Old 1st Sep 2018, 7:07 pm   #1
XsamX1987
Default DIY replacement power cable colour coding help
Hello all. A friend gave me a Raynox DU 707 A projector with no power cable. My plan is just to solder on a new power cable internally but I’m a bit stuck. I have soldered on the earth, I know on my new cable blue is neutral and brown is live but I don't know the corresponding colours if the brown is live or the yellow/red combination is neutral. I will include a picture as I don't think I’m explaining correctly. Hope someone can help me.
XsamX1987 is offline
Old 1st Sep 2018, 11:35 pm   #2
Radio_Dave
Radio_Dave's Avatar
Default Re: DIY replacement power cable colour coding help
Can't help you with where to connect the wires but I do hope your plan includes the removal or disconnection of the old mains socket
Radio_Dave is offline
Old 2nd Sep 2018, 12:44 am   #3
Graham G3ZVT
Graham G3ZVT's Avatar
It looks like in some markets the cable comes in through a grommet with no connector
https://www.van-eck.net/img/itable/i...2503253733.jpg
click to magnify
Live (brown) to the fuse and blue (neutral) to the transformer.
It's clear that the red wire going to neutral is one end of the RF suppressor cap.
As David said, do not leave the connector wired in.
Graham.
G3ZVT
Graham G3ZVT is offline
Old 2nd Sep 2018, 1:04 am   #4
Refugee
Refugee's Avatar
I would look into filing it to fit a C14 input connector they you can use a common C13 to mate with it.
Refugee is offline
Old 2nd Sep 2018, 1:28 am   #5
XsamX1987
I would like to say I was going to do that but I would be a liar, thanks for the Help.
That's a great idea just ordered.
Old 2nd Sep 2018, 1:34 am   #6
XsamX1987
click to magnify
Mine is a little different I have taken a new picture for you
and yes as David said I will remove the old connector, I don't know why I didn't think to
Old 2nd Sep 2018, 6:47 pm   #7
XsamX1987
Hello Rambo
New pic is this what your saying which wires are soldered together.
Old 2nd Sep 2018, 7:28 pm   #8
GrimJosef
Honestly if you've not done this often and you're not entirely confident about it then it would be worth getting a second opinion before you plug into the wall. The mains is very unforgiving.
Where are you in Oxfordshire ? If you can get over to Didcot I'll happily have a look. Two heads are better than one, even if one of them is mine (just to be clear, this wouldn't be commercial work and I'd not be charging at all for it).
Cheers,
GJ
http://www.ampregen.com
GrimJosef is offline
Old 2nd Sep 2018, 11:16 pm   #9
Graham G3ZVT
Yes.
Take care, and put a 3 or 5 amp fuse in the plug.
When vintage equipment is plugged in for the first time in decades, things can sometimes to go bang simply by degrading with age.
Graham.
G3ZVT
Old 2nd Sep 2018, 11:43 pm   #10
XsamX1987
Thanks for your Help and the warning Fingers crossed Huh
If it all goes to plan I will give an update with finished Project Pictures
Sam
Old 3rd Sep 2018, 2:10 am   #11
XsamX1987
Hey GJ thanks for the offer but I should be ok but when it comes down to it and I start to stress out I will stop and contact you
Sam
Old 4th Sep 2018, 9:46 am   #12
Brigham
Has nobody got the correct connector?
Brigham is offline
Old 4th Sep 2018, 11:28 am   #13
Goldie99
There is a better photo of the correct model on the van-eck website, might help a bit:
https://www.van-eck.net/img/itable/i...2336118481.jpg
May be worth asking them re. a power cable / connector - the separate power lead is shown as unavailable, but it costs nothing to ask... (all Dutch speak English).
Goldie99 is online now
Old 7th Sep 2018, 6:13 pm   #14
XsamX1987
Sorry guys I wasent keeping an eye on My post and I have already Finished Fitting the new Connector But thank you for your Posts.
Old 7th Sep 2018, 6:18 pm   #15
XsamX1987
Here is the completed Project would like to thank every one for your Help
Parts used C14 connector 2 screws Heat shrink and some new wire blue brown and earth
tools used
Dremel
Runs perfectly although I'm going to have to add some new Grease
Will include Pictures
ID:	168913   Click image for larger version
Old 7th Sep 2018, 7:03 pm   #16
Refugee
Refugee's Avatar
That looks an awful lot safer that your proposal at the start of this thread.
As a tip for the future those C14 connectors are often mounted behind the panel enabling them to be wired on the bench as part of the internal wiring harness. This also means that the cut in the panel is a rectangle making it easier to cut out.
Refugee is offline
Old 8th Sep 2018, 12:15 am   #17
Graham G3ZVT
That's a good result.
Graham.
G3ZVT
Old 11th Sep 2018, 11:11 am   #18
XsamX1987
Thanks Guys I'm very Happy with how it Turned out, and yes much safer I don't know what I was thinking, Cheers for the Tip.
