7th Oct 2018, 4:59 pm | #1 |
Analog avometer to measure AC on 60Hz
Hello everyone,
I am just curious to know if someone know if the Avometer sold on the american continent were ever corrected for the 60 Hz. A/C supply (as opposed to the 50Hz in U.K & Europe) or if the intrinsic accuracy or resolution of the instrument never called for it ? |
7th Oct 2018, 5:18 pm | #2 |
Re: Analog avometer to measure A/C on 60Hz
The AVO 8 is rated from 25 to 2000 Hz for AC measurement so will be fine on 60Hz. As an aside I have one of my AVOs (the last model, found in a skip) at work, no one nicks it!
7th Oct 2018, 5:41 pm | #3 |
The AVO 8 was an expensive instrument even in its heyday- a substantial proportion went to the UK military who would have expected the accuracy of its AC ranges to extend to AC generators at 400Hz, 1600Hz etc. as well as the 50Hz mains supply and would certainly have specified an expectation of this performance.
7th Oct 2018, 5:48 pm | #4 | |
7th Oct 2018, 5:54 pm | #5 |
When my Dad bought his AVO 8 MkII new circa 1956 it was a very substantial investment to him at the time - but it still works and he occasionally still uses it.
7th Oct 2018, 6:28 pm | #6 |
I've found Avo 8's to read fine on AC at any frequency.
7th Oct 2018, 6:35 pm | #7 |
They would not have made any adjustment for the 60hz market simply because they didn't need to. Avo 8/III rear panel advises variation plus or minus 2% from 15 cycles to 15 kilocycles, from 10v to 250v. (plus or minus 4% on 2.5v range) In practice won't be measurable. Even the WW2 era meters claim accuracy from 25 to 100 cycles.
If however a pure sine wave is not encountered a (slightly) false reading would be given. Dave |
8th Oct 2018, 11:25 pm | #8 |
The OP didn't specifically mention the Model 8. The Model 7 has a "capacitance" range which needs an external mains-derived AC voltage source, and of course this does need to be 50Hz for the capacitance readings to be accurate. I don't know whether the Model 7 was ever marketed in Canada or the USA, and if it was whether any internal component changes were made to ensure the accuracy of the capacitance range.
I have a 1940s US-made Weston tube checker designed for 110 volts 60Hz mains. This has a capacitance range too, using a similar principle, which works but it is decidedly inaccurate when the instrument is run on 110 volts 50Hz!
10th Oct 2018, 2:36 am | #9 |
Re: Analog avometer to measure AC on 60Hz
...Thank you all for your comments and input.
Vaslejean. |
10th Oct 2018, 11:44 am | #10 | ||
Although I tend to use modern digital instruments now it is still in good working order. Anyway, back to topic. |
11th Oct 2018, 3:37 pm | #11 |
I've just taken one of my AVO's off the shelf - an 8mkII - and connected it to my HP745A AC calibrator. On the 10V AC volts range, it is within the thickness of a meter needle from 10Hz to 100kHz. That suggests that it goes a whole lot higher than 100kHz without losing accuracy.
First time I've tried that, and the result is astonishing, candidly. Craig |
11th Oct 2018, 4:24 pm | #12 |
The little meter rectifier stack on the Avo 8 MkII looks very similar to ones I have seen on old EMI Tape Machines used for the bias and erase metering, so I imagine they have a pretty reasonable frequency response, by the standards of the time.
11th Oct 2018, 5:27 pm | #13 | |
13th Oct 2018, 10:57 am | #14 |
...All achieved with a copper oxide rectifier, which they saw fit to replace with germanium diodes when the MkIII was introduced. I have only ever had to replace one of the former, and it's under-performance was backed up by the appearance of corrosion on the ends.
You notice how the early Mod 8/9 pamphlets are open about BSS89/1954 Sec.6 not (necessarily) being met on DC volts ranges; old fashioned full disclosure! It's probable that most of the meters, when newish, DID meet the spec. anyway. (i stand corrected on the 50-60hz capacitance issue, learned something today, thanks Phil!) Dave |
