Old 13th Oct 2018, 2:19 pm   #61
Snarf81
Snarf81's Avatar
Default Re: Dynatron CTV63 problem
I've just had the back off and taken a picture of the capacitor, also I sorted the colour problem out. I still need to sort the focus out but will leave that for when I get a bigger mirror to shove in front of the screen. Incidentally, there is a Teletext can on one of the boards, can I assume it's Teletext enabled? Obviously it's useless now but I remember that some of my home recorded Betamax tapes have Teletext information on it.
Thanks again everyone.
Richard
ID:	170823   Click image for larger version
ID:	170824   Click image for larger version
ID:	170825   Click image for larger version
ID:	170826   Click image for larger version
Snarf81 is offline
Old 13th Oct 2018, 4:48 pm   #62
dazzlevision
The word “WELDED” on the big blue LCR capacitor tells us it is the reliable type and should not cause any trouble.
dazzlevision is online now
Old 13th Oct 2018, 4:51 pm   #63
Snarf81
Snarf81's Avatar
Phew...
I'm glad about that, one less thing to change.
Thanks dazzlevision.
Richard.
Snarf81 is offline
Old 14th Oct 2018, 11:19 am   #64
dazzlevision
The fact your set’s IF board has that Teletext label on a “can” suggests you have a Teletext capable set, but to be sure, you’d need to see if there is a Teletext decoder board fitted, which won’t be on the main chassis, but fitted to the cabinet side or bottom. I see from one of your pictures that there is one cabinet mounted board, with a small mains transformer on it, so your set is at least a remote control type. There is another board on the cabinet side that looks like it is the remote control board. There is no small Teletext interface board on the main chassis’ decoder board, so your set will not be Teletext capable. Do you have the remote control handset?
Old 14th Oct 2018, 11:32 am   #65
Snarf81
Snarf81's Avatar
There is a remote control that came with it but I'm not sure if it's the correct one for the set. I posted a picture of it along with that smoothing cap.
Thanks again
Richard.
Snarf81 is offline
Old 14th Oct 2018, 11:53 am   #66
dazzlevision
Here is a photo of the G11 decoder board (the middle one), with the Teletext interface sub-panel fitted (it's the small vertically mounted board, with a cable form going into the top of it, near the heatsink with three transistors). Your decoder board doesn't even have the connecting pins for the Teletext interface board.
Name:	Philips G26C724 IF decoder timebase view - components side.jpg
Old 14th Oct 2018, 12:36 pm   #67
dazzlevision
Richard.
The G11 is a Philips design and so is the remote, which looks like it is a suitable replacement for the original Dynatron branded item. No Teletext buttons on it, which reinforces my view that the TV isn’t a Teletext capable set.
Old 14th Oct 2018, 3:29 pm   #68
Red to black
Red to black's Avatar
Indeed, my model number data shows the Dynatron CTV 63 as Infra Red frc (full remote control) and non text in the feature list.
Last edited by Red to black; 14th Oct 2018 at 3:33 pm. Reason: missed part of model number
Red to black is offline
Old 14th Oct 2018, 5:05 pm   #69
Snarf81
Snarf81's Avatar
Ah ok,
Thank you for that information, at least I know now that I've got the correct replacement remote control and the set isn't teletext.
Thanks again
Richard.
Snarf81 is offline
Old 18th Oct 2018, 11:02 pm   #70
simpsons
Richard
I too am working on a G11 and on my version, a Philips, there is no clamp for the scan coils. It has been replaced by an incremental adjustment built into the yoke design which results in a "click" sound when you rotate the scan coils using the radial positioning lever.
First, of course, release the assembly by pulling the 2 levers away from the CRT bowl as shown in the diagram posted by Dazzelvision. I find it easier to adjust the scan to be vertical if necessary reducing the width to see the edge of the display against the CRT as any error is more noticable.
Because there are quite a few volts where your hand will be when adjusting the scan coil, I suggest you switch the set off each time you move it. You'll soon get the hang of it.
