"Hello?, Yes, I'm on the train, I might lose the signal soon as we're just going into a tunn..."
Tractorfan is offline
Old 15th Oct 2018, 1:16 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Sanders plug suffering the effects of damp.
That's a mess!
Ebonite/Vulcanite maybe?
Or the stuff they made the "forks" for 200-series telephones from which deliquesces?
Nickthedentist is online now
Old 15th Oct 2018, 1:45 pm   #3
The Philpott
The Philpott's Avatar
Lord knows!. It does look as if a cell has set up between the steel screws and the brass pins, but what made these particular plugs vulnerable..?
The Philpott is offline
Old 15th Oct 2018, 3:14 pm   #4
Celluloid?
Old 15th Oct 2018, 3:24 pm   #5
Nickthedentist
That's what I was thinking of!
See this snippet from Andy Emerson's book: https://books.google.co.uk/books?id=...luloid&f=false
Old 15th Oct 2018, 4:16 pm   #6
John10b
Interesting thanks.
John
John10b is offline
Old 15th Oct 2018, 4:39 pm   #7
The Philpott
Oh i see- if it were celluloid the screws might be under acid attack.
The interaction between PVC and ABS mentioned on the previous page is rather worrying- makes me glad i have a battery isolator on my vehicle.
Old 15th Oct 2018, 5:17 pm   #8
nebogipfel
nebogipfel's Avatar
I'm surprised to see sleeved pins on plugs of that vintage. I assume the corresponding socket would not have had a shutter back in those days?
In my ignorance I thought sleeves were a relatively recent safety feature.
Regards, John.
nebogipfel is offline
Old 15th Oct 2018, 5:55 pm   #9
Lucien Nunes
The sleeved pins were a rarity, offered as an extra feature by a few manufacturers including Sanders and GEC. They were also used on the Wandsworth proprietary gauge, where the switch was operated by inserting the plug. Shuttered sockets existed and I believe the sockets offered by Sanders concurrent with these plugs were indeed shuttered. Various other safety features were introduced ad-hoc, such as proprietary interlocking systems that usually captured the earth pin while the switch was on, fuses - both cartridge and bare wire in SP and DP configurations, and handshields that kept fingers well away from the pins.
Lucien Nunes is offline
Old 15th Oct 2018, 6:07 pm   #10
G6Tanuki
G6Tanuki's Avatar
Celluloid, or perhaps Casein - which was a strange pseudoplastic whose main ingredient was milk!
"Erinoid" - the result of mixing Casein and Formaldehyde - was used in all sorts of stuff in the first half of the 20th century.
G6Tanuki is offline
Old 15th Oct 2018, 6:56 pm   #11
John10b
I also don’t remember seeing sleeves on pins way back, but you live and learn.
John
John10b is offline
Old 15th Oct 2018, 7:22 pm   #12
nebogipfel
nebogipfel's Avatar
Indeed .....but I don't always remember it
Regards, John.
Old 15th Oct 2018, 10:31 pm   #13
Tractorfan
Tractorfan's Avatar
Smile Re: Sanders plug suffering the effects of damp.
The Sanders plugs had no finger shields, so sleeved pins were a necessity.
I think Crabtree were an early exponent of sleeved pins, among others.
Cheers, Pete.
Old 15th Oct 2018, 11:32 pm   #14
Refugee
Refugee's Avatar
Originally Posted by merlinmaxwell View Post
Celluloid?
I would never put Celluloid near power.
Have you seen how it used to burn?
My mum told me a story about a mate of hers who chucked a broken toy into the coal fire.
It flared up and set the chimney on fire so that big flames came out of the chimney pot.
Refugee is offline
Old 16th Oct 2018, 1:49 pm   #15
Richard_FM
Richard_FM's Avatar
I've heard it can burn very easily.
Hello IT: Have you Tried Turning It Off & On Again?
Richard_FM is offline
Old 16th Oct 2018, 2:16 pm   #16
The Philpott
It does. An early bombing raid (mentioned by Guy Gibson if i remember right) mentioned it's use in incendiaries designed to initiate a forest fire at high summer in axis territory.
Old 16th Oct 2018, 3:26 pm   #17
emeritus
I have a 5A Sanders plug. The insulation had already disappeared from one of the pins by the 1950's, leaving black insulation on the other, still intact today.
I can vouch for the inflammability of celluloid. In the mid-1950's an uncle gave me a roll of 35mm nitrate cine film , odd clips and a couple of wartime ministry of food shorts as I recall. It got packed away with my train set, and having read of how such films can deteriorate and spontaneously ignite, I dug it out. It had reached an advanced state of decomposition, so I put it in the garden incinerator, unreeled a few feet to use as a fuse, and lit it. Once the flame reached the main spool, it sent up in a spectacular sheet of flame. Not the sort of stuff suitable for electrical insulation.
emeritus is offline
Old 16th Oct 2018, 4:27 pm   #18
duncanlowe
I was told, though how true it is I'm not sure, that this is why 'modern' film had words like 'Kodak Safety Film' on it, because it wasn't cellulose. I also seem to remember a projectionist at our local cinema, giving us a tour of the facilities (whole other story) and mentioning the risks with the old film.
duncanlowe is online now
Old 16th Oct 2018, 4:34 pm   #19
Lucien Nunes
'Nitrate' film, used until the early 1950s, 'celluloid', and nitrocellulose a.k.a guncotton are all basically the same material, partially or fully nitrated cellulose with or without plasticisers. The flammability of nitrate film mandated elaborate safety precautions in projection boxes and on projector mechanisms, both to extinguish the fire and to prevent it spreading from the source of ignition (the heat of the lamp on the film in the gate) to the film in the spool boxes. I am not aware of small celluloid components in equipment combusting though.
Old 16th Oct 2018, 6:08 pm   #20
dseymo1
It may be an urban myth, but I've heard that an early application of nitrocellulose was in the manufacture of billiard balls, which swiftly ceased following a number of explosions on impact.
dseymo1 is offline
