6th Oct 2018, 10:31 am | #1 |
Removing Facia On Hameg HM605
Hi all
Just got my first scope and it needs a good clean. I have removed the smaller knobs as they unscrew but... does anyone know how to remove this knob and the other 2 as I want to clean the face-plate and everything else as it has years of crud on it from previous owners YUK. I have used reasonable force but they don't budge and I don't want to damage any of the pots that's they run too. I am thinking that they are on splines but cannot verify. Cheers |
6th Oct 2018, 11:20 am | #2 |
Re: Removing Facia On Hameg HM605
Yes.
If you form a small bent wire hook, insert it into the gap between the small spindle and the white disc surrounding it and gently pull the disc out, you will find a nut underneath it, for which you will need an appropriate hollow tube (box?) spanner. |
6th Oct 2018, 11:37 am | #3 |
Thank you so much as I wouldn't have thought about that.