Chris
simpsons is offline
Old 19th Oct 2018, 11:00 am   #71
Snarf81
Snarf81's Avatar
Hi Chris,
Ahhhhh, that would explain why there is no clamp on mine then.
Thank you for this information. I'll have another go at it over the weekend as I haven't got the picture quite level yet, and thanks for the heads up about the live chassis! I'm doing all of the adjusting with the set unplugged. I just need to sort the focus out as around the screen is a bit blurry plus there is something wrong with the contrast whereby if it's turned to maximum and a bright image comes on then the top of the screen distorts and the picture flashes with an accompanying boom from the speaker.
Thanks again Chris
Richard.
Snarf81 is offline
Old 19th Oct 2018, 12:32 pm   #72
toshiba tony
toshiba tony's Avatar
This G11 wants it's a**e tanning. A noise coming from the speaker dependant on picture content is puzzling, but I seem to remember if the beam limiter comes in that could cause it. And regarding the "half live" chassis, just make sure you are not at (or near) anything that is at earth potential, iron, scope, radiators. Electricity should be respected but not feared. OK, I've probably raised a few eyebrows but you should be safe. You need to ascertain if the blurring issue convergence or a focus issue. These used split diode technology, focus issues could occur. Please post a pic or two of some lettering, perhaps of a freeview box in the menu mode.
toshiba tony is offline
Old 19th Oct 2018, 1:32 pm   #73
Snarf81
Snarf81's Avatar
Hi Tony.
Thanks for the info.
I've taken a few pics but my phone camera doesn't like the tv screen flicker...
Thanks
Richard.
ID:	171202   Click image for larger version
Snarf81 is offline
Old 19th Oct 2018, 3:44 pm   #74
MALC SCOTT
MALC SCOTT's Avatar
Check ht volts. Also RGB voltages. Do you have a manual? Malc.
Malc Scott
MALC SCOTT is offline
Old 19th Oct 2018, 4:32 pm   #75
Snarf81
Snarf81's Avatar
I've downloaded the service manual but I don't have an oscilloscope, but I do have a multimeter (which I need to repair the battery terminals).
Thanks
Richard
Snarf81 is offline
Old 22nd Oct 2018, 3:19 pm   #76
Snarf81
Snarf81's Avatar
Can this thread be closed please as I've decided to get rid of the tv set and be on the lookout for something more modern with scart etc.
Thanks again to everyone who commented, I appreciate your help and time.
Richard.
Snarf81 is offline
Old 23rd Oct 2018, 4:10 pm   #77
Maarten
I'm sure a fellow forum member can be found who would like to take it off your hands. Maybe offer it in the appropriate forum section.
Maarten is offline
Old 24th Oct 2018, 10:41 am   #78
Snarf81
Snarf81's Avatar
Hi.
I've already been in touch with a member on here and he says he wants it. If, for any reason, he decides he doesn't want it then I'll put a post up on here.
Thanks again.
Richard.
Snarf81 is offline
Old 24th Oct 2018, 6:24 pm   #79
toshiba tony
Well, call me sectionable but I had grown attached to this post, I now have dementia and whilst I remember the G11 the Dynatron version was of interest to me. Please, if it ends up being salvaged by a member on here please keep us up to date. We had both Philips and Thorn dealerships but the Philips one always made more sales. We saw a few Roberts tv's but the only Dynatron we saw was the 697. And that was a beast, I just hope it doesn't get necked. Take care all.
Tony Walker
Old 24th Oct 2018, 9:16 pm   #80
Snarf81
Snarf81's Avatar
Hi Tony.
Thanks for the post. I had grown attached to the tv but without proper service knowledge and equipment I couldn't go any further with it.
If the chap who wants it, doesn't want it for any reason then I'll advertise it on here so the new owner can keep us up to date with the pesky thing.
All the best.
Richard.
Snarf81 is offline
